MAP sensor low voltage
Results 1 to 3 of 3
2004-2007 Cadillac CTS-V Performance Mods Discussion, MAP sensor low voltage in Cadillac CTS-V Series Forum - 2004 - 2007; both on check engine and hand held scanner. Brand new install Maggie wih 10% overdrive balancer. Car hasn't even been ...
    leosul@verizon.net is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V
    Jan 2011
    Western Massachusetts
    203
    both on check engine and hand held scanner. Brand new install Maggie wih 10% overdrive balancer. Car hasn't even been driven yet... One thread only, I promise!
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Re: MAP sensor low voltage
    See if its plugged in and then check the wiring. If your rear pulleys chewed through the wiring you'll get a code....
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    Yep, either not seated well, wiring gone or worst case gone faulty.
