CTS-V Coilovers from LG Motorsports - Page 2
Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 16 to 30 of 120
Like Tree9Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, CTS-V Coilovers from LG Motorsports in Cadillac CTS-V Series Forum - 2004 - 2007; These move the rear spring, on to the shock. Because of the difference in wheel rate, there is no need ...
  1. #16
    DamnYankee is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Feb 2011
    42
    Re: CTS-V Coilovers from LG Motorsports
    These move the rear spring, on to the shock. Because of the difference in wheel rate, there is no need for such a stiff spring in the rear.
    100% bolt in, no cutting, grinding, or welding. The biggest job is removing the upper front shock mount, which is rubber. The new mount bolts right in, just like the LG Motorsports Vette kit.
    As for adjustable, thats many many months ahead, but it will be based on the Vette system again, which is single adjustable.
  2. #17
    catch2otwo is offline Cadillac Owners Fanatic
    Automobile(s): CTS_V
    Mar 2011
    SF Bay
    144
    Here is what was posted by GSS
    These will lower the car as low as you can go, before mechanical limitations set in- IE the A-Arm binds in the rear, and the upper a-arm binds on the chassis in the front. There is still shock travel to be had, so they will go as low as you can get them to go.
    Spring rates are in the 7xx/4xx range. These are prototypes, so rates may change when we get track time on it.
    Pricing will be 1990$ initially if we can get 3 sets, and 2295 after the intro.
    Louis
    _____________
  3. #18
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,312
    Quote Originally Posted by crankedupforit View Post
    After all the inquiries you've made over the last year from countless posts about others experiences with different shock set ups, you wind up with something completely unexpected.......a set up which no one has ever tried or has any experience with.
    My thoughts exactly.
    But LGM does know their shiznit, so at least he's going with a setup which nobody has ever tried or had any experience with put together by a reputable company.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  5. #19
    jerrycecco is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Jun 2005
    TX
    469
    After all the inquiries you've made over the last year from countless posts about others experiences with different shock set ups, you wind up with something completely unexpected.......a set up which no one has ever tried or has any experience with. Good luck with the project. LG will do a good job for you.
    Long story on this topic, I searched for a local/Dallas V with coilovers and did not find one. (I really wanted a test drive) So I started to searched for a shop to do the installation, LG Motorsports was on the short list of shops. After I talked with Louis, he wanted to install his own superior and race test parts over someone else's parts. HARD to say no to that...
    Louis described the benefits of the (what I call) "true" or 4 corner coilover system I really knew then I found the right shop and the right guy to get the car setup properly, not just throw a bunch of parts on the car.
  6. #20
    Jun 2005
    TX
    469
    A few of you asked and Louis told me the shocks he's using are 100% rebuildable.
    --Jerry
  7. #21
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by AAIIIC View Post
    And starting with a reputable shock. Bilstein is another plus.
  8. #22
    Jun 2005
    TX
    469
    I just heard this AM from Eagles Canyon Raceway,
    they moved the track day to Sat June 11th
    I'm planning to run the V :-)
    --Jerry
  9. #23
    Jun 2005
    TX
    469
    I got my V back today
    and I took the long way home...and it was a blast
    I need to find more twisty roads in the DFW area, did they make any in DFW?
    The car drove very very smooth firm without being harsh and no noise
    If want you like a test ride, pls PM me, but I'm going to limit drives to the DFW area
    ........UNLESS you want to pay my way to Laguna Seca....
  10. #24
    2kx2 is offline Cadillac Owners Fanatic
    May 2009
    44
    103
    Any more updates? I am interested in this setup. My factory shocks squeak and crack like crazy if someone sits in the backseat.
  11. #25
    Jun 2005
    TX
    469
    Drove the V alot on Saturday afternoon
    uneven side streets, stops lights, freeways, on ramps!!
    It's ALL good, still no noise, no vibrations.
    Ride quality: the Caddy softness is gone and replaced with firmness.
    trying to find the right words.
    I took a friend out for a test and nailed a few corners, very little body roll
    ......I have Hotchkis sway bars.......
    My wife said she did not feel a difference in ride quailty
    .......we were on side streets and on the freeway....but no high G's corners
  12. #26
    May 2009
    44
    103
    Thx. My wifes bimmer feels stiffer but not harsh. It actually feels more planted and surefooted than my v. I hate driving her car and then getting back in mine. I hate how poorly my v handles compared to her bmw.
  13. #27
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Your V must be bad.
  14. #28
    May 2009
    44
    103
    Must be. The rear end cluck, body roll, popping and creaking noisese are really annoying.
  15. #29
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    My 35,000 mile V has none of those things. Sux to be you...
  16. #30
    May 2009
    44
    103
    I'm getting ready to 80k on mine. Maggie, LT headers, Magnaflow exhaust, DSS axles, short throw shifter, and Racing Brakes 2pc rotors. I think it is time to swap all the mounts and suspension at this point. It sounds like a damn log truck with all the clunking.
  17. Remove Advertisements
