10AN Oil Cooler set up
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
2004-2007 Cadillac CTS-V Performance Mods Discussion, 10AN Oil Cooler set up in Cadillac CTS-V Series Forum - 2004 - 2007; Sorry I don't have all the pics quite yet. Set up is a Setrab with 10AN Aeroquip forged fittings and ...
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Sorry I don't have all the pics quite yet. Set up is a Setrab with 10AN Aeroquip forged fittings and Aeroquip Starlight Kevlar race quality hose. The only way to get a 10AN to fit was to go to a remote filter. Its located behind the front fender liner and is solid and protected. The lines run forward under all the plastic skid plate crap and then over to the filter then to the thermostat and then the cooler. You'll have to remove the drivers side wheel and the plastic liner to change the oil. This is no lazy mans set up for sure. I have some better pics coming in a few days that show the remote filter. The challenge was always the tight fit from the headers. Not much room for a sandwich plate and fittings under there. The filter by pass plate was all we could figure out. I spent over $200 on different sandwich plate and tried to make them fit (no way with 10AN). As a bonus, with this set up an Accusump is a breeze to hook up now. Just tap the return line with a one way valve and hook up the accumulator. Pretty straight forward since all the hard work is already done.
    On the street while thrashing the car around for an hour or so, the oil temp never went over 195. I'm hoping I can hold the low 230' on the road course. Oil pressure is perfect. Can't tell any different from a "no cooler" set up.
    I'll have some better pics from the lift later this week. I did these with a jack in my garage and didn't remove any plastic covers.
    http://s879.photobucket.com/home/msu...cket/allalbums
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Re: 10AN Oil Cooler set up
    Hmmm, all that work and you could have done exactly the same thing with LPE oil cooler adaptor.
    I also routed the hoses in a creative way...I used the starlite hoses and perma-cool aluminum high flow oil cooler. Kept the oil filter in the same location, and it the pressure remained constant and temp much lower...Before my temps were 105c for the oil temp and 95-98c for water temp...
    After thermostat and oil cooler, i dropped to 91c oil temp and 91c coolant temp. On the track my water only climbed to 95c and my oil temp 121c. Not bad when you think about it...
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,299
    Which headers do you have, Naf?
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by Naf View Post
    Wrong Naf. LPE does not fit my Kooks headers.
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    Must be a tight fit...I would be careful of your wires then...
    For me to get this to fit i had to remove my SW headers install everything and try fit the headers. If it did have adequet clearance, i took it all apart and tried tried again...
    Feb 2007
    Cheese land
    1,596
    Hmmm.....all that work and you could have just done a remote filter.
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    In the end, i got my kit done as much as you did, except they didnt have to ask me everytime where the filter was when i did an oil change...
    Now i have a remote filter due to my dry sump system...Am thinkin where i am goin to tuck that little guy now...
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Awesome! Price/parts list please.
    me needz oil cooler
    Feb 2007
    Cheese land
    1,596
    http://i879.photobucket.com/albums/a...otefilter1.jpg
    http://i879.photobucket.com/albums/a...motefilter.jpg
    Here are a few pics of the remote filter mounting and the line hook up to the cooler. The spot behind the cover in the front fender well is cozy and clean. Location gives you some options for longer filters if necessary.
    Spin on plate and remote filter mount is from Earl's
    Lines and fittings are Aeroquip Starlight and forged 10AN
    Inline thermostat is Mocal
    Cooler is Mocal Matrix (several sizes available)
    Stuff can be found all over the net.
    serik is offline Cadillac Owners Member
    Automobile(s): 2005 cts-v
    Jun 2010
    28
    31
    if you want a esiear rout u can pick up a radiator from performance raidators about 190$ and they have bottom cooling core that has i belive 10an fittings with the cooler inside the rad thats sealed off so u can use the cooler or not use the cooler just would need to run lines thru to the rad from oil pan
    AAIIIC's Avatar
    Aug 2007
    6,299
    I only see that on the 3.6 radiator, not the LS radiator. And I would be surprised if that was intended for use as an engine oil cooler; most OEM radiators with a built-in cooler like that are for tranny fluid. If that's the case, the actual cooler core inside the radiator probably is smaller tubing that would pose a significant restriction to oil flow.
    Aug 2007
    Arlington, VA
    31
    1,647
    Just wanted to bring this back up. Have you had any issues since with this set-up? I just put in an order for a Ron Davis radiator with built in oil cooler and am pretty sure I want to go the route you did. The radiator will have 10AN fittings for the oil cooler. What/where did you get the inline thermostat?
    Feb 2007
    Cheese land
    1,596
    http://www.pegasusautoracing.com/pro...p?Product=1226
    No issues with Mocal stuff so far.
  16. #14
    Aug 2007
    Arlington, VA
    31
    1,647
    Cool. Thanks for the link. I've ordered from Pegasus quite a few times before. I think I'm going to go ahead and copy your setup. I like the remote filter location. While pulling the liner is a bit of a pain, once done, it looks like there's plenty of room to get a hold of the filter. Easier to manage in a garage and plenty of room for a longer filter. I'll have to look up the biggest Amsoil filter that can fit there (I'm a dealer). How much more oil capacity did you gain with your set-up? This may sound like a stupid question, but how do you go about filling/draining? Fill, get up to temp and refill again?
    I'm sick of the stupid oil temp slowing me down, so looking forward to finishing up this project. I broke my humerus in half though, so doing things one handed is kind of a pain...
  17. #15
    Feb 2007
    Cheese land
    1,596
    A few more shots of the inner fender mount.
    You never get every drop of oil out but you probably don't let it go to long anyway.
    It's just like you described. You need to keep checking and top off. The additional capacity is way less than a quart.
  18. Remove Advertisements
