Broke a valve spring *PICS*
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
2004-2007 Cadillac CTS-V Performance Mods Discussion, Broke a valve spring *PICS* in Cadillac CTS-V Series Forum - 2004 - 2007; So a month or two ago I started hearing a louder than normal ticking form the driver side of the ...
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    So a month or two ago I started hearing a louder than normal ticking form the driver side of the engine. I chalked it up as me being hypersensitive. About three weeks ago I was going WOT and at 5000rpm the car acted as though it hit the rev limiter. it completely dropped power. I thought it was an issue in the tune so I finally made it to SNL today to get my problem dealt with. After some data logging it cylinder 5 was misfiring. We swapped the plug and plug wire, no difference. Opened up the valve cover and BINGO!
    They swapped it out for a new one and now its good as new.
    By the way, my springs are PRC dual spring .675".
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Re: Broke a valve spring *PICS*
    At least you didn't drop that valve! Those dual springs saved your butt!
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by ctsv154 View Post
    I know! I am so thankful I went with the dual springs.
    No other damage, just the spring. Glad it wasn't worse.
  5. #4
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,786
    Lucky you.
    You would be surprised (maybe not) how many Vettes suffer from broken valve springs.
    Dual springs are cheap insurance.
  6. #5
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    67
    13,803
    Quote Originally Posted by heavymetals View Post
    ... You would be surprised (maybe not) how many Vettes suffer from broken valve springs. ...
    Yup. Even back in '73, I broke two intake valve springs on my '69 Vette.
    Glad you got this one figured out quickly and relatively painlessly, whisler.
  7. #6
    lilgCTS-V is offline Cadillac Owners Enthusiast
    Automobile(s): 06CTS-V BOLT-ON,06JEEP TJ BUILT, 91 350SDL turbo(daily)
    Nov 2008
    967
    do you think that was what was causing your V to drive all funky when ur rpms were dropping and what not.
  8. #7
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by lilgCTS-V View Post
    Nope, that wasn't it. It still does it. Of course when I was at SNL I couldn't get it to do it. I think it may be the hot ass weather in conjunction with the cam. Oh well, I've learned to live with it.
  9. #8
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    i was expecting alot more carnage when i opened this thread up... im glad i was wrong..
    So how many miles did you get before the spring broke?
  10. #9
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by shadybx7 View Post
    I'm glad I did the dual springs. Had I not then there would have been a lot more carnage. The secondary spring kept me afloat for well over a month.
    Springs had 10,000 miles.
  11. #10
    CTSV_Rob's Avatar
    CTSV_Rob is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2007 CTS-V Thunder Gray; 2004 Cowboy Cadillac (SRT10)
    Mar 2007
    Sunny CA.
    50
    17,669
    How much lift do you have in that Cam Whisler?
  12. #11
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by CTSV_Rob View Post
    Around .610 and .640 I think.
  13. #12
    Nov 2004
    8,786
  14. #13
    Nov 2004
    8,786
    bump
  15. #14
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    My shop swapped out the .675" lift springs to .650". I guess they were having some problems with the .675s. After 2 popped springs all is good now.
    I'm still getting the P0300 code often. I think it may be due to a loose plug wire. Have the FireCore wires ordered. Hope that fixed the code issue.
  16. #15
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    29
    979
    im planning on replacing my stock valve springs. Any benefit on a stock cam to run dual spring over single springs? I'm deciding between the comp cams 26921 (dual springs) and 26918 (single spring)... opinions?
  17. Remove Advertisements
