Diff Differential Bushing Install Removal - Page 2
Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 105
Like Tree4Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Diff Differential Bushing Install Removal in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by SkullV The UUC can't move left-right but in order to be able to put it in there ...
  1. #16
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Diff Differential Bushing Install Removal
    Quote Originally Posted by SkullV View Post
    The UUC can't move left-right but in order to be able to put it in there easily by hand it MUST be able to move around inside the hole either up/down or side/side because there must be some amount of gap for you to be able to just slide it in.
    There's no metal outer sleeve on the UUC. The urethane touches the case itself. Remember my suggestion to turn down the UUC mount to fit inside the old metal sleeve of the stock diff bushing?
    BOTH mounts are going to provide flex/movement of the bolt slightly since they are urethane. Anything but a solid mount is going to have movement. But the bushing being sandwiched in between the diff and bracket with the bolt thru the middle.....it ain't going anywhere.
    Quote Originally Posted by PISNUOFF View Post
    All this talk about my tool is making me uncomfortable!
    Lolly - You and I had such a difficult time using my extractor because the spacer was aluminum and the OD was about 1mm too small. It's steel now and the diameter is perfect.
    If someone tells me the outer diameter of the inner metal sleeve of the CS bushing, I can have a spacer made to fit over it and you can pull the bushing into the casting from the other side using my extractor/installation tool.
    Brian, you have a lovely tool. I never doubted it LOLZ
    I think I have the old sleeve in my toolbox. I'll get the measurement tonight.
  2. #17
    SkullV's Avatar
    SkullV is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Quote Originally Posted by lollygagger8 View Post
    Not what I'm saying. The UUC if it is easily pushed into the diff casing itself can move up and down within it's hole. There MUST be some margin of gap there in order for you to be able to use your hands to press it in.
  3. #18
    Apr 2008
    Indiana
    4,913
    I love bagel bites
  5. #19
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    never had em'.
    i have a CS bushing at home. I can measure it and provide the ID and OD of the CS sleeve around the eurathane. Also I head of aluminum and steel sleeves in the diff. anybody know when this changed? I have an 05 and am praying it is steel. I will be recieving Brian's tool shortly (ooph tool and shortly.. WOW). I "could" chuck up the SC bushing in a lathe and emory the OD a bit at work.
    now I'm getting worried... how bad is the noise? I live in PA where eurathane "no likey cold" and it was so properly put. On the side note.. what you think a gen 1 diff with 18K pampered miles would bring in?
  6. #20
    SkullV's Avatar
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Diff bushing noise isnt bad. All of the bushing sleeves are steel, the ear of the diff where the bushing goes is aluminum.
  7. #21
    MAPerformance's Avatar
    MAPerformance is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V
    Jan 2010
    Minneapolis, MN
    31
    867
    You guys with the creative steel bushings need to freeze the bushing until the day you install it. It will contract a couple thousandths maybe hundredths and pop right in no problem. I do it all the time.
  8. #22
    bneal1022's Avatar
    May 2009
    40
    906
    that's a great point.. could heat gun the case bore as well... I also have Spekter rear cradle bushings to do.. Should I plan this at the same time? Are there parallel tasks in these jobs? or should thay be done entirely seperately?
    BTW the OD of the CS bushing i have is consistantly 1.900" - .002 at some places
  9. #23
    maxspeed96ct is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS-V
    Aug 2009
    31
    1,048
    Quote Originally Posted by MAPerformance View Post
    Tried it, left it in the freezer over night.
    I even hit it with a wire wheel to get it nice and smooth before I frooze it.
    No chance in hell.
    I should Of shaved it down , But once i got it a quater ways in I kept hammerin.
    When I should have stoped , pulled the bushing out and shaved off it
  10. #24
    bneal1022's Avatar
    May 2009
    40
    906
    has anybody had good luck with the CS diff bushing going in, does max know ofhte troubles? anyone know the nominal diameter of the diff bore?
    Brian.. as mentioned above the OD of the CS bushing sleeve is 1.900
    again any parallel tasks in this bushing and the cradle bushings?
  11. #25
    SkullV's Avatar
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Quote Originally Posted by bneal1022 View Post
    I told Max how difficult it was when I installed the first one. He said he would shave off some of the material but I don't know if it happened. It is not really a problem with the design of the mount, as the mount is designed exactly like the stock mount which would need to be installed in the same manner (using a press or hammering it in).
  12. #26
    MotorMounts's Avatar
    MotorMounts is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black CTS-V
    May 2009
    Salem Oregon
    51
    400
    The first bushings were 1.900" +/-.001. The wall thickness of our bushing is about .075", keep in mind that different room temperatures will make this thin of wall tubing expend and contract dramatically when compared to the diameter. What I mean is that .002" is more critical on a part that is 2" OD than .002" on a part that is say.....14" OD. After the last go-round of feedback that our bushings were too difficult to install I shaved them down to 1.898" +/- .001. I can shave them down another .002" to 1.896" but I'm afraid we'll start running the risk of them going too easy and being loose in the bore. .004" smaller than stock on a less than 2" OD is a bunch.
    Brian, it's your tool, but I would think that if your disc that pulls the sleeve out was 1.875" +/- .002 it would give you a minimum of 8 thow of clearance to the OD of the sleeve, to get maximum surface area on the edge of the bushing sleeve.
    In closing, we are walking a fine line between a press fit and a slip fit.
    Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
    http://www.creative-steel.com
    maxx@creative-steel.com
  13. #27
    Apr 2008
    Indiana
    4,913
    bneal, if you haven't left your car in a heated garage overnight to warm up the diff, try heating up the diff itself. It might help expand the aluminum case a little. Just a thought.
    As far as doing the diff bushing and the cradle bushings at the same time, that's up to you. There's no real parallel tasks between the two. If I were you, I'd do em seperately so you can get a feel for the new diff bushing, then add the cradle bushings later.
  14. #28
    PISNUOFF Guest
    Quote Originally Posted by MotorMounts View Post
    I have the OD of the bushing and the OD of my sleeve is 46mm (+0,-.5). What I need is the OD of the inner sleeve of your CS bushing so I can make a spacer with a pocket in it so it only contacts the outer sleeve of the CS bushing and doesn't pull on the center risking pulling it and the rubber through of the outer sleeve.
    BTW - all of the dims on the casting are metric. I've seen the drawings and may even still have a copy somewhere at home.
  15. #29
    May 2009
    Salem Oregon
    51
    400
    OK, I see what you need. The OD of the center sleeve is 1.000 (25.4 mm) and sticks out of the urethane a little over a 1/4" on each end.
    Is that what you needed? Max
  16. #30
    PISNUOFF Guest
    Exactly.
  17. Remove Advertisements
