Diagnosed a misfire to find my lifters were the issue
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V Performance Mods Discussion, Diagnosed a misfire to find my lifters were the issue in Cadillac CTS-V Series Forum - 2004 - 2007; Well, add another failure to the GMPP lifters. I had three out of 16 fail on me. Cylinder # 2 ...
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Well, add another failure to the GMPP lifters. I had three out of 16 fail on me. Cylinder # 2 & 3 were the ones giving the most misfires.
    We swapped the coils, wires, injectors, injector adaptors and sparkplugs but they continuously misfired. So i did a compression test and found the two cylinders had 1/2 the psi that they should have...
    Opened the valve cover and noticed some of the valves were stuck.
    Gonna take the heads off and check the cam for damage. Am looking for Morel 184-5206-HYD, and thunderracing is having a sale today for 10% off. However i am not in North america and will also need head gaskets, and new pushrods...
    Am i to take 0.050 off my length like others are sayin, or is it less than that with YT 1.7s?
    eagerly awaiting your replies
    Naf
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,164
    Re: Diagnosed a misfire to find my lifters were the issue
    Morels are the way to go. The change in pushrod length should be the same with any rocker as long as the current pushrod works with the existing rocker. The Morel lifters however, do have a narrower range of acceptable preload - just 0.030" to 0.050." The best solution is to install everything but the pushrods and then measure, even though that means more down time.
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,787
    What I found is that the Morels like to be adjusted where they are just off the keeper (so they don't beat themselves to death).
    Any farther then a 0.008" preload and I was throwing a check engine light (misfire code).
    Did you install a "high lift" cam?
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    OH SNAP!
    I have length checkers, but this dreaded preload is just horror to me...
    I have a GT1-1, with 631/631 lift...
    I am expecting a flood of emails from my guys today, but i have to wait six hours before it all starts
  7. Remove Advertisements
