Poly swaybar bushings - anyone tried some "universal" ones? - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
2004-2007 Cadillac CTS-V Performance Mods Discussion, Poly swaybar bushings - anyone tried some "universal" ones? in Cadillac CTS-V Series Forum - 2004 - 2007; I do believe that energy suspension makes sway bar bushings of all sides. all you guys need to do is ...
  1. #31
    incubusjunkie614 is offline Cadillac Owners Member
    Automobile(s): none
    Mar 2011
    29
    Re: Poly swaybar bushings - anyone tried some "universal" ones?
    I do believe that energy suspension makes sway bar bushings of all sides. all you guys need to do is buy the bushings in whichever size you have. You use the D brackets that typically come with the bushings and you can order front adapter blocks and hardware straight through hotchkiss.
    http://www.hotchkis.net/_uploaded_files/2279.pdf
    the entire parts list should be on the last page, you can call and order exactly what you are looking for. I know this because I had to figure it out the hard way when addco sent my tiny bushings with a BIG sway bar.
    For reference the powergrid endlinks are a 10mm bolt size (stock/ no drilling) and are an extremely nice piece. The owner/ CEO. chief of designis also extremely knowledgable and helpful! (no, I am not affiliated with them, I simply like to share positive experiences)
  2. #32
    xbladr is offline Cadillac Owners Fanatic
    Dec 2008
    377
    I ordered the 26mm bushings from energy suspension or prothane can't remember which. I will now also be ordering 2 of these. "16810288" Those I believe are the adapter blocks. This should all work well and be a real simple job.
  3. #33
    dboydr's Avatar
    dboydr is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS 3.6L
    Oct 2012
    Washington State
    38
    44
    I am in the process of finding the correct polyurethane bushings also.... man I wish they just made a set for the CTS-V!!!!
    Anyways, I found so far that the Energy Suspension Greaseable Universals part number 9.5169 (27mm) or 19-1183 (27mm) Prothene is the ones you want for the front with a 1.5" block spacer to offset that odd OEM bracket, I know that the bushing is over sized from 26.6mm CTS-V bar.... But a few people said that is why the rubber ones wore out and one person already tried the 27mm bushing and said it works awesome. Is that correct? Or do You want the 26mm and have a tighter fit on the sway bar????
    The Rear I am having a problem trying to find a 21mm bushing that has the bracket width of 3.50" (OEM eye to eye measurement), the only one that I have found that may work from Prothane or Energy Suspension parts is the part 9.5107 that is 20.5mm and uses the style bracket "B" with eye to eye measurement of 2 9/16 to 3 5/8 “it would work”... But I am not sure if 0.5mm would make that big of a difference in restricting movement of the sway bar? Or if maybe the 21mm polyurethane from part 9.5125 can be taken out and just used in the OEM bracket????
    If anyone knows let me know please!!!
  5. #34
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,298
    I went with 26mm up front, but I don't imagine it matters much either way.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  6. #35
    gatesjeff33 is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V, 20" Vogue rims, LS7 Clutch/Flywheel, Revshift Blue
    Dec 2014
    22
    I bought the poly bushings from creative steel. All I had to do was drill and tap the stock oem brackets for grease zerks and I ended up with great results.
  7. #36
    AAIIIC's Avatar
    Aug 2007
    6,298
    Ahhh, progress. When I started this thread 6+ years ago those weren't available. Definitely makes life easier to have parts designed for the car!
  8. Remove Advertisements
