Front @ Rear upper and lower control arm bushings
Page 1 of 14 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 15 of 200
Like Tree7Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Front @ Rear upper and lower control arm bushings in Cadillac CTS-V Series Forum - 2004 - 2007; I spoke with Max @ "Creative Steel" (503) 316-1811 he is the company that makes the motor mounts and transmission ...
    zzilla is offline Cadillac Owners Fanatic
    Automobile(s): cts v-xlr v
    Jan 2009
    158
    I spoke with Max @ "Creative Steel" (503) 316-1811 he is the company that makes the motor mounts and transmission mounts. He said if we can gain enough interest he would consider making control arm bushings for the front and rear, upper and lower .
    These bushings will be for performance , meaning the ride will be rougher but the performance wil be alot better. If any of you have ever put polyurethane bushings on a hot rod or muscle car you know the advantages.
    jerrycecco is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Jun 2005
    TX
    469
    Re: Front @ Rear upper and lower control arm bushings
    im interested, ESPECIALLY for the front
    already have the Adam's MAPerformance REAR trailer arms
    2004 CTS-V
    jerrycecco@gmail.com
    RVO27 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    Gaithersburg, MD
    66
    I'm definitely interested!
  5. #4
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    Interested as well!!!
  6. #5
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,156
    I have a set of slightly used rear upper control arms that I can make available for designing/developing a set of bushings.
    (I got a new set from the Cadillac Racing program parts inventory sell off that have race-grade bushings.)
  7. #6
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    Definitely in for upper control arm. Having disassembled my control arms no less than 3 times in the last week those bushings look like toasted bread. I'm curious as to the design. I'd be interested in ones that can be mounted upside down with a more industrial and wider solid urethane flange to accommodate after market shocks/spring combos. Sort of like the stock one but bigger.
  8. #7
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Interested!
  9. #8
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,150
    I'm also interested. While I was removing/servicing/reinstalling my trailing arms over the weekend I noticed that both upper rear control arms seem to have shifted towards the rear about 1/4-1/2". The bushings appear to be getting pushed out of the control arms. I wasn't able to get a good picture of the rear bushing, but here's the front bushing on the driver side rear upper control arm. You can see that the control arm is offset to the rear (to the right in the picture) and you can see that at least 1/4" of the rubber bushing can be seen sticking out. I can't imagine that's normal.
    Quote Originally Posted by jerrycecco View Post
    Are the trailer arms for towing? And what does having "trailer" arms have to do with replacement bushings for the upper and lower control arms? Did you install the poly bushing from MAP in the rear knuckle despite the fact that the bushing sleeve isn't the proper length and buckles under the proper torque?
    Quote Originally Posted by ichpen View Post
    Front or rear?
    You totally lost me here. The bushings in question are all mounted basically horizontally, and they're cylindrical bushings, so I'm not sure what mounting them upside down would do. And I don't know how the control arm bushings would do anything to accomodate aftermarket dampers and springs.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  10. #9
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    I'm in.
  11. #10
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Aug 2009
    Michigan
    576
    Interested in rear upper and lower.
  12. #11
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    interested... autocrossing is dangerous to my wallet...
  13. #12
    verywhitedevil's Avatar
    verywhitedevil is offline Cadillac Owners Enthusiast
    Automobile(s): 05 CTS V
    Feb 2009
    Tempe, AZ
    600
    interested
  14. #13
    Jan 2009
    158
    Quote Originally Posted by darkman View Post
    Great! I will have my original front upper control arms to send him as well. As I also have a set of upper contol arms from GM racing
  15. #14
    ichpen's Avatar
    May 2008
    1,383
    Interested in fronts mostly but if price is good I'll replace all of the suckers.
  16. #15
    Jan 2009
    158
    I will start a list of everybody who is interested and speak to Max so he can get us a price. The names with question marks I will need you guys to specify as to Front@Rear-Upper@Lower, only rear, only front, only upper, only lower etc...
    1.zzilla -front and rear/upper@lower
    2.jerrycecco - front upper@lower?
    3.rvo27- front and rear upper@lower
    4.tweeter81- front and rear upper@lower
    5.darkman-front@rear-upper@lower?
    6.Ichpen- upper front
    7.unsafeatanyspd.?
    8.AAIIIC-Front@rear- upper@lower
    9.tommycompton-Front@rear-upper@lower
    10.yooper-Rear upper@lower
    11.Dan_Gurney -Front@Rear-upper@lower
    12.verywhitedevil -Front@Rear-Upper@lower?
    13.godsmistake103-Front@Rear-upper@lower
  17. Remove Advertisements
