Maggie owners check for this
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
2004-2007 Cadillac CTS-V Performance Mods Discussion, Maggie owners check for this in Cadillac CTS-V Series Forum - 2004 - 2007; I mentioned this in another thread. Remove the vacuum line to the brake booster (maggie end) and swab the hose ...
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Remove the vacuum line to the brake booster (maggie end) and swab the hose for oil and the barb fitting.
    If you get oil you need a catch can.
    Mine was full to the top of the fitting and there was a pool inside the maggie.
    One catch can (I have duals) was oiled up and runs to the same vacuum fitting (the other side) as the booster.
    The other catch was connected to a fitting on the maggie further upstream and I guess has less vacuum as it wasn't oiled up.
    So.....
    I am gonna connect one catch can (a bigger one) with dual fittings and see which vacuum fitting works the best.
    Also, upgrading all the 3/8" vacuum line to silicone.
    Got it here: http://boostcontroller.com/
    MOD HELL
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    Quote Originally Posted by heavymetals View Post
    So.....
    MOD HELL
    Any chance you can snap some pics of the lines you routed to the catch cans. I'm still baffled by which lines to catch oil from and having the ls2 doesn't help as no one seems to have done it.
    Nov 2004
    8,788
    Re: Maggie owners check for this
    I think the LS2 has a built in breather near the back of the motor and is part of the valley cover.
    That's where most trucks put them........
    Here is a link:
    http://forums.corvetteforum.com/c6-t...to-needed.html
    Should be duck soup to grab that line and add a catch can to it.
    The LS6 has one each on the valve cover.
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    Hmmm...I'll check this out tomorrow. Thanks for the info.
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Oh, man ... I am so far behind doing all this checking stuff. Loose bolts on H-E axles. Loose header bolts. IAT Twitch-Fix. Oil pressure sender that's kerfloohey and on and on. When does it end?!!
    Nov 2004
    8,788
    Quote Originally Posted by rand49er View Post
    It ends when you sell it or wreck it or it gets stolen, although it might get recovered (Murphy's law).
    I gave up model airplanes for this.
    greddy91's Avatar
    greddy91 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Sep 2008
    38
    117
    Quote Originally Posted by ichpen View Post
    x2 for pics of Heavy's engine bay.
    Nov 2004
    8,788
    Here is one.
    The MSD coils are gone as I just had too many failures.
    ichpen's Avatar
    May 2008
    1,383
    Here is a link:
    OK, I'll have a better look tonight.
    Stepside is offline Cadillac Owners Enthusiast
    Automobile(s): '06 DTS performance; CowboyCadillac='12 SVT Raptor
    Oct 2009
    NW Jerzey-in the sticks
    67
    631
    I installed this "catch-can" yesterday on my LS2.
    Click on picture and then click again to enlarge it in a separate window.
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Looks good, Stepside. I gotta do this.
    ichpen's Avatar
    May 2008
    1,383
    Quote Originally Posted by Stepside View Post
    Why does this look different on my maggie then. Only have the two hoses going into the maggie on driver side. I'm assuming the top one needs to be tapped for oil.
    Catch can is also on the passenger side Hopefully length of hosing won't cause issues.
    ichpen's Avatar
    May 2008
    1,383
    Here's the image.
    Actually just made sense of the earlier pic. Bottom hose out of the two that are on top of each other would be the candidate.
    Is that some sort of a pressure gauge or check valve I see on the catch can?
  16. #14
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    Looking at those pictures. I would say you have it installed incorrectly. The line has no restriction in it so it would technically be a vacume leak at that point. You should run a PVC valve or equivalent in that line going to that port. That would be why you are getting alot of oil. It is just sucking it right out off the rocker assembly inside that valve cover.
    I usually run BOTH top ports to one single line, then put a PVC valve inline on the single line and install it on the large vacume port you are using. That way it is regulated and not such a large leak, then at wot, it will open the pvc valve and allow blow by to leave the crank case as designed..
  17. #15
    ichpen's Avatar
    May 2008
    1,383
    Quote Originally Posted by wait4me View Post
    My pic? Or the oil catch can pic from the other guy?
    And yes I think a check valve is in order with or without a catch can. Any recommendations on check valves and places to get them from?
  18. Remove Advertisements
