CTS-V Coilovers from LG Motorsports - Page 8
Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 106 to 120 of 120
Like Tree9Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, CTS-V Coilovers from LG Motorsports in Cadillac CTS-V Series Forum - 2004 - 2007; 900 lb springs...wow. Why such an enormous difference in terms of front and rear spring rates? At what point does ...
  1. #106
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: CTS-V Coilovers from LG Motorsports
    900 lb springs...wow. Why such an enormous difference in terms of front and rear spring rates? At what point does it become more cost effective to eschew the shocks and springs and just install solid steel bars?
  2. #107
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by FuzzyLogic View Post
    eschew?
    One of the front shocks failed on mine once - the shaft seized and would not move. Although it made noise when driven over bumps at low speeds, handling even in fast sharp cornering seemed unaffected.
  3. #108
    Mar 2011
    2,045
    Quote Originally Posted by darkman View Post
    eschew?
    One of my favorite words to write (although I don't speak it, to avoid the literary nerd label). Essentially, it means to deliberately avoid using something, although I bet you already looked that up.
  5. #109
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Actually I looked it up about 30 years ago when I saw a bumper sticker that read "Eschew Obfuscation."
  6. #110
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    29
    979
    Big difference in spring rate because the rear springs are now mounted on the rear shock perch and so this changes the geometry
  7. #111
    atdeneve is offline Cadillac Owners Connoisseur
    Jan 2006
    2,114
    My spouse, Lucy, is ancient.
  8. #112
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,217
    Uhhhh... what?
  9. #113
    BradCTSV is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 2005 CTS-V
    May 2007
    114
    NVH? I had to look that up....Noise: no increase here, Vibration: no added vibration, Harshness: they are stiffer but only in a positive way. Before they were installed I was thinking the front spring rate increase from 400 lbs/inch to 700+ lbs/inch would be quite a bit. I feel with the heavy weight of the CTSV that the 700+ lb springs are just right. The Bilstein shocks are stiffer but a perfect match with the increase spring rates. I had 60k miles on the stock shocks and they felt like there was excess oscillation up and down....now when you hit bumps, the car just soaks them up...giving you a very planted feeling. FYI, the upper shock mounts are stiffer and I installed the Creative Steel rear lower urethane shock mounts....all of this results in the shock working well instead of the stock rubber mounts. These are true coilovers front and rear, so I lowered the front 3/4" and rear 1". There is about 1 1/2" gap between top of tires and bottom edge of wheelwells. Had it corner-balanced and aligned fairly stock....front camber -.50 and rear camber -1.50, caster 6.2.
  10. #114
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by BradCTSV View Post
    NVH?
    Okay, now what is the MTBF on those?
  11. #115
    Mar 2010
    San Jose, CA
    29
    979
    Mtbf is about 1000 hours on track and 10000 on the street based on my rma analysis.
  12. #116
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by OneFast V View Post
    Mtbf is about 1000 hours on track....
    Impressive considering it is only 30 hours for Penskes.
  13. #117
    Mar 2010
    San Jose, CA
    29
    979
    I think you mean mttr/service interval and not Mtbf. Id be quite suprised if you had a failure at 30 hours.
  14. #118
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    You're correct. The Penskes require rebuilding after 30 hours of operation.
  15. #119
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Interesting and very long read...perhaps I missed it but did these ever get put into production?
  16. #120
    Mar 2010
    San Jose, CA
    29
    979
    Quote Originally Posted by philistine View Post
    You just need to give LG a call and drop $2700.
  17. Remove Advertisements
