cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Results 1 to 8 of 8
2004-2007 Cadillac CTS-V Performance Mods Discussion, Deatschwerks fuel pump info in Cadillac CTS-V Series Forum - 2004 - 2007; Ive been waiting to post the results until I did the install and had pics but it seems like Im ...
    cutter5o is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    Sep 2009
    Houston
    42
    65
    Ive been waiting to post the results until I did the install and had pics but it seems like Im never going to finish so here ya go for the fuel pump
    I recently sent a stock fuel pickup assembly from our cars to Deatschwerks for install and flow testing of their DW301 pump. As noted by Chris in his email to me, Our stock fuel pump assembly has an internal restriction but it does allow more flow if you increase the voltage. Our stock CTS-V pump really dies out when it has a load put on it. This explains why I was running out of fuel when tuned with just LTs and an intake. I chose the Deatschwerks pump because it tends to respond well to higher voltage
    Chris said that at 16V the pump flowed almost 300 lph at 56psi. I will be running the Racetronix harness and a BAP so this should be fine for my needs.
    Im limiting my build to 600WHP so this should be more than adequate for my needs. Let me know if you have any questions.
    The pump is a direct replacement although you will need the fuel line from racetronix. If you want you can send your unit to Deatschwerks for assembly, they charge like $69 plus the pump for install. I attached the PDF with his flow bench results
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    2010
    Many
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,372
    Re: Deatschwerks fuel pump info
    Is that just a rebranded denso/kyosan pump that racetronix sells ?
    Curious.
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    27
    4,177
    Hmm.... This peaks my interest. I just bought a used bucket for 75 so I could experiment.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    Sep 2009
    Houston
    42
    65
    Quote Originally Posted by ichpen View Post
    Curious.
    I dont think so. Its a Deatschwerks DW300 pump that they make. It sells for like 169. It has had great success with the import guys. I came across it as an option back when I was searching for my fuel solution while planning this project. I called Chris and discussed it with him and he asked me to send him an assembly that I bought off of GulfM3 for testing and fitment. This is the article I read that turned me on to it. http://www.dsmtuners.com/forums/bolt...rformance.html
    Unfortunately our fuel pump assembly ...as it sits... restricts the hell out of our flow and limits an awesome pump. Now if your interested in looking at how we can find the restriction in our assembly design and remove it. Im all for that as I have it sitting on my desk right now. I can take a bunch of pics and we can post them up if you like. We might even be able to get Chris to flow test it for us if we find the restriction to get a comparison. I dont need this assembly for my build just the
    new Deatschwerks pump thats in it. Im willing to donate this assembly to the cause if you guys want to help me figure out the mods to it.
    Just curious as Im not used to posting pics. Can I add them to the post directly or do I have to use some photo bucket url?
    ctsv154's Avatar
    Oct 2007
    27
    4,177
    Photo bucket is what I do and it works great. I'm all in for pics and I as soon as I get my bucket we can mess around with it too.
    Sep 2009
    Houston
    42
    65
    I resurrected my photobucket account and am uploading pics now. I sent some to your email addy ctsv154. I have to go watch a movie with the wife and kids but Ill upload the pics when Im done. Ill need to take some more pics as Ive found some more stuff in the assembly that doesnt make sense...like the pinhole return after the FPR
    Front of assembly. The primary inlet is behind the FPR by my thumb. The inlet in the middle is for the remote pickup. The venturi is to the side of it and suction for the venturi is created by the flow from the pump to the fuel line
    This is the rear view with the bottom of the bucket off. you can see the line coming out of the fuel pump. this line has to be replaced when installing a new pump. BTW anyone gets a PN for the sock, you get a cookie.
    the top three are all views of the remote pickup and venturi. I think the venturi is our restriction. I still havent figured out where the remote pickup discharges
    these two are pics of the dissasembled unit
    The top three are pics of the check valve for the primary inlet. I assume this keeps fuel in the bucket when the tank gets low
    Pick of the top of the Deatschwerks pump installed
    front of assembly. the FPR is a killer. It hangs of of the return from the Fuel filter. the discharge from the FPR is into the primary inlet and is a pinhole.
    Im wondering what would happen if the FPR was removed and an actual return with boost controlled FPR was installed upstream.
    Sep 2009
    Houston
    42
    65
    ctsv154's Avatar
    Oct 2007
    27
    4,177
    I got my pump bucket and it looks good. I just can believe how small it is. The Venturi pick up dumps into the top of the bucket. Where the hose attaches, unclip the Venturi assembly and it has a nipple that slides in the top of the bucket. This is where it dumps the fuel it picks up.
    Found these pics online. Might be able to use a 255 or 285 in the stock bucket with the Venturi to keep the bucket full and then add another 255 or 285 on the other sending unit on a hobbs switch. I don't see why that wouldn't work. This guy did it!
    Wonder how big out stock fuel line is? I wonder why we can't ditch the fuel pressure regulator on the pump and add an adjustable higher flowing unit after the filter under the car. It would be a pain in the ass to adjust but would keep from running a new return from the engine bay.
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
