Diff Differential Bushing Install Removal - Page 7
Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 91 to 104 of 104
Like Tree4Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Diff Differential Bushing Install Removal in Cadillac CTS-V Series Forum - 2004 - 2007; [QUOTE=Gucci05V;2986083]Installed the CS diff bushing and block and last night. Huge improvement in drivability. Just firm hand pressure and it ...
  1. #91
    MotorMounts's Avatar
    MotorMounts is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black CTS-V
    May 2009
    Salem Oregon
    50
    400
    Re: Diff Differential Bushing Install Removal
    [QUOTE=Gucci05V;2986083]Installed the CS diff bushing and block and last night. Huge improvement in drivability. Just firm hand pressure and it slid into place. Does this mean I'm in for trouble down the road?
    You will have no problems, as long as the bushing can't "work" around in the housing you'll be OK, AND you installed the diff block which will be supporting the diff housing from above. Don't give it a second thought.
    Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
    http://www.creative-steel.com
    maxx@creative-steel.com
  2. #92
    Gucci05V is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Feb 2010
    Boise, ID
    49
    20
    Awesome, thanks.
  3. #93
    hawaiianguy is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Mar 2014
    Ft. Hood, TX
    26
    3
    What are the torque specs for the diff bolts and the exhaust flanges? I'm bout to do the install this weekend.
  5. #94
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,180
    See attached.
  6. #95
    Mar 2014
    Ft. Hood, TX
    26
    3
    Thanks brother! That's exactly what I was looking for.
  7. #96
    mattfranz is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jun 2014
    256
    I know this thread is from a while ago and this is probably a stupid question but do you need to put the sleeve back in there when you put the new brushing in?
  8. #97
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,180
    Quote Originally Posted by mattfranz View Post
    The answer would be no, if the new bushing is one of the aftermarket alternatives.
  9. #98
    qboykin is offline Cadillac Owners Member
    Aug 2014
    3
    Can someone tell me where I can buy the bushing? I don't see it on rockauto. I think it is on revshift but I want to make sure I am getting the right one. Can someone assist me with this?
  10. #99
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,823
    Luke at Lindsay Cadillac has the UUC bushing which is the one I have. Scroll up and look on the right column of ads ... his is the first one.
    I believe Revshift has a comparable product as well. Either one will work.
    If you don't have the installation tool, you may want your local repair shop to do the install.
  11. #100
    Kruss is offline Cadillac Owners Member
    Automobile(s): CTS
    Jul 2014
    4
    Great steps and pictures! Thanks for posting!
  12. #101
    CoopV06 is offline Cadillac Owners Member
    Automobile(s): 06' cadillac cts-V
    Sep 2014
    Texas
    1
    Who has a diff removal tool that takes out the factory bushing and sleeve? Without taking the rear diff out of the car. Any info would be great . Thanks.
  13. #102
    vmarks is offline Cadillac Owners Member
    Automobile(s): 2005 3.6L AY6 stock
    Oct 2010
    15
    Quote Originally Posted by CoopV06 View Post
    I did rent a tool from one of our amazing forum members here, but when I was doing it, I found that this worked best for me:
    1. support car.
    2. remove drive shaft from diff, so that you can angle it down a little from the mounted position.
    3. remove bolt from the mount that has failed. Loosen other mounting bolts but do not remove.
    4. with diff pointing downwards so you have access to the failed mount...
    5. get a fine toothed or diamond hacksaw. assemble with the blade inside the mounting hole, blade teeth pointing into the saw.
    6. go slow, and keep it straight as you cut. you will eventually cut through the steel bushing that the failed rubber mount lived in. Do not cut the aluminum, please.
    7. cold chisel and pliers/vice grips will let you curl up the edge of your cut into the mounting hole, and then a mallet will let you hammer it out.
    There are youtube videos of people doing similarly with a sawzall power tool. This was scary for me, it goes way too fast and I'm sure they marked up the aluminum, where I didn't want to.
    This was pretty easy. I replaced it with the poly UUC busing and haven't thought about it since. Use proper lock-tite and torque on the driveshaft and diff mounts.
  14. #103
    osoriag is offline Cadillac Owners Member
    Automobile(s): CADILLAC CTS 06 6V 3.6L
    Nov 2014
    30
    1
    Hello. I been having this problem with my CTS, I´ve already replaced the rear bushing twice (with OEM) within 2 years. You know where can I buy a bushing of better quality.
    Thank you
  15. #104
    CSTech's Avatar
    CSTech is offline Cadillac Owners Member
    Automobile(s): 04 CTSV
    Jul 2013
    50
    Kind of a late response, but we have the bushing you need. And the tool to install it. PM sent
    Jordan @ Creative Steel Inc.
    503-316-1811
    Open M-F 8:00-5:00 PST
    Jordan@creative-steel.com
    Check us out at: http://www.creative-steel.com
    We're on Facebook! https://www.facebook.com/pages/Creat...39612609499435
  16. Remove Advertisements
