Mini Tubs Coming Soon - Page 2
Results 16 to 30 of 37
Like Tree1Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Mini Tubs Coming Soon in Cadillac CTS-V Series Forum - 2004 - 2007; good luck jeff on getting this done right. cant wait to see it....
  1. #16
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    Re: Mini Tubs Coming Soon
  2. #17
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Quote Originally Posted by tony tone View Post
    i'm running 20x10.5s in the rear like if it's nothing. i'm even tucking almost to the rim with a 285/25 nitto invo without rubbing and everything is stock apart from my k-sport coilovers. even better, i'm considering some step-lipped adv.1 multi-spoke wheels that are 20x11.5 with no modification other than a stretched 285 tire and based on measurements still no rubbing. what's your mission? i'd love to help. what wheels are they? are they custom? also, no spacers here either...
    I am runnin CCW C140s and HRE C2X wheels
    The CCW are 18x8.5 and 18x9.5, no spacers and barely clearing the fender and mms from the trailing arm.
    The HREs will be 18x9.5 up front and 19x10.5 rear...
    The HREs i am runnin a 10mm spacer up front and a 10mm spacer in the rear. The spacers are to give the front clearance from the caliper and the rear clearance from the trailing arm. Again, that pesky trailing arm is annoyin me. I even have the offsetted one from MAP. that is what gainned me 1" more depth. I am runnin Pensky coilovers for the whole car with custom springs, So i have plenty of clearance for Neg camber...
    How do you guys run these wide rims...Like i said i wanted to run a 325 tire in the rear like the vettes do...But i am stuck with a 305...
  3. #18
    Washin's Avatar
    Washin is offline Cadillac Owners Fanatic
    Automobile(s): Twin Turbo 2005 CTS-V
    Jul 2005
    Northern New Jersey
    306
    The frame is rough cut and the wheels are on. Now he has to box the frame and weld it all up. Hopefully I will be beating some Lamborghini ass for Christmas.
  5. #19
    Houdini's Avatar
    Houdini is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS-V, 2010 CTS-V 6MT (Sold), 2007 CTS-V (Sold)
    Nov 2007
    St. Louis Metro
    1,404
    Awesome. No rubbing so far? Looks tight!
  6. #20
    bcarv87's Avatar
    bcarv87 is offline Cadillac Owners Fanatic
    Automobile(s): 05` maggied V
    Oct 2007
    MA
    142
    WOW that looks close
  7. #21
    tony tone is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Jan 2009
    miami
    36
    337
    Quote Originally Posted by Naf View Post
    wow, 305 is nice but i agree, 325 would be just that much better. i'm curious as to why you would have to run spacers with HREs. they're one-off wheels built to fit, therefore they should be hub centric and spaced accordingly from your caliper and trailer arm. my spokes clear the calipers pretty easily with no spacers and stock arms. no hub centering rings either, just wheel.
  8. #22
    JD03Cobra's Avatar
    JD03Cobra is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Thunder Gray 6MT
    Mar 2008
    Michigan
    44
    2,122
    That looks awesome! Can't wait to see the finished product.
  9. #23
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
  10. #24
    856V is offline Cadillac Owners Member
    Automobile(s): 05V
    Aug 2010
    49
    holy tire
  11. #25
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    Had to run a spacer up front to clear my massive brakes, the rear was only to help my 275 clear the trailing arms...
    Pesky trailing arms...Always in my way
  12. #26
    Washin's Avatar
    Jul 2005
    Northern New Jersey
    306
    Because of the positive camber dialed into our cars we decided to section the lower control arm and add about a half inch of material to get the rear tires to sit flush on the ground. No sense adding a nice big tire only to be able to take advantage of half the contact patch. Tomorrow he will be modifying the trailing arms. Unfortunately the Map arms are basically useless. I should have just had my guy make me a set to begin with.
  13. #27
    Washin's Avatar
    Jul 2005
    Northern New Jersey
    306
    Here are a few more pics for you. Looks like he will be customizing the MAP trailing arms tomorrow.
  14. #28
    ctsv154's Avatar
    Oct 2007
    32
    3,824
  15. #29
    Feb 2009
    Long Beach Ca
    35
    2,741
    sexy...
  16. #30
    Washin's Avatar
    Jul 2005
    Northern New Jersey
    306
    Mini tubs are done. In order to make a set of 305's fit with a stock offset you basically have to re-engineer all of the suspension components. It was a lot of work but in the end it will be worth it. I plan on picking her up by Thursday and hope to have some video of test launches soon.
  17. Remove Advertisements
