Mystery Mods Revealed - Page 2
Results 16 to 30 of 31
2004-2007 Cadillac CTS-V Performance Mods Discussion, Mystery Mods Revealed in Cadillac CTS-V Series Forum - 2004 - 2007; When he says "poly" he is referring to polyurethane motor mounts, trans mount, and diff bushings. Cadillac fitted the V's ...
  1. #16
    c4ss's Avatar
    c4ss is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V, Black
    Jun 2008
    Northern New Jersey
    2,166
    Re: Mystery Mods Revealed
    When he says "poly" he is referring to polyurethane motor mounts, trans mount, and diff bushings. Cadillac fitted the V's mostly with cream puff, rubber bushings. Most V owners like to stiffen up the drivetrain a bit with these upgraded mounts. Good luck with the good find
  2. #17
    V-Guy is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V, Raven/Ebony; Harley Fatboy; Harley Ultra-Classic
    Dec 2010
    Indy
    509
    Quote Originally Posted by c4ss View Post
    Oustanding! Thanks!!
  3. #18
    Zo6PwRd Guest
    Ill have to agree and disagree with Darkman, before i bothered dropping 1000 on a FAST id pick up a set of pacesetter or OBX long tubes. Youll see a good gain for less money and itll sound a lot better.
  5. #19
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Quote Originally Posted by Zo6PwRd View Post
    We may not disagree all that much. I think the current horsepower restrictions on this set up in order of magnitude/priority are as follows:
    1. The stock catalytic converters.
    2. The stock intake.
    3. The stock exahaust manifold (the primaries).
    Since headers would presumbly address items 1 and 3 at the same time the net gain is likely more than replacing the intake alone.
    On the other hand, replacing the intake and the catalytic converters (e.g. with Random Techs or other high-flow cats) without getting headers might equal the gains of a header installation alone.
  6. #20
    Dec 2010
    Indy
    509
    Again, fabulous information. Sounds like I have a to-do list! One question - are the catalytic converters on the GM Performance Exhaust (manufactured by Corsa) the same as the stock CCs? In other words, are they not "high-flow"? From darkman's last post, I assume they are the same as stock - or the stock converters are simply integrated into the new exhaust system when its mounted.
    Thanks again, guys. This forum has been great education for me (an admitted newbie).
    Guy
  7. #21
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    The Corsa, as well as other similar exhaust systems, replace the stock exhaust system downstream of the catalytic converter only and therefore retain the stock cats. Hence the nickname - "Catback."
  8. #22
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,365
    Take it to a dyno and see numbers and air fuel. Did it come with a handheld tuner?
  9. #23
    Doctechx is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V Black Raven w/Ebony
    Sep 2010
    Fishers, Indiana
    39
    72
    Good find. I am in the Indy area, and bought my 2006 V shortly before your 2007 hit the market. Did you find the car at Hare Chevrolet in Noblesville? If so, it also has the upgraded wheel package. One thing that I am very curious about is the Volant intake. I was under the impression that Volant did not make an LS2 intake for the CTS-V. I have researched this extensively, and I have only ever seen Volant for the LS6 models. Can anyone comment on this? Seems like the Volant intake tube would be an issue. Perhaps it is only a Volant box with the stock tube, or the Volant tube was modified. I can't imagine that they would change out the 90 mm TB to allow for straight bolt-up. Has anyone else been able to use the Volant intake on a LS2 V?
  10. #24
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    I would have to say the cheater cam is great, but since you are opennin it up there are other nicer cams...Katech Spec-2, LPE GT-11, and others...I would also ask about this High performance ECM...Does he mean a tune???
    Fast 90 or 92 ported would compliment your stock heads and headers are a must...
    Dont forget to upgrade your clutch and brake lines...
    Have a great build and if it doesnt sound right, ask questions
  11. #25
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Quote Originally Posted by Doctechx View Post
    A Cold Airtake Intake for the LS6 is adaptable to the LS2.
    Even though the LS6 has a 78mm throttlebody and the LS2 has a 90mm throttlebody, the outside diameter of both throttle bodies is the same. So the tube fits. (I have a 90mm throttlebody on my LS6 using the stock intake tube).
    The only other difference is that the LS2 intake tube has vacuum line just upstream of the throttlebody. I adapted my stock LS6 tube by simply drilling a hole and inserting a vacuum line take-off fitting just before the throttle body.
  12. #26
    Dec 2010
    Indy
    509
    I have had the same question - I've never found a Volant that is explicitly made for the LS2. I don't actually know how the Volant was modified to fit my car, but I'm in contant contact with the gentleman who did all the mods, and I can certainly ask him that question - which I've been curious about too.
    As always, darrkman's explanation makes perfect sense.
  13. #27
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by V-Guy View Post
    As you'll find it usually does around here. Same OD case closed. BTW Congrats on finding out all these little niceties, I got to find out all the crap wrong with mine when I bought it! haha
  14. #28
    Dec 2010
    Indy
    509
    Thanks! By the way, here are a couple pics. As you can see, it looks like the Volent tube was used.
  15. #29
    Dec 2010
    Indy
    509
    Quote Originally Posted by darkman View Post
    I just talked to Cliff, who did my mods. His reaction (very consistent with darkman):
    "Tube fit no problem. Had to add a hump hose at the MAF (kept coming apart at WOT) and had to improv the breather hose."
  16. #30
    Cliffy0503 is offline Cadillac Owners Member
    Automobile(s): NONE
    Dec 2009
    Toledo, Ohio
    42
    1
    V Guy, thanks for your kind words. I had so much fun working w/ that car. The prior owner never beat on the car of the line, just drove it fast, so he never had any complaints about wheel hop; now , a polly diff bushing will make a world of difference as has already been noted. Like I said, my goal was to make the car faster without having too many negative side effects on driveability. I am so glad to have been in contact with you and share some history on the car. I kind of miss it, but at least I know it is in good hands now. -Cliff
  17. Remove Advertisements
