Royal purple synchromesh in our T56 M12(little research)
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V Performance Mods Discussion, Royal purple synchromesh in our T56 M12(little research) in Cadillac CTS-V Series Forum - 2004 - 2007; My performance shop recommended Royal Purple synchromesh in my T56 and I read somewhere that RP synchromesh is not good ...
    tigerlion is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Jul 2010
    27
    My performance shop recommended Royal Purple synchromesh in my T56 and I read somewhere that RP synchromesh is not good for our blocker ring.
    So I researched little bit about it and here is what I found out.
    In the past, T56 had paper lined blocker ring and it was vulnerable to the synthetic oils. So some people messed their blocker ring by using RP synchromesh and others.
    However, after some point(2001), carbon high density blocker ring was introduced in T56 and it is not damaged by synthetic oil anymore. So actually, synthetic is good for our T56 because it will hold heat much better than non-synthetic.(Even Dexron VI compatible) (information here cadillacfaq.com/faq/answers/pdf/t56-06.pdf)
    MY Summary
    RP synchromesh is good for our T56.
    What do you guys think about it?
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Royal purple synchromesh in our T56 M12(little research)
    I've used Mobil 1 forever and haven't had any probs
    MikeV is offline Cadillac Owners Fanatic
    Automobile(s): '05 Redline CTS-V
    Mar 2010
    Pittsburgh, PA
    172
    amsoil ATD here. no worries.
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by lollygagger8 View Post
    Quote Originally Posted by MikeV View Post
    I used M1 for the first change and now currently have the Amsoil ATD in there and can't tell a difference. (Street dd).
    ronr's Avatar
    ronr is offline Cadillac Owners Enthusiast
    May 2004
    Fenton, Michigan
    870
    When RPM Transmissions put mine in they used Royal Purple.
    C66 Racing's Avatar
    C66 Racing is offline Cadillac Owners Enthusiast
    Automobile(s): 06 CTS-V (sold)
    Oct 2006
    King George, VA
    680
    You are correct about the paper blocker rings and synthetic fluids. Tremec stopped using paper blocker rings in 2000, so all of this gen CTS-V will be okay. I've been using synthetic tranny fluids in my 02 Corvette Z06 since it had about 800 miles on it, and I used the AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G) in my CTS-V (sold in 09).
    As for which fluid to use, that is always a hotly debated topic. Most will view me as biased as I'm now an AMSOIL Dealer as part of my racing efforts (they do not sponsor me), but in 2003 after losing a race engine I did my own research and made my own conclusions chosing AMSOIL. While not tranny fluid, these two studies may be interesting in highlighting the differences between various fluids even if you discount the AMSOIL fluids from the study. My takeaway for Royal Purple is that they have very poor viscosity shear down (sheared low out of grade in the motorcycle 40 and 50 grade tests as well as the gear lube test) and I personally would chose another option.
    AMSOIL Motorcycle Oil “White Paper” (1 MB pdf file)
    AMSOIL Gear Lube “White Paper” (2 MB pdf file)
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    which do you use? i have it in my car and it shifts like crap when it below freezing.
    vetteboy2k is offline Cadillac Owners Fanatic
    Aug 2005
    157
    I think most fluid shifts like that until its warmed up. I had put RP in and hated it in the cold, regular Dex III was better in the cold and amsoil is slightly better as well. Though its nothing like it when its fully warmed up.
    Think its the nature of the beast
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by liqidvenom View Post
    Pretty certain it's Mobil 1 ATF. I don't drive mine in the winter, but have driven it when it's very cold out. Sometimes it might be a little stiff for a mile or two, but it loosens back up no prob.
    redxiv is offline Cadillac Owners Member
    Automobile(s): 2007 Caddilac CTS-V
    Dec 2010
    32
    4
    I'm running RP synchromesh in my tranny. RP gear oil in the diff. And RP oil in the LS2. Here's my takeaway. Although I haven't driven in the cold yet, I have driven it in an autocross. The tranny was significant improvement. Shifted very smoothly, comparatively. The change was well worth the price IMO. The diff fluid seems todo okay. It feels like the limited slip grips a little quicker cause it seemed to want to spin quicker ,but that may just be me. The engine oil doesn't seem to make a huge difference. It may be smoother but not really noticeable over the mobile1 I'd been using. I really like the tranny fluid. Now if I can only tighten up the slop in in the shifter.
  13. Remove Advertisements
