Lingenfelter High Performance Air Intake
Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
2004-2007 Cadillac CTS-V Performance Mods Discussion, Lingenfelter High Performance Air Intake in Cadillac CTS-V Series Forum - 2004 - 2007; http://www.cadillacforums.com/forums...ad.php?t=24017...
    Jeff@Lingenfelter's Avatar
    Jeff@Lingenfelter is offline Cadillac Owners Member
    Jul 2004
    Decatur, IN
    46
    ssmith100 is offline Cadillac Owners Connoisseur
    Feb 2004
    Conroe, Texas
    48
    1,394
    Re: Lingenfelter High Performance Air Intake
    Jeff,
    Any reason why the elbow part of the intake was not replaced? I would much rather have the elbow you are using that is on the Lingenfelter shoot out car. Will this piece be available?
    Thanks,
    Shane
    JOEYCTS-V's Avatar
    JOEYCTS-V is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V Sedan
    Aug 2004
    New York
    1,729
    I was gonna ask the question. The stock below hose looks very restrictive.
    Feb 2004
    Conroe, Texas
    48
    1,394
    The one on the SHoot Out car looks .......................sweet
    The factory one with the accordian elbow looks.................. well, like crap.
    Shane
    JOEYCTS-V's Avatar
    Aug 2004
    New York
    1,729
    I was hoping LPE would include the below hose as well. :disappoin
    Jul 2004
    Decatur, IN
    46
    The aluminum tube actually is prone to heat soak, and the factory piece isn't actually too bad. This was one of the more difficult air intakes to develope as the factory pieces are pretty efficient. Here is a dyno graph in which coolant temperatures were 192-194 degrees, no calibration work, completely stock CTS-V.
    Dreamin is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 ATS-V
    Feb 2004
    Calif.
    2,261
    Jeff, we are referring to your tube (pictured below)
    Is that piece Aluminum? It looks like it's black plastic. Is that a LPE designed tube? You designed a tube but aren't selling it?? Or is itsomeone elses tube?
    ...very confused...
    Feb 2004
    Conroe, Texas
    48
    1,394
    Dreamin,
    When I spoke to Jeff about the intake this morning......(Oh yeah, I ordered one ) he said that the elbow on their car is aluminum and powder coated.
    He also said that it generated a LOT of heat. They only noticed a slight HP loss (less than 1 HP) with the stock elbow. I'm not worrying about it to much since the NEW Magnacharger elbow will work just right.
    Shane
    JOEYCTS-V's Avatar
    Aug 2004
    New York
    1,729
    Why wouldn't they make it plastic? I'm undecided now because of this. It seems like it would be the perfect combo.
    Feb 2004
    Conroe, Texas
    48
    1,394
    Tooling cost is what I was told. It (tooling cost) could cost as much as $5,000.00 according to Jeff.
    Shane
    JOEYCTS-V's Avatar
    Aug 2004
    New York
    1,729
    Quote Originally Posted by GTP
    Is the added potential of 1HP worth the addition of a $40-50.00 part?
    Aaron
    It's not only the 1HP. It would also look a lot cleaner.
    Jul 2004
    Decatur, IN
    46
    The black tube that you see in the picture of our original design was aluminum powdercoated black. The aluminum tube is prone to heat soak, and the power gains weren't justifiable in tooling a silicone tube like the GTO piece. We reuse the stock elbow in our system, and the factory pieces aren't too bad considering restriction.
    Feb 2004
    Calif.
    2,261
    Jeff, one more Q: Did you have a scanner attached during the dyno runs? Would like to know if you saw KR, reduced timing, etc on either or both runs... or if they were both perfectly "clean" runs (i.e. no KR, WOT timing 22*, etc.)
  16. #14
    Jul 2004
    Decatur, IN
    46
    Quote Originally Posted by Dreamin
    All runs during testing were logged using EFILive. Each run was done at the same ECT (192°F -194°F). We would not use runs that showed knock retard for this comparison as they could skew the numbers. All runs used for comparison were "Clean" and the timing was identical. All testing was performed with the hood closed. Anyone who does not perform testing in this manner runs the risk of making false claims.
  17. #15
    Feb 2004
    Calif.
    2,261
    Thanks Jeff... was NOT questioning your testing methodology... my car just made a lot more power and that was *with* knock... guess the power difference is dyno and engine variances.
  18. Remove Advertisements
