Page 12 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 166 to 180 of 244
Thread: V2 rotor/caliper retrofit for V1 cars
  1. #166
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Re: V2 rotor/caliper retrofit for V1 cars
    Really? I find the stock pads in the V2 to be lacking a bit.
  2. #167
    lunarx's Avatar
    lunarx is offline Cadillac Owners Connoisseur
    Automobile(s): 12 CTS Coupe Premium/Touring, 16 Volt, 13 911s, 07 Legacy GT Wagon
    Aug 2006
    SoCal
    1,739
    Lacking?
    Compared to what and for what use?
    I feel that for a 100% streetable pad they hold their own fairly well on track.
    What would you run if you could only run 1 pad (on a V2) for everything?
    (not our case but a good question to put the goodness of factory pads in perspective)
  3. #168
    soflarick's Avatar
    soflarick is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Sep 2009
    Florida
    626
    I chose to stick with RB pads ET500 and ET800, so I won't have to worry about conflicting pad compounds. There may be "better" track pads out there, but I'm on street tires and still driving novice. ET500s on the street, then swap to the 800s for events. Haven't driven on the 800s yet.
  4. #169
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    I had a set of ET500 or ET800 and i managed to destroy a set at my last track day. Ive always been a big RB fan but those pads failed me on the track.
  5. #170
    Automobile(s): ZIP
    51,885
    I felt the stock pads to be a bit soft under hard braking. They left a soft pedal and stopping distances seemed a bit longer than when running Hawks. I run Hawk DTC-30 pads for the street and auto-x. I've run it on the track and it works very well. But someone said if you get them too hot, the pads effectiveness falls off. I didn't see that at Summit Point so I doubt you'd ever see that on the street.
    But the DTC-30 has excellent bite, even when cold, and gives good feedback. I've run them the past 2 summers(April to November) and still have them on now. And the stopping distances are noticeably better than stock...
    ---------- Post added at 06:41 PM ---------- Previous post was at 06:40 PM ----------
    I then run Hawk DTC-70 for the front pads, DTC-60 for the rear when on the track now...
  6. #171
    lunarx's Avatar
    Aug 2006
    SoCal
    1,739
    Can't fault a guy for running DTC-30 on the street.
    No argument on those performing better than the stock pads.
    How is rotor wear and squeeking in street use?
    Also, can you get DTC-30 for the rear calipers?
    ---------- Post added 12-08-11 at 12:10 AM ---------- Previous post was 12-07-11 at 11:56 PM ----------
    Quote Originally Posted by liqidvenom View Post
    Which ones died at the track, ET-500 or ET-800?
    There is a big price difference between those 2 pads.
    I would not be a bit surprized if the ET-500's died.
    However, if you stepped up for the much more expensive ET-800's and they let you down, that would be interesting news.
  7. #172
    Aurora40's Avatar
    Aurora40 is offline Cadillac Owners Enthusiast
    Automobile(s): '06 CTS-V
    Mar 2004
    The Old Dominion
    42
    728
    Quote Originally Posted by thebigjimsho View Post
    You couldn't lock the brakes up with the stock pads?
  8. #173
    soflarick's Avatar
    Automobile(s): none
    Sep 2009
    Florida
    626
    Destroy a set of which? On which side of the car? Based on the user comments elsewhere, the 800s are not full track pads, but an excellent performing track/street pad. The 500s are not a track pad. RB and user comments both confirm this. RB told me the 800s work well as an HPDE/OT pad on street tires, but they will not survive with a more experienced driver and/or track tires.
  9. #174
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by Aurora40 View Post
    I found it difficult to induce ABS with the stock pads. A bit easier to do with the DTC-30s. But with the big Michelins(and now Kumhos) on the V2, it's not like I'm locking them up on every hard braking zone...
    ---------- Post added at 09:19 PM ---------- Previous post was at 09:13 PM ----------
    Quote Originally Posted by lunarx View Post
    I'm at 35k miles running DTC-30s for all but about 10k of those miles. Still on stock rotors although I noticed tiny cracks in the center of my front rotors. Don't really know what directly to attribute that to being that I've tracked it with track pads, but at least I know they won't kill the rotors overnight.
    Squealing, yeah it's there. Which is annoying because my DTC-70s and DTC-60s have an embedded backing surface which results in little to no squeal. The DTC-30s that I have don't. Although, my DTC-30s were bought very early as Hawk was rushing to get the pads out for the V2 application. The pad sizes existed before, but the depths were wrong. I believe the GT-R pads had more pad material than ours do. So maybe DTC-30s available now have that backing on it.
    Dust is also heavier but it's not out of control if you drive normally. Get on them and they'll dust like a track pad should...
  10. #175
    lunarx's Avatar
    Aug 2006
    SoCal
    1,739
    You might have me convinced to try DTC-30 as an all-around pad, if offered in an embedded backing surface version.
    I didn't see DTC-30 listed for the rear calipers (on the Hawk website).
    They would not crack your rotors with street use just grind them down.
    If you got 30K on your rotors, then no worries.
  11. #176
    Automobile(s): ZIP
    51,885
    I get my pads from these guys...
    http://bigbrakeparts.net/searchResul...0Series%20Only
  12. #177
    soflarick's Avatar
    Automobile(s): none
    Sep 2009
    Florida
    626
    That is an informative site. I've used raceshopper in the past. Their prices are extremely competitive, and they have good knowledge of pads and pad materials.
  13. #178
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by soflarick View Post
    They're local to me, too, so that's nice...
  14. #179
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,461
    Quote Originally Posted by CadzillaTN View Post
    Someone order the yellow ones!
    Almost a year later, I'm finally moving that way. I picked up a pair of yellow rear calipers from Luke @ Lindsay today to see if they were the same as the V1 rear calipers (other than the color, of course). As far as I can tell, they are.
    A while back in another brake thread, lunarx said he had been told the silver V2 rear calipers were a different part number than the silver V1 rear calipers. I was pretty sure the rotors were the same (other than the bolt pattern), and the caliper body was the same, but there could have been some other changes (mounting bolt spacing, mounting bolt diameter, etc). That made me worry that if the silver ones weren't the same, then my plan of going with the yellow ones wouldn't work out, unless I went through the added trouble of sending my stock rear calipers off to be powdercoated to match the yellow fronts.
    Turns out, that isn't necessary - the V2 calipers appear to be the same, and bolt up just fine. I have one side already installed and will do the other side later. I'll also go ahead and get the fronts, too, now that I know the yellow will work out OK.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  15. #180
    Automobile(s): ZIP
    51,885
    Poast em up, pics!
  • You may not post replies
