Snapped off MAP sensor.....&$#@%!!!!
Results 1 to 12 of 12
2004-2007 Cadillac CTS-V Performance Mods Discussion, Snapped off MAP sensor.....&$#@%!!!! in Cadillac CTS-V Series Forum - 2004 - 2007; So after the Exedy Twin was installed my V never ran right. The throttle was hanging at 3K for 15 ...
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    So after the Exedy Twin was installed my V never ran right. The throttle was hanging at 3K for 15 seconds and the car was just miserable. I figured something got hosed up but what? Turns out those UUC motor mounts make it difficult to pull the trans so they were loosened up so there was some wiggle room. At that point , as I discovered today, the MAP sensor was snapped off. Probably torqued it when moving the motor around to get the trans out. The MAP is located at the back of the intake which is not a fun place to work. I dread removing the intake for a 10 second plug and play part. Anyone ever get that broken nipple out of the intake from the MAP without pulling the intake off? I tried a small hooked knitting needle but it doesn't go in.
    http://image2.onlineauction.com/auct...-1179888-1.jpg Here is a pic of the MAP
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,181
    Re: Snapped off MAP sensor.....&$#@%!!!!
    If it were mine, I would try to twist one of those broken bolt extractors (or pehaps a drill bit) into that center hole and then pull it straight up.
    Feb 2007
    Cheese land
    1,596
    I may try that. I want to be sure I don't get any crap in the manifold. I thought about taking off the top cover and removing the rear runner but FAST is afraid you'll drop a fastener down the engine so they tell you not to take the cover off with the intake bolted in place.
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Yeah, I would not remove the top either. The intake comes in pieces so you can drill the MAP location where you want it (front or rear). Assembly requires some sealant in specific areas too.
    Although it is to be avoided, I don't think a few plastic shavings in the intake, and ultimately through the motor, would be fatal.
    Good luck - hellva a way to spend new year's eve.
    Feb 2007
    Cheese land
    1,596
    Had the car put up for the winter but it bugged me that it was messed up even though I won't drive it till March probably. I'm going to try a thin drill in a T handle after I get a new sensor I'll measure which size to use.
    silver02stang's Avatar
    silver02stang is offline Cadillac Owners Enthusiast
    Automobile(s): LS6 CTS-V
    Oct 2008
    Appleton, WI
    39
    548
    Frick! I hate piddly problems! I just got my Stabilitrak sorted out after replacing one of the rear hubs and finally a steering wheel position sensor. Now I have a goofy rattle coming from under the car while under load. Sounds like a heat shield thats slowly getting louder...
    Anywho - I feel your pain.
    Stepside is offline Cadillac Owners Enthusiast
    Automobile(s): '06 DTS performance; CowboyCadillac='12 SVT Raptor
    Oct 2009
    NW Jerzey-in the sticks
    67
    631
    So, when you decide to drill it . . make sure you have a Hoover running,
    so the job will really suck! (the shavings)
    Den_93's Avatar
    Den_93 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V
    May 2008
    Milford, MI
    316
    Got a better pic of the broken MAP?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Feb 2007
    Cheese land
    1,596
    There is a link also in the bottom of my first post. I never realized how small the orifice is. The orange nipple is stuck in the manifold. No wonder the knitting needle hook doesn't work. The wierdest thing is that the car has not thrown a code for the MAP and it still runs (barely) and idles. Once underway when you take your foot off the gas the manifold pressure reading doesn't increase so it must think that the car is still under power and continues to supply it with spark and fuel. After about 15 seconds of hanging at 2500-3000 rpm maybe the MAF sensor says there is no air moving into the engine so it finally returns to idle.
    Here is a pic of how it mounts in the rear
    http://media.photobucket.com/image/f...j/IMG_6457.jpg
    Den_93's Avatar
    May 2008
    Milford, MI
    316
    I wanted a to see an actual pic of the of the broken orifice to see how big the hole is. I would try using a drywall screw (or one that fits) to screw it in and pull it out with a pair of pliers. The threads of the screw should be course. It also might help to heat the screw red hot before you screw it in and let it cool before you start pulling.
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Quote Originally Posted by Den_93 View Post
    For what it is worth, the intake comes with no hole for the MAP and the instructions call for a 3/8" inch hole to be drilled to accept the MAP grommet, which is red in the picture.
  15. Remove Advertisements
