Best "Bang-for-your-Buck" Road Course Mods? - Page 8
Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 106 to 112 of 112
2004-2007 Cadillac CTS-V Performance Mods Discussion, Best "Bang-for-your-Buck" Road Course Mods? in Cadillac CTS-V Series Forum - 2004 - 2007; What tire pressures to run depends on many variables but the rule of thumb I know is to start at ...
  1. #106
    JustinC is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Feb 2010
    38
    60
    Re: Best "Bang-for-your-Buck" Road Course Mods?
    What tire pressures to run depends on many variables but the rule of thumb I know is to start at +2psi over manufacturers recommended pressure for autox and RR. That would be 35psi for our cars.
    The everyday variables from then are: Driving style, weather, temp, top speed...
    I like to use both temp and chalk to dial in a tire pressure at the track.
    Especially at autox where you dont have alot of time/runs to figure out temps. I would assume most are running 38-40psi hot at the track with good results no???
  2. #107
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,317
    On street tires, yes, I've found around 40psi hot seemed to work well.
    On R-compounds, no, I've found 40psi to be too high and the tires start to feel squirrely. That's with Nitto NT01s and Hankook Z214s. Other tires may be (will be) different.
  3. #108
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Mar 2005
    Gillette, WY
    35
    1,620
    Quote Originally Posted by AAIIIC View Post
    Yeah, now that I think about it, I was wanting to have my R888s up to just under 40 psi (hot)...maybe 38 psi...in order to not get that greasy feeling at high speeds. So that means that I was most likely starting at, or just under, 30 psi last time I was at the track.
  5. #109
    Slartibartfast is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Feb 2011
    56
    9
    It definitely depends on the tire. Hoosiers (R6s) like to be high-30s to 40 hot, but Toyos (especially RA1s) and Nittos like much lower pressures. Not all R-comps are created equal (by a long shot) so knowing what the specific tire you're using likes will make a difference.
    Setting pressures based on handling seems to be more effective for many people than chalk or other tricks.
  6. #110
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    I would like to start taking my V to the track this year, and I've been shopping around for a helmet. For all the track days / different organizations that you guys are running with would I be able to get away with an M rated helmet? I know that MVP track time (Mark Pfeffer) requires the SA rating, but I wasn't sure how common that requirement really is.
    I've been mostly looking at the entry level SA full face helmets which seem to start at about $250 and go way up from there. I'd appreciate any recommendations that you guys have for brands or features that you think are worth the extra money.
  7. #111
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    try them on. helmets don't all fit the same. get an SA helmet. you'll probably find the SA2005 helmets are cheaper since they'll last 5 years less than the SA2010 that are out.
    fwiw, some tracks are now requiring full face...like Monticello or NJMP...I forget. plus, if you do any karting, you'll need full face.
    I bought my Bell from OG Racing www.ogracing.com
    here's one that it's a great deal:
    http://www.ogracing.com/catalog/1-Dr...-SA2010-HELMET
    another:
  8. #112
    JDB's Avatar
    JDB
    Apr 2010
    PA
    1,070
    As far as the OP's question... forget the mods. V already has plenty of power, big brakes, and suspension isn't that bad. It's plenty of car right out of the box to be fun and quick around the track. I have not tracked my V (yet), but I have plenty of track experience in other cars. and, seat time will make you faster than anything. fresh fluids, some track pads up front (at least Hawk HP+, but a more experienced driver should use something better suited for race only) and half of stock in the back, some decent summer tires and go... have fun.
  9. Remove Advertisements
