Page 1 of 6 123456 LastLast
Results 1 to 15 of 87
Thread: My F1c Pro-Charged CTS-V is complete
    spdracer77 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Sep 2005
    Naples, FL
    41
    124
    Project finally done on my 2004 CTS-V. Here are pictures of the set up most of you been waiting for.
    Original LS6 motor stroked to a 383 with all forged internals, diamond pistons, kooks long tube headers, dart 225 heads,LS7 throttle body, fast 92 intake, Ford 8.8 rear end,
    cam, magna flow exhaust, twin 255 fuel pumps, 60lb injectors, F1c pro-charger, huge 4 core intercooler, 50mm blow off valve and etc. 9lbs boost 641 rwhp and 575 torque with 4 1/2 pulley. With 4 inch pulley made 718 rwhp and 637 torque.
    rlj5's Avatar
    rlj5 is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ProCharged cts-V -Silver on Black
    Aug 2005
    Indy
    68
    673
    Re: My F1c Pro-Charged CTS-V is complete
    So, what kinda boost you runnin with the 4" pulley ?
    Is there a filter on that ProCharger intake ?
    F1-A ProCharged LS2/402 Forged w/AFR 225 heads & Fast 92mm intake |Meth | 1-7/8" kooks w/ Corsa |Stage V Trans by RPM w/ 9" Ford IRS |UUC Shifter |Msd shift lite |custom gauge pod w/dual interceptor scan gauges w/wide band |launch control |Line lock |Hre C-20 wheels |GY gsd3's 255/40/18 front & M/T 305/35/18 DR |Kw Coilovers
    Built & Tuned by EPP---------- 864 rwhp / 812 rwtq
    9" IRS built & installed by---- Madman Racing
    http://s478.photobucket.com/albums/r...view=slideshow
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Looks clean. Good numbers too.
  5. #4
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    That is Captain Insano!
  6. #5
    Sep 2005
    Naples, FL
    41
    124
    Thanks
  7. #6
    Sep 2005
    Naples, FL
    41
    124
    13lbs with the 4 inch pulley. There is no air filter only a screen cap that goes over it. I was thinking to either cut the pipe shorter to attach a filter on it or add an elbow and then attach the air filter. I think it would be better for the pro-charger. How much boost you running?
    Quote Originally Posted by rlj5 View Post
    So, what kinda boost you runnin with the 4" pulley ?<br>
  8. #7
    pato is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V
    Aug 2011
    186
    Really nice! Do you have a dyno sheet?
  9. #8
    z28dogg is offline Cadillac Owners Member
    Automobile(s): ctsv
    Sep 2010
    tucson
    32
    19
    WOW! Can we get build details?
  10. #9
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,831
    Quote Originally Posted by UnsafeAtAnySpd View Post
    It does look clean. "Good numbers?" Holy cow! That's an understatement.
  11. #10
    Sep 2005
    Naples, FL
    41
    124
    Quote Originally Posted by pato View Post
    Sorry no dyno sheet but I'm sure it could be printed out. Car is making this power with a mild tune. In a couple of weeks my tuner is coming down to tweak it up a little making it more aggressive. Now the timing is only at 14. It should be at least 18. I will post the before and after dyno sheets.
  12. #11
    bcarv87's Avatar
    bcarv87 is offline Cadillac Owners Fanatic
    Automobile(s): 05` maggied V
    Oct 2007
    MA
    142
    Badass man
  13. #12
    cam3439 is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Nov 2010
    106
    Nice.
  14. #13
    rlj5's Avatar
    Aug 2005
    Indy
    68
    673
    Quote Originally Posted by spdracer77 View Post
    nice looking build...
    Sure would like to see the dyno sheet on it
    I'd get an air filter on that engine....... JMHO
    I'm at 14 lb boost now with a 4" pulley
  15. #14
    MO POWA! is offline Cadillac Owners Fanatic
    Automobile(s): CTS V
    May 2009
    30
    140
    NICE! Is that a corvette bracket?
    Did you go with speed density tune? Is that a threaded IAT sensor by the bypass valve? How did u adapt it to the stock IAT sensor pigtail?
    BTW, Why didn't you clock the volute straight down and ran the charge pipe to the front off the car. That way you could run a horizontal flow intercooler.
  16. #15
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    great pics, any pics of it with the bumper off?
    and the same questions ( which bracket is that? a procharger one, A&A, etc?) as mopowa, I also dont see fans on your setup.
  • You may not post replies
