10AN Oil Cooler set up - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
2004-2007 Cadillac CTS-V Performance Mods Discussion, 10AN Oil Cooler set up in Cadillac CTS-V Series Forum - 2004 - 2007; When I added a cooler on my Moostang, I figured the additional capacity based on the cooler size (Mocal's specs ...
  1. #16
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,540
    Re: 10AN Oil Cooler set up
    When I added a cooler on my Moostang, I figured the additional capacity based on the cooler size (Mocal's specs include the actual capacity of the cooler) + the amount in the lines (somewhere I found a thumbrule of 0.xx qts per ft of -10AN). I think it was right around a quart extra on that car - it has a 25row cooler, so that alone was 0.55qt.
  2. #17
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    I think the oil in the cooler may not all drain out when changing the oil on mine. If it did I bet it would be an additional quart as well. Probably was when I first installed it and filled it the first time I added one extra quart.
  3. #18
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Aug 2009
    Michigan
    576
    Nice work. If you were to go with a dry sump system, where would you put the tank?
    What size front tire/wheel combo do you run on the track?
  5. #19
    Feb 2007
    Cheese land
    1,596
    I'd probably go with an Accusump. All thats needed now is a T fitting in the return line. I'd probably have to think about a mounting spot. Not much room up front.
    I've run stock tire sizes on the track most of the time. This year I'm running 275/35s on Team Dynamics like AAIIIC is. I also have a set of KW Variants for this year as well.
  6. #20
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    What 275s are you going to be running? That's the same size I'm going to run as well with R6s. Still going to be on the stock FE4s though sadly.
  7. #21
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by UnsafeAtAnySpd View Post
    On the street I run Yoko Advan AD08s in the stock size. I have rebadged R6s from the GrandAm series (Continentals) in the 275 size. In the spring I will be unloading my trusty H&R / FG2 (only 20K miles) set up which I really am a big fan of. I hope the KWs perform as well. I'm sure they will.
  8. #22
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
    Quote Originally Posted by crankedupforit View Post
    This post reminds me - I've got an Accusump sitting in my garage that I need to install. After looking at several locations I think I am going to fabricate a braces attached to the two points where the radiator sits. if I do that, I will remove the radiator and drill through bottom for the mounting bolts.
  9. #23
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by darkman View Post
    Love to see it. Keep us posted. I guess the spare tire tub is to far away huh?
  10. #24
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    The spare tire tub is not necessarily too far. I discussed locations with Canton Racing's technical folks and they reported a lot of sedans run them in the trunk. They even said that 10 AN would be large enough line for that application. I would be tempted to run 12AN over at least part of that distance or maybe just opt for a higher pressure valve. You could call Canton and ask - they are pretty accessible.
  11. #25
    AAIIIC's Avatar
    Aug 2007
    6,540
    A few more shots of the inner fender mount.
    I still have yet to get my setup figured out. Unfortunately, your filter location would interfere with my new brake cooling ducts. (Pictures of that to follow soon, I need to update the brake cooling duct thread.)
    The other unfortunate thing is that Earl's doesn't make the spin-on adapter you used in the 13/16"-16 thread. I see it listed for under $35 on Summit Racing. The only equivalent piece I've found is from Hamburger's and costs >$100 on Summit and it has -12AN ports, which means even more money for fittings!
  12. #26
    Feb 2007
    Cheese land
    1,596
    Good luck with finding a spot for that filter. Not a lot of good options unfortunately.
    Sounds like you found a suitable spindle plate for the ducts. Love to see it.
  13. Remove Advertisements
