Rps twin disc
Results 1 to 15 of 15
2004-2007 Cadillac CTS-V Performance Mods Discussion, Rps twin disc in Cadillac CTS-V Series Forum - 2004 - 2007; Has anyone installed the RPS twin disc kit for the V??? I talked to Carolina Clutch and showed them pics ...
    RADARB8's Avatar
    RADARB8 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V TURBOCHARGED
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Rps twin disc
    Has anyone installed the RPS twin disc kit for the V??? I talked to Carolina Clutch and showed them pics of my used twin i bought from a gentleman on the LS-1Tech Forum and he told me YES my clutch will fit...I have a 1" new collar that came with it...and was told i could use that with my stock LS2 slave..or i could buy their slave with bearing which is a c5, ....He said the slave is longer for only app. $145.00...which sounds great But i have heard from a few f/m that the RPS does NOT fit our cars Anyway, please chime in.. Especially u Darkmanlol......Notice how the flywheel has been machined and borebalanced.. I knocked off exactly 10lbs...steel flywheel weight is exactly 20lbs.
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Re: Rps twin disc
    wait for some smarter people to chime in
    But it doesn't look like the discs have springs. There was talk on the Katech clutch thread that this might make the parade clunk worse.
    Tony
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Re: Rps twin disc
    Are those the disc's that cam with the clutch? Is it a dual friction carbon? I ask because the discs are carbon and the floater is carbon but the flywheel is steel. You can't run carbon on steel so the other side of the disc will need to be a different material. I believe RPS uses an organic side that faces the flywheel and pressure plate and leave the floater and floater side of the discs carbon. If this is how this is set up, great! Just make sure that the organic side faces the steel and the carbon side faces the carbon. Its a great clutch and I have heard a lot of good things about it. There is no reason this wouldn't work in a V. Its shorter than an LS9 package. You can install it and measure for proper clearance. I wouldn't just bolt something in without measuring.
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    Re: Rps twin disc
    This info is from Vengeance Racing
    Product Description
    RPS's Street Twin Lite has been designed and engineered especially for the LSX powered Corvettes, Cadillacs, and F-bodies. This version replaces the original cast iron "casting" with an aluminum piece that has RPS's exclusive carbon friction material attached to the face. The Street Twin Lite complete weighs in at a mere 33 lbs and is great for Road Racing, Drifting and Drag Racing. This clutch uses a patented, non-warping, carbon floater plate with RPS exclusive light weight twin disc system. The inner disc has RPS's carbon-carbon friction material on the floater side (to match the carbon material on each side of the floater) and high grade organic material on the flywheel side. The outer disc has carbon-carbon on both sides, one to rub against the floater and one to rub against the "casting". This combination makes for a great high horsepower street and race clutch with smooth engagement, easy pedal pressure and quiet operation. Testing has shown this clutch is capable holding 805 rwhp and over 750 lb-ft of torque. If you want to get your big power to the ground and keep your car a joy to drive, this is the clutch for you.
    Weight: 32lbs.
    Pedal Press: Stock + 10%
    Torque Capacity: 750
    RADARB8's Avatar
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Re: Rps twin disc
    thanks guys.....this used clutch has no groves in the pressure plate or flywheel.. just some hot spots that i am going to get refreshened.....This kit must be the older version cause it has a steel flywheel that some machine shop drilled for weight purposes, and it has what ctsv154 says a 2 sided carbon floater disc. The other discs have carbon on one side only leaving the organic sides for the flywheel and pressure plate.does that sound correct...I will be puttting it in about 3 weeks from now...The guy who sold it to me said it worked great but he was using a Mcleod slave with it and the pedal pressure was stiff and didn't like it...plus he got a good deal on an Excedy twin and his buddy put it in his V for him free...
    The outer disc has carbon-carbon on both sides, one to rub against the floater and one to rub against the "casting". If Darkman is correct then i have the wrong disc for the pressure plate because my outer side that runs against the metal pressure plate is organic not carbon.
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    Re: Rps twin disc
    Quote Originally Posted by RADARB8 View Post
    If Darkman is correct then i have the wrong disc for the pressure plate because my outer side that runs against the metal pressure plate is organic not carbon. [/COLOR]
    Darkman knows nothing about this. Darkman just copied info from the Vengeance Racing webiste.
    RADARB8's Avatar
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Re: Rps twin disc
    thanks guys,,,I am going to goggle Vengeance racing right now and check it out. and probably give them a shout...good info:
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    Re: Rps twin disc
    Can you post up some more pics of the discs?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    Re: Rps twin disc
    Quote Originally Posted by ctsv154 View Post
    Vengeance has some pics of theirs (may be different though).
    RADARB8's Avatar
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Re: Rps twin disc
    i didn't see anything on Vengeance Racing... been trying to bring up some pics that i took of the discs for the past 3 hrs.pissedi need a drink. going for a bud select55 right now....OUT!!!!!!!!!!!!!!!
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    RADARB8's Avatar
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Re: Rps twin disc
    Pics of RPS disc's. maybe this will help.
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    Re: Rps twin disc
    Those look correct to me. Organic on the sides that face the steel and carbon on the side that faces the carbon floater. I dont know enough about carbon clutches to tell you they are in good shape but it looks like all the right parts.
  16. #14
    RADARB8's Avatar
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Re: Rps twin disc
    When i go to the shop and get the flywheel and pressure plate cleaned up it will look like new....just curious....has anyone ever seen a flywheel drilled and balanced to knock off 21lbssteel flywheel is now exactly 2o lbs.
  17. #15
    RADARB8's Avatar
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Re: Rps twin disc
    Yeah, thanks guys...everything looks good to me..just don't know yet about the flywheel...it looks like quality machine work to me....................
    https://www.vengeancerd.com/ecart/pr...in-Lite-Clutch Read more at http://www.cadillacforums.com/forums...ost2449710Read more at http://www.cadillacforums.com/forums...nk#post2449710
    And i will check out that Vengeance site Darkman....thanks again....
  18. Remove Advertisements
