Weight Reduction Checklist - Page 5
Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 81
2004-2007 Cadillac CTS-V Performance Mods Discussion, Weight Reduction Checklist in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by rand49er Holy crap! Look who showed up! Apparently it's the new cool for the oldskool to show ...
  1. #61
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Re: Weight Reduction Checklist
    Quote Originally Posted by rand49er View Post
    Apparently it's the new cool for the oldskool to show back up
    BTW,
    So happy my V1 and V2 both have moon/ultraview delete!
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  2. #62
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    67
    13,803
    Quote Originally Posted by trukk View Post
    BTW,
    -Chris
    Chris, I still want a ride in one of the sessions at an upcoming V Day.
  3. #63
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by Rollbar View Post
    .My 3720 lb car still has ac and emergency brake.Huge weight savings if removed.
    Any ideas what those items might weigh in at?
  4. #64
    Rollbar is offline Cadillac Owners Member
    Automobile(s): '04- V with 6.2 L
    Dec 2009
    DALTON,GA.
    58
    71
    E brake foot mechanism inside car weighs 10-20 lbs.AC compressor at least 20 lbs with less serpintine belt resistance.
  5. #65
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    While the A/C Compressor is about right, I've shipped my brake pedal assembly as well as all of the cables and I'm pretty sure it was under 10lbs
  6. #66
    NormV is offline Cadillac Owners Connoisseur
    Automobile(s): XTS VSport-550+ lb-ft of torque, ATS 2.0T AWD HPTuners tuned
    Jun 2007
    OH-IO!
    2,633
    BTW,
    -Chris
    Hi Randy and Chris! Roofless V-Series guys unite! Chris is Vx2?! Six hundred miles per week has mine parked for 400 HP turbo-4's that see 40's mpg.
    I picked up a GTO to do a twin turbo setup as UPP has a $5K kit and was working on the suspension and brakes and thought I'd check in.
  7. #67
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    67
    13,803
    Quote Originally Posted by NormV View Post
    Don't be such a stranger. Sounds like you're busy.
  8. #68
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    That's why you need racing e-brake pedals!!!
  9. #69
    kciaccio is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Apr 2012
    46
    154
    Change out the factory nav unit with a parrot smart asteroid http://www.parrot.com/usa/products/a...asteroid-smart and you shave about 8 pounds and have a way better head unit.
  10. #70
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    I wish i could do that, my only problem is i drive in a kph country and not a mph...With plenty of speed traps, so i am stuck keepin the oem radio till i break the code on how to switch the mph to kph
  11. #71
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Couple of things to add.
    • FG2 rear shock body: 7.4 lbs each, 8.0" circumference
    • FG2 front shock body: x.x lbs each, x.x" circumference
    • KW Variant 3 rear shock body: 6.0 lbs each, 6.25" circumference
    • KW Variant 3 front shock body: 8.6 lbs each, 6.25" circumference
    • OEM motor mount: 5.0 lbs
    • Creative Steel motor mount: 2.0 lbs
    • Hotchkis 2280 front sway bar: 9.0 lbs
    • Hotchkis 2280 rear sway bar: 7.4 lbs
    • Addco 2290 front sway bar: 28.5 lbs
    • Addco 2289 rear sway bar: 14.4 lbs
    • AD244 alternator: 14.5 lbs
    Do you think we should create a sticky that compiles all of the weight information we've compiled thus far?
  12. #72
    Idahoctsv is offline Cadillac Owners Member
    Automobile(s): Cts, Cts-V
    Dec 2013
    6
    V1 weight reduction
    Interior of my V is completely stripped. No seats, floor mat, sound system, dash, power windows(in process) And trying to remove all wiring as possible. That's my hault, anybody help me on all the wire I can get rid of and what I need to keep? Car is for drag/street. Thanks
  13. #73
    Mar 2011
    2,045
    Re: V1 weight reduction
    Google CTS-V weight reduction.
  14. #74
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    67
    13,803
    Naf ground off the welds.
  15. #75
    Junior1's Avatar
    Jun 2008
    1,248
    Long drawn out process. I had a shop do mine as there are certain wires that will render the car useless without them...
  16. Remove Advertisements
