some questions for the guys who have done headers - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
2004-2007 Cadillac CTS-V Performance Mods Discussion, some questions for the guys who have done headers in Cadillac CTS-V Series Forum - 2004 - 2007; Thanx Cancer!! If there are any other things I should know please respond to this thread. I work @ a ...
  1. #16
    ranger2525's Avatar
    ranger2525 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cts-v,2003 escalade,2000 corvette conv. 1996 harley, 20
    Jun 2010
    Overland Park, Kansas
    51
    142
    Re: some questions for the guys who have done headers
    Thanx Cancer!!
    If there are any other things I should know please respond to this thread. I work @ a dealership, Honda/ Subaru as the parts director so tools should not be an issue. But I would like to have any other things I need on hand. As rack time is @ a premium.
  2. #17
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    67
    13,803
    First of all, go here --> http://www.cadillacfaq.com/faq/answe...ers/index.html
    If you do Kooks, the biggest difference is the steering shaft. You have to remove a bolt and swing the shaft to the side, install the header, then rebolt the shaft together ... 1/2 minute tops. DON'T turn the steering wheel while it's disconnected. Not absolutely certain with TPIS, Katech, or the newer brands that have come out recently.
    Lastly, the above install procedure omits mention of putting the dip stick tube back in place. I personally just about crapped my pants trying to get it back it (I finally did ... get it in, that is), and others have had their cars towed to a shop to reinstall it when they were unsuccessful, so just FYI.
    Having access to a lift is a big plus. You'll do great.
  3. #18
    ranger2525's Avatar
    Jun 2010
    51
    142
    Thanx for all the great info guys! I'll repost when done. Camshaft next. So I will be leaning on you guys once again.
    Scott
  4. #19
    CI-V-IL is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Raven Black CTS-V
    Dec 2010
    Fishers, IN
    135
    Rockauto also has MLS exhaust manifold gaskets for less than half of the price of the GM ones.
    http://www.rockauto.com/catalog/moreinfo.php?pk=2652610
    I, unfortuantely, bought GM gaskets and found these a few days after.
  5. #20
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by rand49er View Post
    Just to reiterate Randy's pointer. If you do you will be buying an air bag clock spring. Tie the steering wheel in place or something when you have it disconnected. Not a step to be taken lightly...
    Quote Originally Posted by CI-V-IL View Post
    I have re-used my OEM manifold gaskets 3-4 times now with zero issues.
    Also to further the discussion on the dip stick...It really isn't that hard to get back into place but rather getting it COMPLETELY seated is the issue. Before you remove it make sure you see where it goes into the block. Then when you are done ensure the "ring" around it is seated flush or you will get a leak.
    With my B&B I had to do some light grinding on the dip stick where it bolts to the heads. I think someone else did also. Of course I think there are probably some variances on the dip stick and its bends so that might not apply to you.
    Bottom line SEE and FEEL what "good" is like before you start so you know what you need to go back to.
  6. #21
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    36
    1,747
    Damn, I've done headers 3 times now on Vs and it never gets easier lol. The o2 extensions work on the 04-05s but for some reason don't clip in for the 06-07s. But the 06-07s don't need them if you free up slack in the wire.
    Ive been burnt on the "don't spin the wheel with the steering shaft disconnected" bug. Its a $500 mistake.
    My 1 7/8's headers rubbed on the shaft, but nothing a few blows from a dead blow plastic hammer couldn't fix.
    I've also reused gaskets a few times and never had any leaks.
    Regarding the ARP studs, I had a pain with them too. I had to have someone hold the header from below while I hand threaded a few studs enough to hold the header up on its own.
    Thats just my .02 Cents from multiple installs/removals.
    Anywho, I have a set of barely used o2 sensors from my 05 V available for sale. PM for details.
  7. #22
    Cobrahunter's Avatar
    Cobrahunter is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Black Cts-V
    Jun 2009
    Dayton, OH
    117
    I used GM OEM LS1 manifold Gaskets & these spark plug wire covers http://www.summitracing.com/parts/DEI-010502/
    no leaks & no wires melting
    I was able to untangle my 02 wires & made them reach w/out extensions
  8. Remove Advertisements
