some questions for the guys who have done headers
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
2004-2007 Cadillac CTS-V Performance Mods Discussion, some questions for the guys who have done headers in Cadillac CTS-V Series Forum - 2004 - 2007; i finally got around to installing kooks 1 3/4 headers on my 06. wasnt too bad but did run into ...
    EHam is offline Cadillac Owners Member
    Automobile(s): Cadillac CTSV
    Nov 2008
    Charleston, SC
    33
    26
    i finally got around to installing kooks 1 3/4 headers on my 06. wasnt too bad but did run into a few small problems. i used ARP studs. drivers side went right in but i couldnt get the pass. side in w/o taking off the 4 center studs and replacing them with the bolts provided. no big deal but not too happy about spending $100 and couldnt use all 12 studs. also the front o2's were a PITA since the extentions supplied wouldnt work. my only problem now is the wires touching one of the primarys on the drivers side. the headers are jet-hot coated and the wires have that reflective tape on them but im not sure if this is going to be enough? any ideas on this besides header wrap? i have to drive 3.5 hours to get it tuned next week and i dont want to burn any wires.
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Re: some questions for the guys who have done headers
    What was up with the extensions? Also, I did't use my extensions because they were just too long and I dont have any issues with them touching the headers. Any way you can re-route them to get them off the headers?
    Nov 2008
    Charleston, SC
    33
    26
    the extention connections dont match up. i had to pull the black piece off the back of the heads to get more slack otherwise they wouldnt reach. i should clarify my post....its not the o2 wires touching the headers. im not even sure which wires they are. ill get a better look in the morning but they appear important since they came wrapped up from the factory.
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,813
    They appear important?
    I'd suggest sleeping on it, then take another look in daylight. I'm sure you'll be able to find somewhere to tie them up to and out of the way.
    Get that tune, then poast back up here and tell us how they sound.
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Ya get it off the header. Mine is held off in one spot with a few zip ties linked together!
    856V is offline Cadillac Owners Member
    Automobile(s): 05V
    Aug 2010
    49
    i did arp studs when i did my 1 7/8 kooks... only had to pull the pass rear one.. but then put it back in once the header was hung... mine arent coated and i only have thermo sleeves on my wires... 25k miles on em and no problems!
    Nov 2008
    Charleston, SC
    33
    26
    i got a better look at the wire that was touching the header and it turned out to be the alt. wire. i remember reading about someone putting a hole in the tube when it burned through the insulation so i moved the wire around and zip tied it. theres about a 1/2 inch gap which i hope is enough. i was going to purchase some plug wire thermo sleeves but it seems they wont fit around LS2 wires. any LS2 guys encounter this problem? im hearing some strange noises but ill wait till after the tune to judge. people sure dont know what to think about this Cadillac though.
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Those grey connectors are for the rear two o2 sensors...The front two just need to to have a couple plastic clips pulled out to reach...I was missin the rear two extentions and man what a pain in the butt...
    Dont worry too much about the tune, you are just merely runnin a little rich. Ur mpg will be off a little till you get a proper tune...
    Zo6PwRd Guest
    ^^^ MAybe its just me but if i spend 1000 plus dollars on headers and spend 4 hrs installing them, im gonna want a tune to maximize the gains and have the car run perfect. Thats just me though.
    Automobile(s): 05V
    Aug 2010
    49
    Quote Originally Posted by Zo6PwRd View Post
    yea me too!
    JSR
    JSR is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V
    Jun 2010
    Virginia Beach
    35
    12
    I recently installed the same Kooks 1 3/4" set and ran into the same problems with the O2 extensions and the wires.
    The O2 extensions are simple. Just lake a sharp flat screwdriver type thing and remove the one ridge that prevents the connector from seating. Take a look at the factory connector that it goes in place of and see how it needs to be removed.
    As for the wires, I took a 8" long piece of 1/2" wide sheetmetal and notched it to fit behind one of the bolts holding on the oil filter housing. The sheetmetal is stiff enough to keep it pushed away from the primary far enough away.
    As far as the tune...does anyone have experience with Wiggins Racing and Performance in NC?
    lilgCTS-V is offline Cadillac Owners Enthusiast
    Automobile(s): 06CTS-V BOLT-ON,06JEEP TJ BUILT, 91 350SDL turbo(daily)
    Nov 2008
    967
    i have my headers jet coated, and my wires are touching im just gunna let it rip i could care less 15k miles not a single problem
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    If you are talking about the spark plug wire touching the headers, wrap the headers or get cool sox. I wrapped my B&B headers (looove em), and my back driver's side wire is laying on the header and I haven't had any problems (knocking on wood)
    I didn't need extensions on my O2 sensors, they were long enough. I also used stock manifold bolts and gm gaskets on my headers, and they work excellent!
    Question: if the headers are coated, why is there tape on em?
  16. #14
    ranger2525's Avatar
    ranger2525 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cts-v,2003 escalade,2000 corvette conv. 1996 harley, 20
    Jun 2010
    Overland Park, Kansas
    52
    142
    When you guys say GM gaskets, do you mean stock exhaust manifold gaskets or does GM make header gaskets?
    Scott
  17. #15
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by ranger2525 View Post
    Scott
    Stock manifold gaskets.
  18. Remove Advertisements
