Page 8 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 106 to 120 of 244
Thread: V2 rotor/caliper retrofit for V1 cars
  1. #106
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Re: V2 rotor/caliper retrofit for V1 cars
    Pretty kickass, yooper!
  2. #107
    catch2otwo is offline Cadillac Owners Fanatic
    Automobile(s): CTS_V
    Mar 2011
    SF Bay
    144
    This has jumped up from the dream list to the reality list. Great work documenting your work. Its kick ass that they fit behind the stock hoops. So that ball park figure I think I read was 2600? for everything?
  3. #108
    9t8z28's Avatar
    9t8z28 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Jul 2011
    36
    116
    Are our brakes not that good? I am really impressed with them, but I can't say too much since I have never tracked the car.
  4. #109
    zzilla is offline Cadillac Owners Fanatic
    Automobile(s): cts v-xlr v
    Jan 2009
    158
    Yes they are that good the "OEM "calipers .But like in all motorsports / modifications/show cars/ race cars there is always that edge to make it better.
    "GROUP BUY" on these rotors comming very very soon stay tuned I just need to get one more piece of info.
    My rotors are the floating version but it looks like I will not be able to test track these untill after "SEMA"
  5. #110
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by 9t8z28 View Post
    I was always happy with my '04's braking. But my '09 V brakes better with 4200lbs than my '04 did with 3850. The V2 brakes are Herculean!. It's a pretty easy swap, so those looking for more need not go far.
    And, remember, it's cheaper to gain 50-100ft in braking zones than it is on the straights...
  6. #111
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    Quote Originally Posted by thebigjimsho View Post
    Da TRUTH
  7. #112
    Aurora40's Avatar
    Aurora40 is offline Cadillac Owners Enthusiast
    Automobile(s): '06 CTS-V
    Mar 2004
    The Old Dominion
    42
    728
    Quote Originally Posted by yooper View Post
    They fit and they work, and boy do they work! After proper bedding in of the rotors, we did a few comparison panic stops from 80 and 100 against an 08 Corvette convertable with the stability control turned off. (Hope my wife doesn't read this-her car)
    The V was equiped with Bridgstone RE-11 tires in OEM size, PerformanceAFX 2pc fixed mount rotors, V2 calipers loaded with Cobalt Racing XR1 pads, while the Vette had OEM run craps and OEM brakes. The V consistently stopped in a little over half the distance of the Vette, even after switching drivers. I know, we should have used a Z06.
    Isn't this more a testament to the tires? The stock brakes on a C6 should be more than enough to engage ABS, especially with the crap GY GS:2 OEM tires. More brakes will not help past that point (except in fade resistance). I suspect the stock V1 brakes were more than enough to engage ABS on the RE-11's as well (though I've never used that tire).
    A more interesting test would have been to measure the stopping distance of the V before and after. It would show whether the brake bias had been improved or worsened. Though having more fade resistance vs more ideal brake bias is probably a fair trade-off on a road course. On a street-driven car, in a panic stop, not so much.
    That said, they look great and it's great to have this option available.
  8. #113
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Aug 2009
    Michigan
    576
    Actually I did measure the before and after and nothing was lost. I prefer to get some track time on this set up and then give a full report. After the first weekend in October we will know "the rest of the story".
    Aurora40 all good points.
    Quote Originally Posted by Aurora40 View Post
  9. #114
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Same project, different angle for those who prefer 5 lug wheels. Bob can give you whatever bolt pattern you wish. 5 x 120=CTSV2 & 5th gen Camaro options
    5 x 4.75=just about anything else.............
  10. #115
    Sigfod's Avatar
    Sigfod is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Oct 2010
    Sterling, VA
    169
    Just for a recap. The V2 calipers bolt up where the stock V1 calipers were with no adapter needed? Also these calipers will fit behind stock wheels?
  11. #116
    Aurora40's Avatar
    Mar 2004
    The Old Dominion
    42
    728
    Cool, thanks for the info. And I look forward to hearing how they do on the track.
  12. #117
    Junior1's Avatar
    Jun 2008
    1,248
    Quote Originally Posted by Sigfod View Post
    Yes as per yooper: The 12mm V1 steering knuckle caliper mounting bolt holes need to drilled out to 14mm to accept the V2 caliper mounting bolts. Once drilled this is a bolt-on upgrade
  13. #118
    lilgCTS-V is offline Cadillac Owners Enthusiast
    Automobile(s): 06CTS-V BOLT-ON,06JEEP TJ BUILT, 91 350SDL turbo(daily)
    Nov 2008
    967
    can you keep stock rotors?
  14. #119
    Jan 2009
    158
    Quote Originally Posted by lilgCTS-V View Post
    No
    The group buy will start tomorrow for these rotors and stay tuned for all the info and pricing
  15. #120
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Apr 2008
    2,061
    I wonder if V1 can attain sub-100 ft braking from 60mph with these?
    Not really relevant from a purchasing perspective but would be a cool fact considering the benchmarks out there...
  • You may not post replies
