CREATIVE STEEL: CTS-V 8.8 Rear Diff Swap BOLT IN - Page 6
Page 6 of 27 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 76 to 90 of 393
Like Tree37Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, CREATIVE STEEL: CTS-V 8.8 Rear Diff Swap BOLT IN in Cadillac CTS-V Series Forum - 2004 - 2007; i think the stock drive shaft is fine, especially with an adapter. It would be nice to know if the ...
  1. #76
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    Re: CREATIVE STEEL: CTS-V 8.8 Rear Diff Swap BOLT IN
    It would be nice to know if the strength is there in a 28 spline axle. Better yet use the t-bird inner cv's and caddy outers (strength again?)
    if we could get the entire kit down to the brackets, a driveshaft adapter, and the axle shafts themselves+ plus a cheap used t-bird diff and inner Cv's, this might be the best budget solution available.
    I think you have a great product here, it would be nice to just see the second layer of it, the real budget solution, to go with the upgraded 31 spline version.
    I know it may not be said enough, but thanks for making another option
  2. #77
    MIAdragon is offline Cadillac Owners Fanatic
    Automobile(s): none (yet)
    Jan 2010
    Miami
    112
    <----- Have a test car right here.
  3. #78
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by MIAdragon View Post
    I wish. Max owns a V!
  5. #79
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    I'm reluctant to spend a dime adapting to a driveshaft that has the failure rate and unservicablility of the stock unit, but when the bucks are down, it could make sense.
    A one piece driveshaft would make a great option and one a lot of us will need at some point.
    either way, I'm glad to see there are finally good options....
  6. #80
    jpoole's Avatar
    jpoole is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Cadillac CTS-V
    May 2007
    McKinney, Texas
    266
    This looks to be an ideal solution and I am interested in buying the kit to install my own 8.8 and will be using a true trac in it. Especially if it will fix some of that clunking... I recently installed a TrueTrac with motive gears in my pickup and it is very quiet & smooth.
    There have been a couple of posts here on gear oil. Thing is on a True Trac, they don't need friction modifier as they use sliding helical gear to provide power to the tires. This means a few things, there are not any wear parts like a LSD, provides a mechanical locking of the wheels and no need for the FM like in a LSD type differentials. Also, Eaton recommends using a quality petroleum/mineral based oil and state they don't recommend synthetic with a TrueTrac.
  7. #81
    CI-V-IL is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Raven Black CTS-V
    Dec 2010
    Fishers, IN
    135
    Max, are you still here?
    So it sounds like the kit comes with the 8.8 brackets and driveshaft adapter, correct? If we want to piecemeal a kit, we will just need to have custom axles made and supply the 8.8. Does that sound correct?
  8. #82
    2007V is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V, maggie
    Apr 2011
    85
    hey just an fyi guys, I have a tbird sc (with a twinscrew) and this 8.8 in it and have followed those forums for years. It is pretty rare that someone would break one, and if they did it would almost always be an AL case. There are a handful of guys in the 10's and a few in the 9's. But mostly or all automatics at that level, which would help soften the initial hit. The SC halfshafts break pretty regular though, I wouldn't recommend those.
    It's pretty easy for an SC to make 400 ft-lbs, but pretty hard to put 400hp to the wheels.
  9. #83
    RADARB8's Avatar
    RADARB8 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V TURBOCHARGED
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Quote Originally Posted by 2007V View Post
    Hey 2007V....what is an sc,,and twin screw, and an al case... just trying to get the info. but too many initials lol thanks big Greg O.
  10. #84
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
  11. #85
    Jun 2010
    Arizona
    407
    Figures there would be some SC fans here too... My dad had one when i was growing up, and is part of the reason I have a 96 t-bird in my garage too.
  12. #86
    RADARB8's Avatar
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Thanks Liquidvenom.. [Twin screw] is the supercharger
    [sc] is for sport coupe
    and [al] must mean aluminum
  13. #87
    InfrareV is offline Cadillac Owners Member
    Automobile(s): '06 CTS-V
    Feb 2011
    31
    89
    Close, it was Super Coupe.
  14. #88
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    Max sir, where are those brackets.
  15. #89
    Dec 2010
    Fishers, IN
    135
    Did this die? Definitely sparked my interest, but haven't seen a response for a while.
  16. #90
    Feb 2009
    Greenville sc
    45
    992
    bump..............
  17. Remove Advertisements
