Finally got around to having the nitrous tuned this past week. First bottle after converting it to a wet kit. Upped the jet from a 100 dry to a 125 wet, and she put down 491 at the wheels. I believe they are going to modify something else minor and rerun it, but the end result will be somewhere in the 490s.
Overall I am pretty happy with it. NA it made approx 375, but I was hoping the 125 would add exactly 125. The car ran great, no issues except maybe a little clutch slippage at activation.
I am going to be going much bigger. The stock bottom end is SUPPOSED to be able to handle a 200 shot with a spot on tune and some cold plugs (3 ranges colder then stock). Looking at dedicated fuel systems and direct port. My previous numbers 512/536 were only on a 100 shot.
I am not sure what to make of the numbers from that dyno anymore. A couple people from EPP ran on it and got lower numbers then EPPs dyno and it had spot on numbers for my SVT Contour with what all other SVT Contour's are running
At one point in time that would have been true, but with new technology like the Harris Speed Works Interface, a dry shot is probably safer because you eliminate the element of a leaking fuel solenoid. The only real safe way to go is direct port because you can tune each Cyl.
The torque was definitely a surprise. I was hoping for 500 hp, but never saw 517 tq coming. And I can feel it too. When I sprayed it was scary fast. Finally!
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
