E85 Conversion on Maggie'd V - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 84
Like Tree2Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, E85 Conversion on Maggie'd V in Cadillac CTS-V Series Forum - 2004 - 2007; You might wanna invest in some tuning software. I use HT tuners, and all it would take is two minutes ...
  1. #16
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,000
    Re: E85 Conversion on Maggie'd V
    You might wanna invest in some tuning software. I use HT tuners, and all it would take is two minutes to switch tunes. I wouldn't fell comfortable with the car trying to adjust from E85 to gas. And with that much timing.....If you do have to run gas with this tune, don't lug the gears. I notice (this is my car with my tune) if I let the RPMs get too low (under 1500) sometimes I get knock retard. When I'm off the gas and let the RPMs drop, when I get back on the gas she goes into boost and the MAP spikes. Say your on the highway in sixth. Traffic slows down for a bit. When you get back on the gas, your RPMs are a little over 1000, the MAP will spike. This is when I get some KR, so I keep the timing low in those cells.
    You also may want to look into a wideband. Not sure how your narrowband O2s are dealing with such a rich AFR.
    Keep in mind: This is from my limited experience with HP tuners, and watching/logging how my car reacts to changes in my tune. Hopefully the "smart" people will comment on my post.
    Anyway, good luck today. Can't wait to see your numbers
    Tony
  2. #17
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,813
    Quote Originally Posted by Twitch View Post
    Tony
    Yeah, Tony's probably right to invest in a handheld tuner ... you know, just in case. You are blazing a trail here after all ... as far as this forum is concerned anyway.
    I agree with Tony in the WB O2 sensor. But, the term "rich" may not apply since stoichiometric with E85 is 9.8/10/whatever so you have to adjust your thinking to that kind of number.
  3. #18
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,000
    Quote Originally Posted by rand49er View Post
    To clear things up. When I said rich, I was talking about running gas, if he can't find E85. I doubt the PCM is gonna simply adjust from 9.8 to 14.7. Then when you think about how easy it is for a Maggied V to go into PE, you'll be comanding an AFR around 6.5:1. That cant be good.
    Not trying to be negative. Just pointing out potential problems, so you can have a plan before it happens. I say just keep a cheapo laptop in the car.
    BTW I knew when I mentioned "smart" people, Randy would be the first one to jump in
  5. #19
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    36
    1,747
    Holy. Cow!!!!
    Nobody will believe this. I gotta get the dyno sheet scanned
  6. #20
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,000
    Quote Originally Posted by deedubb View Post
    holy. Cow!!!!
    just post the damn numbers!!!
  7. #21
    deedubb's Avatar
    Feb 2005
    Mile High
    36
    1,747
    Pre e85 was 429rwhp, post e85...... 487rwhp!!!
    And IAT's stayed 20-30 degrees lower than last time after 3-4 pulls.
    Most will say no way but I'll scan and post dyno sheets!
  8. #22
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Maybe that is why supercharged race cars have run alcohol for years.
  9. #23
    SkullV's Avatar
    SkullV is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Hell yeah man! Glad it all worked out for you, did they log the IDC during the dyno pulls?
  10. #24
    deedubb's Avatar
    Feb 2005
    Mile High
    36
    1,747
    I dunno what that is Ted, my tuner should be here sometime today to post the dyno sheets though and can answer that for me.
    I don't even have headers or have yet to put on the OD pulley. Should easily see over 500 at the wheels!
    I'm stoked!!
  11. #25
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,813
    I'm stoked!!
    Dang! Those are great numbers! Congrats!
    Just think about the guyz at sea level doing this.
    To clear things up. When I said rich, I was talking about running gas, if he can't find E85. I doubt the PCM is gonna simply adjust from 9.8 to 14.7. ...
    Oh, I see how you were thinking. I'm thinking you're probably right! That's a big adjustment going from E85 to "normal" premium gasoline in terms of the volume of fuel being injected ... I wouldn't think the PCM could adjust that far, either.
  12. #26
    SkullV's Avatar
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    I'm stoked!!
    Injector Duty Cycle. The not having headers or the pully on yet is what I am concerned about since you didn't change the injectors. It's gotta be close already!
  13. #27
    deedubb's Avatar
    Feb 2005
    Mile High
    36
    1,747
    Yup I gotta get injectors next. I think they said my injectors were 100% at the top of 2nd/3rd . In fact, I can't do the OD pulley till I get 60#ers or better
  14. #28
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,813
    Dee, when I was doing mine maggie a couple of years ago, Rick and I were communicating pretty closely. He had different injectors in his maggie and wanted the 60 #ers I had (Motrons). He ended up ordering the wrong ones. He seemed to imply that he had to eat them, though I'm not certain of that, but he ordered "long" ones according to him instead of "short" ones. All I'm saying is look everything over real well before you plunk down your plastic.
    Dang, this is exciting!
  15. #29
    97BlueDeville's Avatar
    97BlueDeville is offline Cadillac Owners Member
    Automobile(s): 06' DTS
    Sep 2004
    Aurora, CO
    41
    65
    Congrads dave...!
    Dave's CTS-V with E85 Conversion = 58 RWHP / 55 RWTQ Increase
    Again "Fan of E85 Fuel!"
    After a inline fuel pump, and e85 tune were installed on Dave's CTS-V, did a dyno today as you all know..
    Results below of best run of 91 Oct VS E85 Fuel. "NO" other mods done.
  16. #30
    Sep 2004
    Aurora, CO
    41
    65
    IDC was 90% on the top of 4th.
  17. Remove Advertisements
