Page 7 of 7 FirstFirst 1234567
Results 91 to 96 of 96
Thread: The definitive h&r / mm spacer lowering thread
  1. #91
    WesH8398's Avatar
    WesH8398 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2010
    Sarnia, Ontario, Canada
    35
    897
    With OEM sized wheels and tires, you won't have any rubbing issues, even once your camber is brought back into spec. The shop that did my alignment got me within OEM alignment specs, no problem. Just be aware that going with bigger rims and/or bigger/wider tires WILL introduce a whole new gamut of issues. Trailing arms and maybe a fender rolling should solve these though.
  2. #92
    9t8z28's Avatar
    9t8z28 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Jul 2011
    36
    116
    Re: The definitive h&r / mm spacer lowering thread
    I kept posting the wrong pics above! Got em right this time
  3. #93
    WesH8398's Avatar
    Apr 2010
    35
    897
    Quote Originally Posted by 9t8z28 View Post
    I am also going to try and raise the front suspension slightly as well. I am going to see if I can make a 1/4" spacer to go in between the shock and the lower control arm and see what it does. My main concern is that it will be stable. That and a 40 Series tire on all 4 corners will help as well.
    Do you NEED to run lower profile tires for any reason? That'll contribute to poorer ride quality, no doubt. And the h&r springs aren't the coziest of rides to begin with.
    I'm no engineer, but I'm not sure that placing a spacer between where the bottom of the strut attaches to the lower control arm will affect your ride height. Maybe it will, but my simple brain is having a hard time with it. Something's telling me that you'd want to put the spacer between the bottom or top of the spring and the upper or lower spring perches... Actually, between that lower spring isolator and the lower perch looks like a perfect spot.
  4. #94
    9t8z28's Avatar
    Jul 2011
    36
    116
    I want to go from a 245/45/18 Goodyear F1 to a 255/40/18 NITTO NT555. It will only decrease tire diameter by a 1/2" at the most. The front tires make contact with the inner fenders so the slightly smaller tire will help. I am not totally concerned about a slightly harsher ride.
    Putting a spacer between the spring will increase ride height but it will also stiffen the spring and the worst part is it will take away the springs travel which will also take away the shocks travel. Spacing the shock from the lower control arm will increase ride height without affecting the spring. Like I said, I just have to make sure there is room and that it will be stable and not snap the bolt off. I have done this to my 4th Gen Camaro with the same style upper/lower control arm with a strut and it worked perfect.
    Quote Originally Posted by WesH8398 View Post
  5. #95
    9t8z28's Avatar
    Jul 2011
    36
    116
    I did the mod this past weekend. I used the 3/8" spacer on the bottom. It was a little bit of a pain to cut with a razor blade but it worked. I also reused the scrap piece and used it on the top. I pit it between the factory rubber and the spring. The car has been on the lift so when I put it back down on the floor it was over an inch higher! I didn't drive the car and I am sure it will settle some. The top spacer is probably not going to work as it only contacts only a portion of the spring.
  6. #96
    EdmundGTP is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V
    Aug 2009
    Tempe AZ
    35
    612
    Id buy another piece for the top... That doesnt look like it will work well for very long..
  • You may not post replies
