Engine Oil Cooler, External or in the radiator?
Results 1 to 9 of 9
2004-2007 Cadillac CTS-V Performance Mods Discussion, Engine Oil Cooler, External or in the radiator? in Cadillac CTS-V Series Forum - 2004 - 2007; Which is more efficient at dispersing heat? Internal cooler in the bottom of a Ron Davis radiator or external cooler ...
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Aug 2009
    Michigan
    576
    Which is more efficient at dispersing heat? Internal cooler in the bottom of a Ron Davis radiator or external cooler such as Mocal or Setrab?
    Application is track days on road course and the Hot Rod Power Tour (which has a lot of bumper to bumper crawling into or out of each venue)
    Appreciate all responses as I have the radiator out now.
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Re: Engine Oil Cooler, External or in the radiator?
    PM V-Sam on his Ron Davis for an opinion.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,217
    Quote Originally Posted by yooper View Post
    The answer is pretty much "it depends". An oil-to-water cooler is more efficient because water/coolant is a better heat transfer agent than air - that's why the typical oil-to-water cooler is significantly smaller than a comparably rated oil-to-air cooler.
    However, if you've got a cooling system that's already pushing the limits, then adding the additional heat load of an oil-to-water cooler may push it over the edge so that your coolant temps are too high. I'll be honest, I've never paid any attention to my coolant temps on track - I bounce between checking oil temp, oil pressure, and tire pressures - so I don't know how our cooling system performs. But with a big aftermarket radiator (whether it be Ron Davis or Fluidyne or someone else) + better air flow (you're going with a vented hood with all the body work you're having done, right?) you may have more than enough cooling capacity to use an oil-to-water cooler.
    Quote Originally Posted by crankedupforit
    Shouldn't be any need to PM him - he's posted before that he's had 3 Ron Davis radiators fail on him. I still find that very, very surprising based on the company's reputation, but that's been his experience.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    I have the Ron Davis with built in oil cooler. I don't have the cooler lines hooked up, but really don't see how there is any room to actually hook it up ever. The ABS? control module is in the way.
    cam3439 is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Nov 2010
    106
    Same problem here with the fittings for the oil cooler lines being directly in front of the ABS harness. I have emailed Bill at Ron Davis Radiators with detailed pictures and notes on the pictures. We will see what he says, but I asked multiple times if this was a direct fit that required no modification and he stated that it was.
    Aug 2007
    Arlington, VA
    31
    1,647
    ^Let me know what he says.
    smbstyle is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Jun 2010
    30
    181
    I am running a mocal oil cooler with a TPIS oil cooler adapter (I got rid of the Katech adapter b/c it was way too tall) and it works great. The entire setup wasnt too pricey either. definitely cheaper than a Ron Davis radiator! If I did it all over again I would probably use the Setrab cooler versus the Mocal cooler.
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Any success stories using engine oil cooler in any brand high flow radiator?
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by AAIIIC View Post
    As am I. Didn't want to report it second hand since I have no experience with it.
  12. Remove Advertisements
