keep busting rocker arms - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
2004-2007 Cadillac CTS-V Performance Mods Discussion, keep busting rocker arms in Cadillac CTS-V Series Forum - 2004 - 2007; Was cylinder number 8 this time. Cleanly sheared off. Took out the IAT sensor with it. Fun times. Now scratching ...
  1. #31
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    Re: keep busting rocker arms
    Was cylinder number 8 this time. Cleanly sheared off. Took out the IAT sensor with it. Fun times. Now scratching head as to where I can get the maggie iat sensor. Need to dig up that aftermarket thermistor part number again.
  2. #32
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by ichpen View Post
    It is just a GM part as I had to get one for my setup. Let me see what I can find in my records.
    EDIT: Part # 12160244 Found here --->http://paceperformance.com/i-5118475...nd-trucks.html
  3. #33
    ichpen's Avatar
    May 2008
    1,383
    Thanks sir. Found the part number and replaced it. One day I'll have to fish the old one out of the valley one day.
    All well for the time being.
  5. #34
    ichpen's Avatar
    May 2008
    1,383
    Small update. Given that none of the shops/folks I've talked to have any clue as to what's going on, I'm going to try to go back to stock rockers. They're cheap enough and from what I've heard still offer excellent performance (given they're lighter than 90% of aftermarket rocker arms). More importantly, I never busted one of those.
    I'll keep the tea dual gold springs and hardened pushrods and just switch the rockers. Will see how that goes. Thanks for the opinions gents.
  6. #35
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,790
    Did you ever try an adjustable pushrod and measure what you need?
  7. #36
    ichpen's Avatar
    May 2008
    1,383
    No, need to get the adjustment pushrod thingymabob. Maybe I'll measure it up when I'm doing the swap.
  8. #37
    PISNUOFF Guest
    There are different styles of measurement pushrods. Make sure you use the correct one for the brand/style pushrod you are using, if not you could be off by as much as .017". i.e. the Comp Magnum's use a different measurement than the Comp Hi-Tech push rods when ordering them. Here's some reading on them:
    http://www.compcams.com/Products/CC-...rods%27-0.aspx
  9. Remove Advertisements
