volant cold air intake
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Like Tree1Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, volant cold air intake in Cadillac CTS-V Series Forum - 2004 - 2007; i am just wondering if the volant cold air intake for 04-05 ls6 ctsv will fit a 2007 ls2 cts ...
    2007ThunderV's Avatar
    2007ThunderV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts v
    Jul 2011
    482
    i am just wondering if the volant cold air intake for 04-05 ls6 ctsv will fit a 2007 ls2 cts v
    i ordered one anyways, volant does not give a listing for 2007;s but there website says 2004-2006 which doesnt make sense.....
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,822
    Re: volant cold air intake
    I had one. It really didn't fit the '04-'05 LS6 very well either.
    Is it too late to get your money back?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,179
    Typically the only difference between cold air intakes designed for the 2006-2007 LS2 CTS-V and those designed for the 2004-2005 LS6 CTS-V is the addition of a vacuum tube input connection for the LS2. If not needed, this input connection can be capped, and conversely if the input is absent and needed you can make one. Also, the outside diameters of the 78mm and 90mm throttle bodies are the same so the OEM/CAI intake tubes are interchangeable.
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    I have one in my 04 and I really like it. Fits fine in my V. The only difference in the LS2 kit is a vac nipple onthe intake tube that can easily be installed.
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,822
    Quote Originally Posted by ctsv154 View Post
    I have one in my 04 and I really like it. Fits fine in my V. ...
    I had to go to Home Depot and get some weather stripping to seal the airbox. The holes to fasten it in place were not well alligned, either.
    Maybe mine was an early one.
    Jul 2011
    482
    nah too late to return it, its already in my garage...
    so i take it i need to add something for the vaccum line because mine is a ls2?
    anyone have a link or pics of what they did to modify it?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,179
    I have an LS2 throttle body on my LS6 which required me to add a tube to my existing intake tube. There are probably many parts that would work, but I used an air compressor quick disconnect piece which had threads on one end and a nipple that fit the vacuum tube to be attached. I drilled a hole in the intake and screwed in the threaded ended. I finished it off with some RTV. I could have put a retaining nut on the threaded part, but I decided I did not want the risk of losing it into the motor.
    lollygagger8 and lollygagger8 like this.
    Jul 2011
    482
    Quote Originally Posted by darkman View Post
    thanks for the pic, thats exactly what i was thinking, i have a bunch of copper pluming fittings that should do the trick.
    alradco's Avatar
    alradco is offline Cadillac Owners Fanatic
    Oct 2011
    43
    484
    How much bigger than stock is it? Anyone have any pics? Just curious if it will work with our aluminum radiator. Thanks.
    Peter
    tony tone is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Jan 2009
    miami
    36
    337
    Quote Originally Posted by alradco View Post
    mine and love it:
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,179
    Here is what they look like. I don't have any measurements.
    Jul 2011
    482
    Quote Originally Posted by tony tone View Post
    mine and love it:
    looks good..
    i plan on painting my lid to match the car, and ordering a gm performance division badge to replace the volant badge lol hopefully it looks goods
    Blake032's Avatar
    Blake032 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Jan 2013
    Alabama
    32
    35
    ALRADCO, from my experience it did not fit with your radiator. I ordered a volant and with your radiator and the stock fan shroud assembly it would not fit. I had to modify the K&N intake tube after I installed your radiator but it wasn't a problem. Love the radiator BTW!
  16. #14
    ImEpayne is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS-V
    Feb 2013
    North Syracuse, NY
    26
    71
    Found this thread very helpful, thanks all. Will be ordering my Volant for my '06 and doing the quick mod here shortly.
  17. #15
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Dec 2008
    Huntsville
    48
    291
    Has anyone come up with any beneficial mods for the volant? The reason I ask is I modded mine extensively to fit the much larger filter that came with the eforce blower. While I was at it I decided to open up the bottom front corner of the airbox in an effort to get as much flow as possible. I also added some silicon sheeting to replace the odd stock rubber piece on the front of the stock box. The additional sheeting seems to deflect more air into the box.
  18. Remove Advertisements
