Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: Got Katech LS9 Clutch Kit Installed ... finally.
  1. #31
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,831
    Re: Got Katech LS9 Clutch Kit Installed ... finally.
    I'll bet Brian has lots and lots of pics of "paperweights."
  2. #32
    PISNUOFF Guest
    Haha. Randy, you have no idea. I could fill a garage with them. I use to keep the broken stuff until my gf finally made me take a bunch to the scrap yard. Driveshaft, axles, clutches, broken rotors from burnouts, piston, LS2 shortblock, grooved out crank pulleys, more axles, lol. Not to mention all the stock parts that were scattered around....new parts waiting to be installed.
    Now I am only allowed to keep the really cool trophies and pictures of the regular carnage.
  3. #33
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by PISNUOFF View Post
    All this carnage, and you're still on the stock 4th gen diff, right? What kinds of axles are you running?
  4. #34
    Den_93's Avatar
    Den_93 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V
    May 2008
    Milford, MI
    316
    Which RPS clutch did you get?
    I did have problems with the LS9. I broke two pressure plates. The straps broke on both. After I properly broke each one in, I drove it like I stole it. The second one leased about three weeks. My guess is that they simply cannot hold up to ZR1 Hp/TQ levels when the vehicle weighs in at two tons and is consistently abused.
    My RPS has been a trooper for 15 months. I have not changes my driving habits and it's just now starting to have shifting issues at high rpms after getting it really hot. I'm hoping it's just the stock slave that is giving up but I'm not counting on it.
  5. #35
    PISNUOFF Guest
    Quote Originally Posted by HAMSTAR View Post
    Stock 4th gen diff and drive through the wheelhop for about two years without any concern for its wellbeing with stock axles. Most carnage was done with Gforce axles and stock CV's. I now have the DSS 1000 Hp axles.
    Quote Originally Posted by Den_93 View Post
    Organic/carbon fiber. Not sure what other 'options' there are. I had someone order it for me so I don't know the specifics.
  6. #36
    PISNUOFF Guest
    I blame these ring/pinion pieces 100% on HAMSTAR!!!! Lol
  7. #37
    Apr 2012
    Seattle, WA
    731
    Wut, don't blame me dude! That's a direct result of Aftermarket Racing Exhaust!
    Still, sorry to see. Is your diff OK?
  8. #38
    PISNUOFF Guest
    Haha. And wide pipes. It's the same as it was before I swapped the fluid today. It's been over a year since I change it. I did also find the bolts on my DSS axles loose today. One almost backed all the way out.
  9. #39
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,831
    ... I did also find the bolts on my DSS axles loose today. One almost backed all the way out.
    Yikes!
  10. #40
    PISNUOFF Guest
    Add two more ripped to shreds motor mounts. Just installed a set of Revshift ones. Also found that my headers had burned through two layers of Fiberglas heat tape into my alternator wire. Maybe that's been the cause of my battery dieing after two days of sitting and the battery charging light. Lol
  11. #41
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,831
    Brian, we need a thread just for your carnage.
    Make that a stickie.
  • You may not post replies
