CREATIVE STEEL: CTS-V 8.8 Rear Diff Swap BOLT IN - Page 14
Page 14 of 27 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 196 to 210 of 393
Like Tree37Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, CREATIVE STEEL: CTS-V 8.8 Rear Diff Swap BOLT IN in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by ichpen I'd be very interested in what you used to build your 8.8. I'm looking at this ...
  1. #196
    GeoffreySather is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-v
    Jan 2010
    33
    15
    Re: CREATIVE STEEL: CTS-V 8.8 Rear Diff Swap BOLT IN
    Quote Originally Posted by ichpen View Post
    I'd be very interested in what you used to build your 8.8. I'm looking at this myself and leaning toward a wavetrack diff. Just completely lost when it comes to the rear.
    I used the Ford Racing M-4204-F318 carrier (Limited slip with carbon fiber clutches, 31 spline), the Ford Racing M-4209-88373 gears (3.73) and Koyo bearings.
    I pulled the diff from a 1995 Cougar and ended up with the rear cover from the CS kit.
  2. #197
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    Quote Originally Posted by GeoffreySather View Post
    thanks for the pt# im trying to spec out if its worth sourcing my own iron diff for the swap or just buying it from CS.. how much did you end up spending?
    Any in car vids of you rowing through the gears? 75% of the reason i want a new rear is to get rid of the clunking drivetain.. I mean almost every shift from 1-2-3-4 will produce some pinnion lash.i know i could go aftermarket but seems to me that hard aftermarket a dif bushing make the this cts diff go pop...
  3. #198
    Jan 2010
    33
    15
    Oh, and I had to replace the plate that the driveline connects to, the cougars was a smaller one.
    I have an Excel sheet I made with all the costs at home, I'll get back to you on the exact price of the diff.
    But my guess is between $700 to $850 on the diff with parts and labor.
    Closer to $700 though cause I bought two sets of gears and I had to buy another rear cover.
    shadybx7 and shadybx7 like this.
  5. #199
    a12ozbottle is offline Cadillac Owners Member
    Automobile(s): 2004 cts v
    Feb 2011
    Jacksonville, FL
    39
    6
    Ordered mine...worried about the diff cover now. Have an aluminum housing with the HD cover.
    How much did you spend on hardware, bolts...etc?
  6. #200
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    I'd be interested in the spreadsheet, I can put it up for all to see if you have issues sharing it. Congrats on figuring out a viable budget diff options btw, much appreciate the info.
  7. #201
    Jan 2010
    33
    15
    Okay I lied, it would've been about $839 assembled without a new flange...
    Rusty Ol' Ford 8.8" $106
    Carrier $219
    Gears and bearings $235
    Diff Assembly $135
    Por-15 and paint $51
    Rear cover weld $32
    Bolts nuts and washers $6
    Diff bushings $33
    Ford Racing Gears(2nd set) $140
    New Rear cover $100
    I do not know the cost of the flange as it was included in the install price.....
    Total cost for me $1,057
    As you can see some of the costs were not necessary, so hopefully this can save you guys some money.
    But shit I could rebuild this thing for $500, lot's better than a $1700 stock replacement
  8. #202
    ichpen's Avatar
    May 2008
    1,383
    Thanks for that.
    Rusty TBird 8.8 in the basement.... ermmm, ok, let's see if we can get a wavetrac in there. Maybe I should just call Max at this point.
  9. #203
    wcryan is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS-V Maggied
    Aug 2009
    Escondido, CA
    28
    1,065
    wavetrac? I keep hearing these different terms with these diff's. What do they all mean?
  10. #204
    ichpen's Avatar
    May 2008
    1,383
    Quote Originally Posted by wcryan View Post
    No kidding, I'm still edumicating myself on this.
    Here's a writeup. http://www.wavetrac.net/technical.htm.
    Basically from what I gather it's the cream of the crop of carriers. It's torque biasing with with 'wave' profile gears that come into play at zero torque conditions.
    In reality from what I hear, it's good for exit speeds or the transition from decel to accel which in more traditional diffs i.e. truetrac has a delay.
    It's very popular with the M3 crowd (their boards are lit up with people doing a swap).
    Down side is it costs an arm and a leg. Twice the cost of a posi/truetrac at least. Is it really needed for us? Probably not. Do I want it? Yep.
  11. #205
    shadybx7's Avatar
    Apr 2008
    3,014
    iron seems like the way to go.. the New ATS has a Iron pumpkin, different sized axles, and dual front diff mounts.. im glad somthing good came of this V1 experiment that doesnt cost 60k new
    this is what i have been reading:
    https://www.brutespeed.com/rear_end_information.htm
  12. #206
    ichpen's Avatar
    May 2008
    1,383
    Good article except wavetrac is no only available for 9", you can get it in 31 and 33 spline 8.8s from Moser.
  13. #207
    Jan 2010
    33
    15
    Yeah...... you're nuts....
  14. #208
    Aug 2009
    Escondido, CA
    28
    1,065
    so if you buy an 8.8 kit and put a cobra rear end in it, it wont be posi? Sorry if thats a dumb question. I'm just a little confused
  15. #209
    ichpen's Avatar
    May 2008
    1,383
    From loose understanding the Cobra's came with posi from the factory. I'd say whatever you buy you should spend the time to rebuild it or freshen it up as clutch packs tend to wear out on the posi units.
  16. #210
    soulja's Avatar
    soulja is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V Sedan 6MT, (Sold) 05 Maggie & 8.8 V1.
    Sep 2009
    Belleville, Mi.
    39
    509
    I am really interested in this conversion. I have read through the thread. Just to be clear, the 8.8 differential is either from the older Thunderbirds or older Mustang Cobras?
  17. Remove Advertisements
