V2 rotor/caliper retrofit for V1 cars - Page 16
Page 16 of 17 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 226 to 240 of 244
Like Tree24Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, V2 rotor/caliper retrofit for V1 cars in Cadillac CTS-V Series Forum - 2004 - 2007; Well, here's the thing that I don't understand. Apparently, many have been installing the V2 calipers with Z06 14" rotors ...
  1. #226
    DMM's Avatar
    DMM
    DMM is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2010
    Maryland
    40
    389
    Re: V2 rotor/caliper retrofit for V1 cars
    Well, here's the thing that I don't understand. Apparently, many have been installing the V2 calipers with Z06 14" rotors on F-body's, with the Z06 rotors the exact same dimensions as our OE rotors, only 5 lug. Here is an article where Scoggin-Dickey provided the parts combination of V2 calipers and C6 Z06 rotors:
    http://www.gmhightechperformance.com...s/viewall.html
    Are you absolutely sure installing the V2 calipers on the OE 14" rotors is impossible?
  2. #227
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    29
    979
    Quote Originally Posted by DMM View Post
    I'm assuming the offset of the caliper relative to the rotor due to the mounting holes causes insufficient overlap of pad and rotor. That is just a guess, so until someone tries it that's just speculation.
    AAIIC maybe you could test this out?
  3. #228
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,150
    Oh, sure, play on my incurable desire to figure this sort of thing out, even when I should be something productive like replacing my alternator. Fortunately for you I have one corner of the car already jacked up, the wheel off, and a couple sets of V1 rotors sitting here to play with.
    V2 caliper on V2 rotor. Pad material rides maybe 0.5mm inside the outer edge of the rotor:
    V2 caliper on V1 rotor. I didn't measure it at all, but the pad material overhangs the outer edge of the rotor by ~1/4". That makes sense, as the V1 rotors are 355mm and the V2 rotors are 370mm.
    Closer view (albeit a little blurry):
    Inside diameter matches up just fine:
    I may have to experiment with this next track season. I think that, for my purposes, the greater thermal mass of the V2 rotor is key to getting the better braking performance that I want on track. However, I'm curious if the larger pad area, which spreads the heat load a bit, would be enough to help the brakes survive the abuse I subject them to.
    It's worth noting that there's not a whole lot of selection in pads for the V2 caliper as of yet, and what is out there is substantially more expensive than the V1 pads (which are common to STIs, Evos, 350Zs, S197 Mustangs, etc etc). Not using a chunk of those expensive pads is kind of a shame, but obviously using the V1 rotors does make life easier.
    Edit: I just sent an email to Centric via their "Contact Us" page.
    Quote Originally Posted by me
    I noticed the other day that you are now offering front rotors for the 2nd generation ('09+) CTS-V (aka "V2"), part number 120.62128. That's fantastic news, as the OEM rotors are very expensive.
    A number of folks, myself included, have installed the V2's 6-piston calipers and the larger rotors on our '04-07 1st generation CTS-Vs (aka "V1"). The biggest hurdle to doing this is figuring out the rotors, as the V1 uses a larger center bore and has a funky 6x115mm bolt pattern vice the 5x120mm pattern on the V2. I had a machine shop enlarge the center bore of a pair of OEM V2 rotors, and then re-drilled the hub bolt pattern by hand - definitely not the preferred solution!
    I wonder if it would be possible to produce a version of the 120.62128 rotor using the center bore and hub bolt pattern from the V1's 125.62075 rotors. No other changes to the design would be necessary; I am currently using those modified OEM V2 rotors on my V1 using the V1 front knuckles and V1 wheel bearing/hub assemblies. Everything lines up perfectly.
    I realize that this is probably not an application your company would normally produce, but I figured it could not hurt to ask. I think a significant number of V1 owners would undertake the V2 rotor/caliper upgrade if an affordable rotor solution was available.
    Thank you for your time!
  4. #229
    Mar 2010
    San Jose, CA
    29
    979
    This is great information. I wonder if there is still benefit running the v2 calipers and v1 rotors.
  5. #230
    DMM's Avatar
    DMM
    Jan 2010
    Maryland
    40
    389
    Thank you for taking the time to go through and document this, really, thank you! Before seeing this, I was contemplating getting the V2 calipers to use on the V1 rotors as in the thread that I posted. I am surprised that SD would suggest this parts combination when they clearly do not match up, especially when SD has such a stellar reputation.
    Good idea asking about the V2 rotor, however, it may be easier to ask for them to produce blanks rather than have them drilled for a specific application. There would be sufficient demand, especially since the V2 calipers are being installed across platforms as indicated in the GM High Performance thread that I linked. You could even point them to this thread in an attempt to catch their attention. I believe the only platform the V2 shares the wheel bolt pattern with is the G8.
