Shifter/Shifting Issues!
Results 1 to 13 of 13
2004-2007 Cadillac CTS-V Performance Mods Discussion, Shifter/Shifting Issues! in Cadillac CTS-V Series Forum - 2004 - 2007; Hello Guys, great forum and excellent info. I rarely post but read all the time. I need help....I have posted ...
    Izzmeister's Avatar
    Izzmeister is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Nov 2006
    Miami
    108
    Hello Guys, great forum and excellent info. I rarely post but read all the time. I need help....I have posted something similar before but here goes.
    2007 CTS-V Black on Black
    Mods: HID 6k fogs and headlamps, Katch shifter/lindsay bushings, Eibachs with MM plates, poor-man's magnaflow(no-cats), nitto invos, LEDs everywhere, lingenfelter CAI...misc stuff.
    Issue: Shifting is very difficult, I have to fight the shifter to get into gears especially 1st gear. I have checked just about everything, when the retaining nut on the bottom pivot that connects to the selector rod is tight it gets a little better for a few days but still is too difficult to shift and gets worse. I have checked everything twice in the car and will probably be dropping the tranny soon to see whats wrong.
    The bushing in the shifter bottom are stock and in good shape, the shifter is installed correctly and has been lubed at the pivot ball. I have noticed that when its cold out the car shifts a little better and in warm weather it really is difficult to shift. It feels like it gets stuck halfway like it has a rough spot. I have no choice but to check the rods connecting to the tranny and their bushings, etc. I have also drained the tranny fluid and re-filled with dex/mer as specified in the manual. Don't know why my car shifts so horribly. I have driven other Vs with the same shifter and it was an absolute joy to shift. Mine is rough and notchy all the time.
    If anyone knows what I can look for at the tranny level please let me know. Im guessing it has to be the tranny forks or the bushings that connect to it.
    Thanks Guys....btw my V did 352-HP/354-TQ at the wheels on a real dyno after the tune with the above mentioned mods...I have a dyno sheet and video of the car making the run if u guys want to see...I also have some pics of the car...nothing special but she's mine....lol
    Houdini's Avatar
    Houdini is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS-V, 2010 CTS-V 6MT (Sold), 2007 CTS-V (Sold)
    Nov 2007
    St. Louis Metro
    1,404
    Re: Shifter/Shifting Issues!
    You've probably checked already but how was clutch fluid? Does it need to be changed or does the clutch need to be bled? What about your motor mounts? When mine were shot shifting got horrible.
    Izzmeister's Avatar
    Nov 2006
    Miami
    108
    Quote Originally Posted by Houdini View Post
    Motor mount are creative steel and in good shape. Clutch fluid reservoir was empty but I filled it. The clutch engages well though, even when the car is off and I engage the clutch the shifting is just as bad. I think I am going to have to bring the tranny down and check that selector rod. It's the only thing I have not checked yet. I can feel that it binds before getting into gear fully and then snaps in gear.
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,813
    Even though you topped off your hydraulic clutch fluid, the cheap (and smart) thing to do is bleed it and then top it off again with fresh fluid.
    If that doesn't work, then we can take the next step.
    PISNUOFF Guest
    Seems to me like you have an issue with the shift rod that goes into the top of the trans. Also, you may want to check and see if the center shift rod is hitting the boss that sticks out about 2" from the top/rear of the trans.
    Izzmeister's Avatar
    Nov 2006
    Miami
    108
    Quote Originally Posted by PISNUOFF View Post
    You know come to think of it when I was installing the Katech thru the top my stock shifter while connected fell on the driveshaft a few times pretty hard and dented the crap out of the rod. Maybe it changed the linkage geometry or even moved/damaed the pin that goes connected to the top of the trans. Can I buy just that linkage?
    PISNUOFF Guest
    I don't think you can buy just that linkage. Denting it upwards wouldn't harm the way it shifts, only where in the boot each gear is located. If you don't feel like the shifter stalk is hitting inside the cabin then you are OK. I also find it hard to believe that it hit hard enough to bend that rod, it's pretty sturdy.
    PISNUOFF Guest
    I think your issue is right here or under the cover right on top of this picture.
    Izzmeister's Avatar
    Nov 2006
    Miami
    108
    I'm going to just take it to the dealer and let them figure it out. I do not know what would break or go wrong there. I live in florida, weather is warm 95% of the year. These past 2 weeks have been pretty cold...30s 40s and 50s. The colder it is the better the shifting, don't know what the correlation is. @pisnuoff....what do u think the exact problem is? Inside the tranny? Or maybe the linkage bushing is shot? Suggestions before I take it to the dealer....
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by Izzmeister View Post
    No real suggestions, but one heads up - the first item on the transmission troubleshooting protocol (GM Service Manual) is to flush and bleed the clutch hydraulics. Many dealers, and other shops for that matter, will not even investigate other possible causes unless and until they are allowed to flush and bleed the system. So if you run into that, it does not necessarily mean they are out to get you.
    Izzmeister's Avatar
    Nov 2006
    Miami
    108
    Got it Darkman, Thanks everyone
    PISNUOFF Guest
    I can't give a good, educated guess without seeing/hearing/feeling exactly what it's doing. That being said, my gut feeling is that it's related to the trans itself.
    lonestranger is offline Cadillac Owners Fanatic
    Automobile(s): 05 Escalade ESV Platinum
    Dec 2005
    Bradenton FL
    203
    Maybe the battery in the Dewalt is low??? Just a thought!! (Grin!!!)
  16. Remove Advertisements
