Newbie - Week #1 Modding Results
Results 1 to 11 of 11
2004-2007 Cadillac CTS-V Performance Mods Discussion, Newbie - Week #1 Modding Results in Cadillac CTS-V Series Forum - 2004 - 2007; No pictures or dyno numbers yet, but I did want to share regarding my weekend's worth of work on my ...
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    No pictures or dyno numbers yet, but I did want to share regarding my weekend's worth of work on my 2006 CTS-V. I think I accomplished quite a lot:
    Lesson Learned #1 (tools): You can NEVER have enough tools (especially box wrenches of various sizes and lengths). Worst thing ever is realizing that you're missing a tool and having to undo your work to head over to the store. The lack of a long 7/8" box wrench stopped me from installing my headers today (couldn't apply enough torque to remove my O2 sensors). Also, get heavy-duty Nitrile gloves. Not only will they keep you from getting burned, they do an excellent job of keeping you from getting cut when a wrench slips.
    Lesson Learned #2 (Exhaust Removal): when removing the rubber brackets from your exhaust, the easiest two to get off are the ones located on the outside edge of your tailpipes. Apply a thin lube (Liquid Wrench or WD-40), get on your back, and man-handle that thing with one hand while simultaneously lifting the muffler up and toward the mount with the other hand. Regardless of how you manage it, it's hard work--those rubber mounts are really tough.
    Lesson Learned #3 (Muffler Gutting): First off, you have to remove the exhaust from the car to do this. There's is no fiberglass in the bottom of the muffler. A 3/4" hole in the top/center of the muffler is sufficient to pull it all out. I have videos to show the difference in sound before and after (will post separately, once I finish with the car). Short version: no discernible difference in volume. Car starts up a little more smoothly, however, and revs a little bit quicker. Alone, this modification is not worth the time--it's part of a system that includes your catalytic converters, manifold, and CAI. Do 'em all, or don't bother.
    Lesson Learned #4 (Differential Fluid): First off, if you haven't changed this fluid before, DO IT. I have 15,000 miles on my (babied) 2006 CTS-V, and this fluid was black. I filled/flushed with 2 quarts of Royal Purple Max-Gear. I normally corner like a banshee, and during turns, it feels like I just lost 200 pounds off the rear end of the car. Bonus: no more of that echoing *ka-chunk-ka-ka-ka" when disengaging the clutch at high RPM, rev-matching is easier (feels like I just changed the engine oil), and the car is coasting significantly better.
    Oh, and by the way, if you haven't done it yet, taking that fill bolt off is a $#@%ing [censored]. If it hasn't been broken free, you'll almost certainly need to remove the exhaust to give yourself enough room to put sufficient torque on it. I had to lay on my back, jam my feet in the jacks, and pull with both hands to free it.
    Lesson Learned #5 (Laser/Radar Detector Hard-wire): I'm kind of handicapped here by being an electrical engineer, but for anyone else out there who also knows the red/black convention: when it comes to Beltronics products, green is +12V and red is ground. Seriously, wtf guys?
    Lesson Learned #6 (CG Lock): for some unknown reason, Cadillac opted not to include a locking seatbelt buckle for the driver (although they're in every other seat). The CG lock solves this problem, and it holds much better than GM's design. Driving experience is greatly improved with this thing--best $50 investment on this car yet. I will be talking to the person who does the V-series brake caliper decals to create a custom decal for the CG Lock if anyone else wants in.
    With that, I'm out (for now). I'm tired and I smell like Liquid Wrench, Royal Purple, mushed worms (it rained yesterday), and sweat.
    A sample of the upgrades to come in the following 3 weeks:
    - LS7 clutch / 20 lb steel flywheel
    - Wrapped OBX headers
    - CAI
    - Katech short throw shifter + UUC bushings (if Luke would only hurry up)
    - Ground Control spring kit + MM spacers
    - V2 shifter + custom shift boot
    - Hawk HP+ brake pads and repainted calipers with new silver "V" decals
    - Embroidered headrests (let me know if you want in)
    - Complete LED light overhaul (replace all incandescents)
    - EL wire mood lighting
    - Rear radar detector hard wire
    DMM's Avatar
    DMM
    DMM is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2010
    Maryland
    40
    389
    Re: Newbie - Week #1 Modding Results
    Congrats! Probably feels like a new car! BTW - welcome to hell...mod hell
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    Careful. Mods are like crack. Tough to stop once you start.
    Quote Originally Posted by FuzzyLogic View Post
    ... for anyone else out there who also knows the red/black convention: when it comes to Beltronics products, green is +12V and red is ground. Seriously, wtf guys? ...
    PISNUOFF Guest
    The rubber exhaust mounts come off easily with lube and a pry bar. Installation is easier if you put the mounts on the exhaust first, then on the fixed posts (with the exception of the forward most one on each side, unless you remove the locking washer first).
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    no motormounts? you really should check them out and replace them now when the headers are out asaposed to down the road..
    -EL wire mood lighting
    whaaaa?
    also--
    perfect's Avatar
    perfect is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac CTS-V Platinum
    May 2008
    Kansas City
    33
    1,182
    Fellow EE here as well and was a bit peeved at the wiring convention of my hardwired V1.
    And +1 to "you can never have enough tools".
    Mar 2011
    2,045
    I'm sorry, but--as I went to review your responses I saw what I originally wrote, albeit totally out of context.
    Apply a thin lube (Liquid Wrench or WD-40), get on your back, and man-handle that thing with one hand . . .
    Anyway, I will be taking pictures (especially after adding the EL wire), but I want to wait until I get closer to completion.
    DMM's Avatar
    DMM
    Jan 2010
    Maryland
    40
    389
    Quote Originally Posted by shadybx7 View Post
    whaaaa?
    also--
    +1 on the motor mounts, and go aftermarket vice OE so that you do not have to do them again.
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Apr 2008
    2,061
    Kudos to the OP for adding value instead of only lurking!
    Quote Originally Posted by rand49er View Post
    Randy, That joke isn't funny if you live in a city full of gun toting crackheads..........
    Mar 2011
    2,045
    If you're really bored, check these before / after gutting exhaust videos. Don't listen for a difference in volume or timbre--there isn't one. Instead, wait for the third rev (4,000 RPM), and note how the engine has to struggle less to breach the 3,000 RPM barrier.
    http://smg.photobucket.com/albums/v2...CIMG0016-1.mp4
    http://smg.photobucket.com/albums/v2...t=CIMG0017.mp4
    Conclusion: less backpressure = more linear throttle response.
    Aurora40's Avatar
    Aurora40 is offline Cadillac Owners Enthusiast
    Automobile(s): '06 CTS-V
    Mar 2004
    The Old Dominion
    41
    728
    I think there's definitely a sound difference after gutting the mufflers. It sounds the same when cruising, but has more growl when accelerating. It's not particularly loud, but certainly sounds more like a V8 than it did originally. I did not notice any difference in driveability or performance.
    It was easy enough to do, I'd certainly do it again.
  14. Remove Advertisements