    Thanks again!
    Following AAIIIC's lead, I sent Centric an email as well. I figure the more of us that do will only show there is sufficient demand for such a thing.
    I have noticed that you now offer the 2009+ Cadillac CTS-V front rotors. While you may or may not be interested in this, I would like to ask if it would be possible to purchase these rotors without the center eccentric or wheel bolt pattern machined in the hat of the rotor for aftermarket use.
    The V2 (the designation for the 2009+ CTS-V) front rotors are quite popular across many GM platforms due to their six piston calipers and relatively low price (around $350 each). However, the V2 rotors have a somewhat unique bolt pattern which forces many to use the smaller 14" diameter 2006+ (C6) Z06 front rotors.
    I personally have a 2004 Cadillac CTS-V (a V1) and would like to upgrade to the V2 rotors as well. However, the V1 front rotors are the smaller 14" diameter as well.
    To show you there is sufficient market for a rotor blank, I have a included a V1 to V2 caliper upgrade thread from a board (of which there are many) that has grown to 16 pages and been viewed almost 15,ooo times:
    http://www.cadillacforums.com/forums...t-v1-cars.html
    Here is a magazine article from GM High Performance where they installed teh V2 calipers with 2006+ Z06 rotors on a 2000 F-Body Camaro:
    If you were to make this a reality to the market, i'm sure that you quickly realize the market potential.
    Thank you for your time and consideration.
  6. #231
    AAIIIC's Avatar
    Aug 2007
    6,150
    Quote Originally Posted by AAIIIC View Post
    - I've verified that the 18x8.5" Rota Torques will clear these brakes. The Rotas are currently my cool weather setup w/all-seasons on 'em, and I put them on the car this week.
    BLAM!
    The picture makes it look like clearance to the barrel of the wheel is tighter than it actually is. There's a bit of lip at the back of the spokes, then it drops a bit to the actual barrel, so there's plenty of clearance (even with balancing weights near the backs of the spokes). Clearance from the back of the spokes to the face of the caliper is huge.
    On another note, at the Cadillac V-Series Driving Lab at Circuit of the Americas in early December, they had a Brembo engineer dude there to tell us about how awesome the Brembos are, etc etc. My particular group of participants was mostly full of enthusiast types, which the Brembo guy recognized - "I see a number of personal helmets in the group here..." Instead of just giving us his standard spiel, he opened the floor to questions so we have a more technically oriented discussion. Afterwards, I approached him and asked about getting V2 rotors made with the V1 hub bore and bolt pattern. He said it might be possible to do a batch that way if there was interest, since the aluminum center hat is initially solid and then the bolt pattern and hub bore are machined in. I still need to follow up on our discussion - he told me to contact Brembo USA and give his name as a reference. I'll post up if anything comes of that.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  7. #232
    DMM's Avatar
    DMM
    Jan 2010
    Maryland
    40
    389
    I'd likely be in. Do the V2 calipers clear the OE V1 wheels? Sure it was covered somewhere in the 16 pages...wanted instant gratification
  8. #233
    Mar 2010
    San Jose, CA
    29
    979
    Interested and yes v2 calipers clear v1 oem wheels.
  9. #234
    Sigfod's Avatar
    Sigfod is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Oct 2010
    Sterling, VA
    169
    BLAM!
    Interested in these rotors
  10. #235
    AAIIIC's Avatar
    Aug 2007
    6,150
    A few random notes:
    (1) First, an install note that I don't think I covered previously. I know it has been mentioned that the V2 uses larger diameter caliper mounting bolts (14mm vs 12mm). The V2 bolts are actually a bit too long (in other words, the V1 knuckle isn't quite as thick as the V2 knuckle where the caliper bolts up). As a result, the OEM bolts will actually touch the back of the center hat section of the OEM V2 rotors. I initially shaved the bolts down a few millimeters, but that resulted in some ugly threads on the end, so they didn't thread into the calipers by hand very cleanly. I have a thread chaser set, but the only 14mm chaser is the wrong pitch, so I couldn't clean up the threads as I would've like. So, I went to Fastenal and bought 4 grade 10.9 (same as the OEM bolts) 14mm-2.0 x 45mm bolts. (The stock ones were ~49 or 50mm long.) They work perfectly; you could just go straight to that option rather than ordering the OEM V2 bolts. I suppose the other option would be some thick 14mm washers under the head of the V2 bolts - I'm sure there's a reason I didn't go that route, but I can't remember it now.
