Page 11 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 151 to 165 of 244
Thread: V2 rotor/caliper retrofit for V1 cars
  1. #151
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    Re: V2 rotor/caliper retrofit for V1 cars
    I'm jealous...
    Can't wait for my setup from Bob
  2. #152
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    how did you warp your rotors?
  3. #153
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by liqidvenom View Post
    They got too skinny. I should have replaced the rings about three track days ago. I corded my GACs so I ran Sunday on my Yoko AD08s which put even more stress on the rotors. All in all the UUC rotors are serving me well.
  4. #154
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Aug 2009
    Michigan
    576
    Quote Originally Posted by Junior1 View Post
    I'm jealous...
    I am jealous of Cranked's Katech power. Man does that thing pull up hill in 4th gear.
  5. #155
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Mission accomplished: The V2 OEM 6 piston Brembo caliper upgrade to V1 is a done deal. Good to go!
    Detailed update tomorrow on the PerformanceAfx 2pc rotors and Cobalt Racing XR1 pads for this conversion.
  6. #156
    yooper's Avatar
    Aug 2009
    Michigan
    576
    See PerformanceAFX thread for update on the 15" 2pc rotors for this conversion.
  7. #157
    yooper's Avatar
    Aug 2009
    Michigan
    576
    More track action at a buck twenty.
  8. #158
    Sigfod's Avatar
    Sigfod is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Oct 2010
    Sterling, VA
    169
    Quote Originally Posted by yooper View Post
    Do you have a link to this thread?
  9. #159
    hXc95SLS's Avatar
    hXc95SLS is offline Cadillac Owners Enthusiast
    Automobile(s): 1992 Dodge Dakota DD, 2005 CTS-V Black on Black
    Apr 2008
    Toms River, NJ
    28
    573
    Hey yooper, that brake ducting you made, is it just welded to the backing place of the rotor? Also where did you route it to cause I'm interested in doing that.
  10. #160
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Quote Originally Posted by hXc95SLS View Post
    I made them from .063 alum that was laying around. They go between the steering knuckle and hub bearing in place of the light metal heat shield that the ABS harness attached to. Attach 3" hose and route to pickup location of your choice. I pulled the 3 screws out that secure the turn signal running light assembly and replaced with homemade inlet assembly.
    Working on another version leaving the light assembly in and using the factory inlet. Version 2 will be more user friendly, looking for strong material that is the same thickness as the OEM heatshield, for street driving just stuff a nurf ball in the inlet and pull the ball out when you get to the track. Should have product available after the first of the year.
  11. #161
    lunarx's Avatar
    lunarx is online now Cadillac Owners Connoisseur
    Automobile(s): 12 CTS Coupe Premium/Touring, 16 Volt, 13 911s, 07 Legacy GT Wagon
    Aug 2006
    SoCal
    1,739
    Thought you guys might want to see what the Racing Brake Rotors looked like.
    I picked them up in person and the Racing Brake guy Warren is very dedicated.
    He is working on Stainless Steel piston replacements for our 6 Pot Calipers.
    Something to note is that the hardness on these rotors is much higher than most.
    He tests each rotor on a Rockwell machine before shipping.
    Therefore not all pad compounds are suitable.
    Ceramic compounds should be avoided (Carbotech for instance).
    He does sell Hawk and his own Racing Brake Brand of pads, so those are tested and known to work well.
  12. #162
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Looks good. Can you post a close up side view shot showing the cooling vents? How thick are the actual rotor plates?
  13. #163
    soflarick's Avatar
    soflarick is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Sep 2009
    Florida
    626
    You have time to tinker with them? Interested in weight comparison. You select RB pads?
  14. #164
    lunarx's Avatar
    Aug 2006
    SoCal
    1,739
    Hi Guys,
    Sorry this took so long.
    I gave my camera away and did not get a new one yet.
    Had to make due with a camera phone shot.
    The Front Rotor Plates are 5/16" Thick.
    The Rear Rotor Plates are 1/4" Thick.
    I also gave my scale away so I can't weigh these untill I get one.
    I don't doubt the weights on the Racing Brake Site but I sure do want to verify them.
    I will most likely run Factory Pads.
    I was impressed with the track performance of the factory pads on 6-pot calipers at the Cadillac V Series Performance Academy.
    It can only be better on a 300lb lighter V1.
    I don't think there is a better all purpose pad than the factory pads.
    They have; no squeek, easy on rotors, impressive fade resistance.
    Only downside is dust.
    Of course, they cant hold a candle to a full track pad, but no streetable pad can.
  15. #165
    yooper's Avatar
    Aug 2009
    Michigan
    576
    Thanks
  • You may not post replies
