Diff Differential Bushing Install Removal - Page 4
Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 105
Like Tree4Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Diff Differential Bushing Install Removal in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by PISNUOFF Youtube - hotrodctsv Hahah, NICE....
  1. #46
    SkullV's Avatar
    SkullV is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Re: Diff Differential Bushing Install Removal
    Quote Originally Posted by PISNUOFF View Post
    Hahah, NICE.
  2. #47
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by lollygagger8 View Post
    Not everyone has a press like whoever you had put yours in. Also, if you had to use a press, you would have to take the diff out of the car, no?
    Quote Originally Posted by CancerJCC View Post
    He didn't (use a press) he used a socket and hammer.
    Then that's not pressing it in, is it?
    No but you said he DID use a press? I was saying he didn't he used a socket and hammer. ???
    Oh well not important just saying he didn't "press" it in with a press, he "pressed" it in with a hammer
  3. #48
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    What are the toque for the 2 diff mounting bolts? The bolt that retains the bushing? And the driveshaft bolts? Thanks!
  5. #49
    MotorMounts's Avatar
    MotorMounts is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black CTS-V
    May 2009
    Salem Oregon
    51
    400
    Whelp..........It sounds like it's time to build a F'in tool to put these bitches in.
    I'll crawl under the car (wait a minute.....I have a lift now) revision: I'll walk under the car tomorrow to get some ideas on how to build a "pull it out and push it in" gizmo. Or, maybe I should cut the bushings down 50 thow, then include some epoxy......kidding.
    I'll keep you posted
    Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
    http://www.creative-steel.com
    maxx@creative-steel.com
  6. #50
    PISNUOFF Guest
    Quote Originally Posted by MotorMounts View Post
    Cool! I'm about done with the loan-a-tool program.
  7. #51
    bdawg is offline Cadillac Owners Member
    Automobile(s): 05 Cadillac CTSV
    Apr 2007
    SANTA CLARITA
    40
    By any chance would you still loan it out?
  8. #52
    bneal1022's Avatar
    May 2009
    40
    906
    i just sent one of his back on thursday priority.. Brian should have it back on mon/tues. It did help - really whether it too out the entire bushing or just rip through the rubber, I planned on having to cut the bushing so I was not too busted up about it. I could not have got to the busing sleeve without it. If I had more time I would have made an insertion tool. I just had to get car together and in garage cuz of snow. Would not be bad, just need long big bolt, a contoured "puck" to mate to CS bushing flange face, and some type of thick brace with threads for the bolt to span the back of the diff bore to draw it in.
    I used a flapper wheel to dress the bore ID and CS bushing exterior until it was a snug, not press fit with a freezing bushing and hot bore. Used a deadblow to knock it in and used loctite 290 (wicking loctite). It aint going anywhere. The 290 is loctite for pre-assembled joints and literally vanishes via capilary action into joint
    I'm working on my writeup and can post it shortly as a pdf rather than trying to upload tons of pictures. I do have my specter werks written up and will post soon too.
    RazorBacker1 likes this.
  9. #53
    SkullV's Avatar
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Interesting method! Hope it works out (I'm sure it will). I wasn't thrilled about beating it in with a hammer, but it did work!
  10. #54
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Glad you worked it out. It ain't going anywhere
  11. #55
    Doba is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2007
    54
    didnt read anywhere that you had to take off rear axles? I take it its an obvious yes inorder to rotate the diff to that certain angle where you can access the bushings.
    - where did you buy your new bushing, I need to do that one, along with tranny mount and the two bushings holding driveshaft.. fun.. wouldnt it just be easier to drop the diff though?
  12. #56
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by Doba View Post
    You don't have to remove axles, unless you want to take the diff out, which is a lot more work.
    UUC bushing/trans mount from Luke @ Lindsay Cadillac, or CS diff bushing/trans mount from Max at Creative Steel.
  13. #57
    Jun 2007
    54
    Sounds good, just not sure If I want to struggle under the car or take it all off and comfortably do it on a press.
    gonna start stripping her down shortly, once I decide if im making the driveshaft bushings out of a rubber or aluminum... what would you V guys suggest?
  14. #58
    Jon's Avatar
    Jon
    Jon is online now Cadillac Owners Master
    Automobile(s): 16 ATS-V, 04 CTS-V, 09 CTS, 07 SRX, 04 CTS
    Feb 2004
    Alberta, Canada
    31
    6,655
    Just a FYI... Save you guys sometime
    The driveshaft does not need to be disconnected. There are 4 screws & a plate near the middle of the car that support the driveshaft. Remove them and you will be able to do this without disconnecting the driveshaft.
  15. #59
    Jon's Avatar
    Jon
    Feb 2004
    Alberta, Canada
    31
    6,655
    Test drove it today.... The howling is ridiculous at 50mph. Sounds like a school bus
  16. #60
    Jun 2007
    54
    any idea where the howling sound is coming from? and why
  17. Remove Advertisements
