Cradle bushings or G-Force axle?
Results 1 to 15 of 15
2004-2007 Cadillac CTS-V Performance Mods Discussion, Cradle bushings or G-Force axle? in Cadillac CTS-V Series Forum - 2004 - 2007; Sorry the multitude of threads, but I have a few ?s before I take my car in for quite a ...
    a3ritter is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V
    Jun 2010
    Royal Oak, MI
    33
    Sorry the multitude of threads, but I have a few ?s before I take my car in for quite a bit of work. One area I am planning to improve is stress on the rear via cradle bushings or axle. I have been told the bushings will be good enough for the power I am planning to generate, cam/ headers/ full exhaust/ P&P TB/ CAI/ tune, and the axle would not be of much benefit. I am curious of your thoughts and which would be a better way to go. Thankx.
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    Re: Cradle bushings or G-Force axle?
    Axles.... definetly axles.... (i say this without using the bushings myself) but i have a feeling others will chime in with the same.
    The axles just work so good.
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    I'm sure most of the replies will be to get the axles. But I'll give you a Specter bushing owners point of view.
    They work great on my Maggied car with the original 05 diff. I've done clutch dumps and have broken the tires loose simply by giving it too much gas. Minimal hop at worst, but usually it's smooth tire spin. I do get some hop in the rain though.
    I did get some whine out of my otherwise quiet diff. But they also tighten up the whole rear. The car handles better now. Especially on a bumpy road/highway.
    Either mod will handle the power you'll make. In fact I don't think power makes any difference unless you get into serious power.
    kevm14 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8
    May 2008
    35
    1,354
    Do the bushings get rid of that annoying side-to-side sway feeling over certain surfaces? I can only assume that the cradle is moving around all over the place when I feel this.
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    axles - yes
    cradle bushings... = i removed mine as it amplified the whine of my brand new diff. once removed diff was silent. up to you, mild loss of what was left of my wheel hop after the axle or amplified diff whine. i chose the quiter diff. dunno why as i have kooks headers, borla exhaust and cutouts.
    i reccommed hotchkis sway bars. they keep the car flat in turns.
    May 2008
    35
    1,354
    I'm talking about more of a waddle feeling. Seems to be coming from the rear and I always pictured the cradle moving around, causing it. I was just wondering if someone added bushings and noticed this feeling was gone. Though this isn't the thread for this...but people with bushings will theoretically be weighing in.
    kentuckyplow is offline Cadillac Owners Member
    Automobile(s): 2003 CTS, 2005 CTS-V
    Feb 2009
    44
    21
    "I'm talking about more of a waddle feeling."
    I know that exact feeling you're talking about and was wondering what the cause was myself. And more important, the cure.
    Hopefully someone can educate us.
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Aug 2009
    Michigan
    576
    I had the same feeling with 275/40 x 18 tires on oem rims. After checking the torque of every bolt in rear suspension I put 245/45 x 18 on rears and the waddle went away. Check to see that your coil springs are properly positioned in their mounts. Next came the SW bushings and then the axles, then the BMR Trailing arms and toe rods. Now the play is concentrated at the trailing arm lower bushing and there is way too much movement. Getting rid of all the play will eliminate wheel hop. There will always be stress on the OEM diff due to the way it's mounted in the cradle. Look at the V2 diff mounting points.
    IMHO this car needs delrin bushing at all suspension joints front and rear if you want to fully utilize the handling capabilities of the V. If your goal is a daily driver, replace the OEM clutch/flywheel with the LS7 kit from Luke, get a good tune and enjoy, but don't dump the clutch! Even with all the soft rubber bushings, these cars handle pretty good.
    Quote Originally Posted by kevm14 View Post
    May 2008
    35
    1,354
    It does handle great! In fact, in a corner, I never notice anything that feels odd. It's mainly going straight over certain surfaces.
    Also I have stock size tires.
    I think I was hoping that the bushings would get rid of that feeling, plus reduce wheel hop. I guess I could find the time this summer.
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    At first I thought you were talking about how the rear moves around in turns. The bushings do eliminate that. But your probably talking about tracking in groves. Like if a lot of trucks use a road and it develops a grove. You can make it better by taking some toe out of the front. But then your car wont feel so precise. I tried it and decided I'd rather live with the tracking. To be honest, I don't remember if the bushings helped with this or not. Either I'm used to it, or something made it better. But it really doesn't bother me anymore.
    May 2008
    35
    1,354
    I don't think it's tramline, but the rear moving around. Trust me, my Caprice on 255/50-17s tramlines way worse than these cars do.
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    If the rear is moving around, the bushings will help.
    http://www.cadillacforums.com/forums...eo-inside.html
    Castro's Avatar
    Castro is offline Cadillac Owners Fanatic
    Automobile(s): None
    Jan 2005
    DC
    34
    447
    My cradle bushings make the diff very noticeably louder and I'm planning to get rid of them when I get around to it. Axle stops the wheel hop 90%, bushings might be a contributer too but I'm not really convinced of their value. Whoever told you that the bushings will be able to "handle the power" and axles won't be of much use doesn't know what they're talking about quite frankly. Stock power is way more than enough to cause severe wheel hop.
  16. #14
    Jun 2010
    Royal Oak, MI
    33
    Well again, what I was told was that the bushings would be enough to handle the wheel hop, essentially making the axles overkill and unnecessary.
  17. #15
    Castro's Avatar
    Automobile(s): None
    Jan 2005
    DC
    34
    447
    I would recommend doing a gforce passenger side axle first and go from there. It will make the biggest difference by far and is inexpensive. If you are still getting hop you could try either doing the driver side axle as well and/or do the bushings. As mentioned there can be a big trade off with the bushings but not with the axles. For me and some others it is a constant annoyance in exchange for possibly eliminating a rare annoyance. Do you already have diff whine?
  18. Remove Advertisements
