Ground Control coil over install
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
2004-2007 Cadillac CTS-V Performance Mods Discussion, Ground Control coil over install in Cadillac CTS-V Series Forum - 2004 - 2007; Got the FAQ info but lost the GC install sketch I received with them and assuming it is the same ...
    Black Sunshine's Avatar
    Black Sunshine is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS-V
    Nov 2006
    Moultrie, GA
    56
    838
    Got the FAQ info but lost the GC install sketch I received with them and assuming it is the same one mentioned in the FAQ.
    Where can I get a copy of the GC sletch? Anyone got one they can scan/copy and send to me?
    ronr's Avatar
    ronr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    May 2004
    Fenton, Michigan
    870
    Re: Ground Control coil over install
    The sketch pictured in the FAQ is a photo of the one GC sent with my kit. Not sure if they've updated/changed it since then.
    Nov 2006
    Moultrie, GA
    56
    838
    Where is this sketch pictured? It doesn't come up when I load the GC page on the FAQ.
    I've sent GC two emails with no response to my request for a copy.
    wcryan is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS-V Maggied
    Aug 2009
    Escondido, CA
    28
    1,065
    http://www.cadillacfaq.com/faq/answe...all/index.html
    -Dont forget your washers for the top of the rear shocks
    -Grease up your springs so they dont squeek
    GC Sketch is useless btw
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Apr 2008
    2,061
    grease the springs?
    Aug 2009
    Escondido, CA
    28
    1,065
    yessir...... Mine squeeked until I lightly greased the top and bottom of each spring
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,179
    Some folks even add thrust bearings to keep the noise down.
    Aug 2009
    Escondido, CA
    28
    1,065
    Where do the thrust bearings go?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,179
    Quote Originally Posted by wcryan View Post
    I have not installed a Ground Control setup myself, but the thrust bearings presumably go where the key grease goes which is above and below the springs where the spring contacts the perch. The noise is caused, at least in part, by the rotating action of the springs against the perch surface as they compress and decompress.
    Aug 2009
    Escondido, CA
    28
    1,065
    i'll have to look into those..... The squeeking is getting pretty annoying
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    No squeak with mine. Been on GC for several years.
    Aug 2009
    Escondido, CA
    28
    1,065
    Lucky
    CadzillaTN's Avatar
    Apr 2008
    2,061
    None here either which is why I was surprised about the grease suggestion. Mine sounds like a bucket of loose metal parts when going over bumps, but no squeaks.
  16. #14
    Nov 2006
    Moultrie, GA
    56
    838
    I'm looking for the GC sketch so I can identify the parts of the kit I am missing and order/find replacements.
  17. #15
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    I must be really lucky cause my car sounds stock as far as suspension goes. No sqeaks rattles or anything. I did add some spacers in the back when I installed them so maybe that's why there is no clunk?
  18. Remove Advertisements