    (2) I finally got to do a full track event with the V2 setup and I came away very happy that I went through all this effort. I don't have any objective data to refer to, but the brakes felt great and I never once felt I needed to take it easy for a bit to let the brakes recover. When I still had the V1 setup, the lead instructor at one of the events asked me about the brakes and how they did with such a heavy car. I told him that with my Subaru [normally aspirated, thus slow, and obviously much lighter than the V], I can go deep into a braking zone and even though I'm braking very hard, there's still more there. If the guy ahead of me slows down more than I expected him to, I still have braking power left in reserve. But with the V, I always felt like I was using all the braking capacity I had, and it just wasn't as confidence inspiring. Obviously, others find the V1 brakes to be more than enough, but that's how they felt for me on track.
    With the V2 brakes, I feel as though I have that reserve now. Going into turn 1 at VIR (upper 130s down to ~45mph) I was able to take some late point-bys, take the inside line, and comfortably haul the car down.
    (3) I'm out in the garage putting the street rotors & pads back on and figured I'd post up some weights:
    OEM V2 rotors - 25#
    Racing Brake 2-piece V2 rotors - 23#
    (4) I'm still curious about what rotor options are out there. As I've previously mentioned, Centric now offers a rotor for the V2 - #120.62128. I haven't found an actual picture of one yet, but on RockAuto.com it says it's co-cast (like the OEM rotors), and the weight is about the same as I just measured for my OEM rotor. (If the Centric part was not co-cast, I would expect it to be quite a bit heavier since the center hat would be cast iron rather than aluminum.)
    Rockauto.com also has two different varieties of ACDelco front rotors - 1-piece #1771105 (co-cast rotor, corresponds to GM part #25851237), and 2-piece #1771145/1156 (corresponds to GM part #20795300/302). The 2-piece rotors are "only" $297 on rockauto.com, which is pretty damn good. I'm curious if the rotor rings are intended to be serviceable, or if they're basically "throw away" 2-piece rotors. I've done a bit of searching around today but haven't found any info on that yet. If they are replaceable they would be a helluva lot better deal than the RB option!
  11. #236
    Mar 2010
    San Jose, CA
    29
    979
    Have you driven on the V2 caliper+V1 rotor combo yet? I'm very interested in this setup as an interim to buying the full up RB 2 piece rotors
  12. #237
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Glad this got bumped up today as I just opened up the box with my nice new shiny V2 calipers. I haven't decided which route to go yet with the rotors.
  13. #238
    AAIIIC's Avatar
    Aug 2007
    6,150
    A guy over on cadillacowners.com says Brembo does not offer replacement rings. I would think a V2 owner or ZL1 owner would've figured out how to source replacements through Coleman or TCE or someone like that, but I haven't seen any sign of that in searching around.
    Quote Originally Posted by OneFast V View Post
    Although I said earlier that I might give that a shot, I don't think I'll get around to it. As expensive as the V2 track pads are, it seems kind of foolish to not get full use out of them. I suppose I could try it with my street pads - if it ruins them, I won't be all that upset, as I'm not too impressed by them.
  14. #239
    AAIIIC's Avatar
    Aug 2007
    6,150
    Random update:
    When I installed the V2 stuff, I didn't find much in the way of street pad selection for the V2 pads. I ended up going with Hawk HPS. They've been OK, but hardly anything to write home to Mom about. And even a single stop from high speed (quick blast on the highway or something like that) was enough to make them give up the ghost. I was getting increasingly unimpressed by the HPSs, so I decided to look into other options.
    Looking at options on rockauto.com I discovered that GM actually offers two sets of pads for the V2. There's the OE Brembo pads, PN 25940447, which have a ~$450 MSRP, but there's also PN 19288002. MSRP on that pad is only ~$70, and you can get them online for about 2/3 of that. (I got them from rockauto.com as AC Delco 17D1405M (Durastop Professional semi-metallic). For that minimal outlay (less than 1/3 what the Hawk pads cost!), I figured it couldn't hurt to try them out. I'm glad I did. Their performance is worlds better than the HPSs. Still no noise (which was also true of the HPSs), but much, much better initial bite, overall stopping power, and they seem to be able to take a little heat. The only unknown is dust - the HPSs were very non-dusty, which was one good thing about them. Before I installed these pads I had already switched over to my "hyperblack" Rota winter wheels, so it's hard to tell how dusty the AC Delco pads are.
    I also picked up a set of Raybestos PGD1405M Professional Grade semi-metallics. They were shown on rockauto.com as a "Wholesaler Closeout", and came in NAPA packaging. I imagine I'll keep the AC Delcos on for now, and maybe try the Raybestos pads in a few months, just to compare. Again, for $25 I figured it couldn't hurt to see how good/bad they are.
  15. #240
    Mar 2010
    San Jose, CA
    29
    979
    any clues on where you found them for $25?
  16. Remove Advertisements
