Creative Steel motor and transmission mount installed
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
2004-2007 Cadillac CTS-V Performance Mods Discussion, Creative Steel motor and transmission mount installed in Cadillac CTS-V Series Forum - 2004 - 2007; And I couldn't be happier. I had a bad passenger side motor mount that was completely torn on top and ...
    icucmeuc is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Dec 2009
    Manchester, NH
    39
    65
    And I couldn't be happier. I had a bad passenger side motor mount that was completely torn on top and causing all sorts of clunking and made the whole car shudder when starting and stopping the engine.
    After installing the Creative Steel mounts the car feels extremely ... tight... I guess that'd be the best way to describe it. Going from 1 bad mount to new mounts decreased the vibrations I was getting CONSIDERABLY, but I have no reference going from good stock mounts to the Creative Steel ones.
    I'll be doing the differential mount next / soon as it didn't look too good back there.
    Some things to mention.
    On the tools listing that they have posted up for the removal and install procedure on the motor mounts, a 13 mm socket is listed for the top bolt on the lower bracket. Mine were actually 18 mm... Also doesn't hurt to have a 3/8 drive flex and 1/2 drive flex too just to make it easier to get certain angles.
    To get appropriate angle on the driver side lower mount nut on the lower bracket I found using a wrench to be just too freakin' frustrating. I unbolted the top bracket from the block and turned it around in there so I could get an air gun on the lower nut and took it apart that way. MUCH easier. For reverse I did the same just using a ratchet instead of the air gun, and leaving a thread or two loose so the bottom bracket could be properly clocked in.
    I did this on jack stands laying on my back, and it took me 4 hours on my own, but an hour of that was fighting with the wrench before I tried the other approach. That is for both motor mounts and transmission mount.
    I'm extremely pleased. The car feels completely different
    wcryan is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS-V Maggied
    Aug 2009
    Escondido, CA
    28
    1,065
    Re: Creative Steel motor and transmission mount installed
    who did u get your diff bushing from?
    Dec 2009
    Manchester, NH
    39
    65
    Quote Originally Posted by wcryan View Post
    Didn't get that yet but will be ordering from Creative Steel
    MotorMounts's Avatar
    MotorMounts is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black CTS-V
    May 2009
    Salem Oregon
    50
    400
    Glad to hear you like the mounts. As soon as I read that you had the 18mm headed bolts on the front of the lower brackets I thought "Bet he has an 04" then I looked up to see what car you drive by your screen name... Yip, 04. I'll bet that it's an early 04 too. We just did a mount install for a customer in our shop and it took me a while to figure out why the 13mm wouldn't fit (can't see the head of the bolt while installed) that car also had an 18mm headed bolt. I don't know when GM switched to the 13mm but my 04 is the 13mm version.
    Sorry guys, this is a lot of talk that won't effect most of you.
    Very good hear you like the motor mounts and trans mount, Max
    Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
    http://www.creative-steel.com
    maxx@creative-steel.com
    CTS_V_04 is offline Cadillac Owners Member
    Nov 2010
    11
    Motormount, do you offer military discount? Also where do I order from?
    06CTS-V is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Jan 2010
    New York
    37
    111
    Quote Originally Posted by CTS_V_04 View Post
    What he said...
    May 2009
    Salem Oregon
    50
    400
    Yes, we do offer a military discount, 10% off the total of the order. Fax a copy of your DD-214 or military ID, tell Kristie when you call, she will hook you up. Our fax number is 503-316-1814.
    Thanks for signing up you guys, very cool. Max
    Jan 2010
    New York
    37
    111
    Quote Originally Posted by MotorMounts View Post
    Can you PM me a quote for black motor mounts only shipped to 12553 with the discount? I'll fax u the copy of my ID tomm. Thanx
    POS VETT is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Mar 2010
    44
    274
    Ok, I'm going to be lazy, where can I find the instructions to replace motor mounts ?
    jmpumford's Avatar
    jmpumford is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Maggied CTS-V
    Oct 2010
    Los Angeles, CA
    34
    253
    Quote Originally Posted by POS VETT View Post
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    I guess I should have asked! Either way I am extremely happy with the products. I can vaguely remember my dash clunking on hard shifts. What a PITA that was, thanks Max! And for the guys on the fence DO IT. This is hands down the best mod (bang for buck/results) that you can do if you have more than 20k miles...
    hnic91 is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Jan 2010
    Massachusetts
    32
    95
    Quote Originally Posted by CancerJCC View Post
    MY motor mounts and trans mount are on the way. I have yet to feel how smooth the car is stock. Can't Wait
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Apr 2008
    2,061
    and you won't, unless you just ordered oem mounts.
  16. #14
    msteno is offline Cadillac Owners Member
    Automobile(s): 05' V
    Mar 2010
    Sterling, VA
    40
    25
    How do I go about ordering a set of these?
  17. #15
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Contact Max by phone or email.
    His user name is MotorMounts on this site if you want to PM him.
    From above:
    The web site is getting close as of today 8-31-10
    E-mail, maxx@creative-steel.com
  18. Remove Advertisements
