Best "Bang-for-your-Buck" Road Course Mods? - Page 5
Page 5 of 8 FirstFirst 12345678 LastLast
Results 61 to 75 of 112
2004-2007 Cadillac CTS-V Performance Mods Discussion, Best "Bang-for-your-Buck" Road Course Mods? in Cadillac CTS-V Series Forum - 2004 - 2007; XP16 and XP12...
  1. #61
    v-sam's Avatar
    v-sam is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    May 2005
    cary nc
    247
    Re: Best "Bang-for-your-Buck" Road Course Mods?
    XP16 and XP12
    2005 CTS-V:Ground Control 650/700|FG2|Corsa|UUC Shifter and Shift Knob, Brake Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|Eibach Sway Bars|Kooks 1.75 Coated and High Flow Cats|Upper Control Arms|Front and Rear Strut Brace|Power Steering Cooler|Oil Cooler|LED Lights|ARP Wheel Studs|Corner Weighted|Stealth V Tune
  2. #62
    Sigfod's Avatar
    Sigfod is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Oct 2010
    Sterling, VA
    169
    Quote Originally Posted by AAIIIC View Post
    Which Carbotechs are you guys running?
    I am very interested in this as well. I have done 18 track days thus far with the NCCBMWCCA in my track car and two of my DD. I do believe you should start on the track with a slow car and only improve the car when the car becomes the limiting factor instead of you.
    After reading this I am going to try the Ti shims, and hopefully they will help with the track car. I will also skip the HPS pads, as some have mentioned these are a step back from stock. I wonder which pads people recommend that will work as well if not better than stock, and will not squeal. The main concern to think of is that this is a street car occasionally driven on the track, so I don't want to make any changes that will significantly hamper the comfort of the car.
    I have a proposed list of mods.
    Brake Pads / Fluid (ATE Super Blue)
    SS Lines
    Ti Shims
    Cradle Bushings / BMR wheel hop kit w/ bushings
    CAGS eliminator
    Short Shifter
    Wheels / Tyres
    KW V3 suspension w/ 10k / 10k springs
    As for Carbotech pads, on the track car, I run XP8 F/R, but I may be switching to XP10 if the Ti shims don't work.
  3. #63
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,372
    Where can you get the Ti shims? Do you have a link? thanks.
  5. #64
    Sigfod's Avatar
    Oct 2010
    Sterling, VA
    169
    Quote Originally Posted by odla View Post
    Front Ti Shims
    Rear Ti Shims
    Adjustable Sway Bar End Links
  6. #65
    rjoffe is online now Cadillac Owners Connoisseur
    Jul 2005
    1,897
    ctsvparts.com
  7. #66
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,381
    Quote Originally Posted by v-sam View Post
    XP16 and XP12
    Well, I tried the XP16s and can't say I'm impressed. Braking performance was no better than it was with the Hawk DTC70s - if anything, it may have been a bit worse. And more importantly, the life of the XP16s is too damn short - 2 days at Summit and they're toast! Down to maybe 1.5mm of material left, so I won't even bother starting my next event with them on the car.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  8. #67
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Thank you. Good feedback. I went with ST42s but always wondered about the Carbotechs.
    Do Carbotechs require the rotor surfaces to be free of previous brake pad materials?
  9. #68
    AAIIIC's Avatar
    Aug 2007
    6,381
    I assume so - that's seems pretty standard with most pads. I prepped the rotors like I always do when I'm changing to different pads.
  10. #69
    Feb 2007
    Cheese land
    1,596
    From the Carbotech site.
    If rotors were previously bedded using a different manufacturer’s brake pads; then it is strongly recommended that the used discs (rotors) be reconditioned/turned and meet minimum specification requirements.
    Reconditioned?? As in machining?
    I always stayed away from Carbotechs because of this. Especially if you go back and forth from street pads to track pads. I'm thinking a Scotchbrite pad may not get the job done and the ceramic compound doesn't like the metallic stuff embedded in the rotor.
    You an I are in agreement with most turning recommendations (waste of time) except I wonder if the friction material is all that different then it's really necessary.
  11. #70
    soflarick's Avatar
    soflarick is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Sep 2009
    Florida
    626
    RB recommended procedure is to use fine steel wool and brake cleaner on the friction surface to prep it for another compound pad.
  12. #71
    soflarick's Avatar
    Automobile(s): none
    Sep 2009
    Florida
    626
    What tires are you two using with the Hawk and Raybestos pads?
  13. #72
    AAIIIC's Avatar
    Aug 2007
    6,381
    Nitto NT01s before, Hankook C51 Z214s now.
  14. #73
    Feb 2007
    Cheese land
    1,596
    Yoko AD08s with the ST42s. Street and track set up. Track set up R6s.
  15. #74
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    Quote Originally Posted by crankedupforit View Post
    I see that you and unsafeatanyspeed both run the R6s. I was always thinking about the R1s, but maybe the R6s are better. Can you tell me why you chose one over the other?
  16. #75
    Feb 2007
    Cheese land
    1,596
    R6s,as rebadged Continentals, are pretty plentiful right now coming off the Grand Am circuit. They can be had pretty cheap. I think the R100s are full racing slicks while the R6s are DOT and have two grooves. A guy I know who runs GT Trackdays said the R100s are super sticky but when they let go it's all over. R6s are a bit more progressive but certainly not as forgiving as a street tire. If the price is right R6s are hard to beat and are considered by some as the benchmark of DOT slicks. For me it was about cost. Good used R6s with 75% or more tread life are cheap right now.
  17. Remove Advertisements
