Project "VANQUISH" Widebody kit for CTS-V - Page 11
Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 151 to 165 of 170
Like Tree34Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Project "VANQUISH" Widebody kit for CTS-V in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by AAIIIC The dry sump oil pump is totally in the way of where the A/C compressor needs ...
  1. #151
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Aug 2009
    Michigan
    576
    Re: Project "VANQUISH" Widebody kit for CTS-V
    Quote Originally Posted by AAIIIC View Post
    The dry sump oil pump is totally in the way of where the A/C compressor needs to go. No way that'll work. What sort of half-assed shop is doing this work?!
    Work being performed by yooper motorsports. Cooling is for oils, water, and brakes-wheel bearings. Driver gets plenty of cooling with no side windows at 150 plus.
    Won't be as pretty as Project VANQUISH, but should make a good chase car for video's
    Who will be on track first? zzilla or yooper??
  2. #152
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    I thought Mythbusters identified that fuel economy is better with the A/C on and the windows up at highway speeds. Wouldn't that indicate that you'd be faster with some sort of windows (as opposed to having nothing there) to prevent turbulent airflow along the sides of the car at 150+ mph?
  3. #153
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Quote Originally Posted by FuzzyLogic View Post
    Yes, unfortunately the track requires side windows to be down.
  5. #154
    Mar 2011
    2,045
    Quote Originally Posted by yooper View Post
    What about some kind of air deflectors to push the flow away from the windows? Are those allowed?
  6. #155
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Yes, if your class rules allow, no limit on the aero.
  7. #156
    ohsolos10 is offline Cadillac Owners Member
    Automobile(s): 2002 ecsalade 1995 deville concourse 2 1994 deville
    May 2012
    39
    1
    This looks very promising
  8. #157
    LSfan70s is offline Cadillac Owners Member
    May 2012
    3
    Great build! Subscribing
  9. #158
    zzilla is offline Cadillac Owners Fanatic
    Automobile(s): cts v-xlr v
    Jan 2009
    158
    UPDATE:
    Well so much for straight forward. Removed transmission and proceded to get the flu for Xmas and New Years, Yeah that was fun!! Any way back at it motor is out, new heads milled and on, cam in ,New rod bolts stretched,Timimg chain on Working on dry sump today.
    Then off to Rolex 24
  10. #159
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    1/2 year later... Any updates zz ?
    Needing a hood and rear wing...
  11. #160
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Well this half-assed shop finally got the track car off to the tuner. Really need some seat time soon, too much family drama!
    crankedupforit likes this.
  12. #161
    Junior1's Avatar
    Jun 2008
    1,248
    Looks good yooper. Talk to me about that wing...who, what, where, how much?
  13. #162
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Quote Originally Posted by Junior1 View Post
    PM sent
  14. #163
    Junior1's Avatar
    Jun 2008
    1,248
    PM sent
    Thank You sir
  15. #164
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,456
    That's some serious downforce goin' on there!
    Is that a rear diff cooler in the rear license plate area?
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  16. #165
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Yes, I had RPM Trans install internal pumps in both the trans and diff. Uses the inertia of the drivetrain to run the pumps while fluid is plumbed to a dual fluid cooler. The fan is on/off on the dash. Air is drawn from naca ducts to fan/cooler enclosure eliminating exhaust getting into car. I will start another thread regarding build of the chevy with the Cadillac motor.
  17. Remove Advertisements
