| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Anyone know what kind of shifter this is?
11-02-09, 12:12 AM
| | Cadillac Owners Member Cadillac(s): none | | Join Date: Sep 2009 Location: Florida | | | Anyone know what kind of shifter this is? What kind of shifter is this? UUC? |
11-02-09, 12:26 AM
|  | Cadillac Owners Fanatic Cadillac(s): 05 CTS V | | Join Date: Feb 2009 Location: Avondale, AZ | | | Re: Anyone know what kind of shifter this is? UUC, pretty sure
__________________ Platinum, Katech STS, MOMO knob, UUC bushings, clear corners, Billet radio,A/C,door pulls, & armrest endcaps, sim brushed aluminum dash overlay,rear spoiler, 3157 LED tails, STAGEUP tune,GM Accessory wheels,Vision .08oz lugs, JETHOT KOOKS 1 7/8,HI FLO Cats, Aero Turbine muffs,H pipe, Specter Werkes cradle bushings,Billet Prototypes catchcan,NGK TR55, Optima Red Top, Hendrix PRO axles, Hawk HPS, cryo/cross drilled rotors(R). BEST E.T. to date 11/06/09: 13.495 @ 107.00 |
11-02-09, 12:29 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Anyone know what kind of shifter this is? Is the top threaded? I cant tell from the small pic. If it's threaded then its Katech, if not it's UUC.
__________________ R.I.P. Cadillacforums..... |
11-02-09, 05:54 AM
|  | Cadillac Owners Fanatic Cadillac(s): CTS-V | | | | | Re: Anyone know what kind of shifter this is? I already found this in my other thread about the magnaflows on ebay, its NOT threaded it's a UUC
Its on ebay, bid on it man you could just get one helluva deal (i already one one so im not bidding against you  ) |
11-02-09, 09:04 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Anyone know what kind of shifter this is? Yeah that looks like a UUC shifter alright.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
11-02-09, 11:57 AM
| | Cadillac Owners Fanatic Cadillac(s): 07 cts-v | | Join Date: Sep 2009 Location: N. Texas | | | Re: Anyone know what kind of shifter this is? It will not go cheap. On the rare occasion when a B&M gets on there it gets bid sky high. |
11-02-09, 08:39 PM
|  | Cadillac Owners Fanatic Cadillac(s): CTS-V | | | | | Re: Anyone know what kind of shifter this is? |
11-05-09, 03:07 PM
|  | Cadillac Owners Fanatic Cadillac(s): '05 CTS-V | | Join Date: Jul 2008 Age: 29 | | | Re: Anyone know what kind of shifter this is? Quote:
Originally Posted by SkullV Is the top threaded? I cant tell from the small pic. If it's threaded then its Katech, if not it's UUC. | The bottom end of my Katech has rounded corners -- it's not square like the one in the photo. I don't think that's a Katech, although it might be an earlier design than the one I have..
__________________ Katech shifter w/UUC bushings, Corsa cat-back, 2x RE Audio SE12s powered by a US Amps MD1D (1200w @1ohm), CAGS eliminator, K&N drop-in, W4M tuned PCM.. just getting started! |
11-05-09, 04:07 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Anyone know what kind of shifter this is? Quote:
Originally Posted by calidave The bottom end of my Katech has rounded corners -- it's not square like the one in the photo. I don't think that's a Katech, although it might be an earlier design than the one I have.. | The threading where the knob is installed is just the easiest way to tell since UUC and Katech are the only ones (other then OEM) that use a 2 piece design. |
11-08-09, 12:53 PM
| | Cadillac Owners Member Cadillac(s): 05 V | | Join Date: Aug 2009 Location: Calgary Age: 31 | | | Re: Anyone know what kind of shifter this is? that almost looks like a STOCK shifter to me (all cleaned up or new), not a UUC
If you look at the tapered shaft going to the top, UUC is not like this, there's is straight, if someone could verify.. but looking at UUC pics, the larger cylinder is straight not tapered smaller near the top. http://www.uucmotorwerks.com/CTSV/USSCTSV.htm
The other and MOST important way to tell the difference is Katech was cheap and makes you re-use bushings and sleeve where you connect the shifter to the fork for the transmission. UUC was smart in integrating (with urethane bushings) for this cross - bolt. - probably where the higher price comes to play.
Check the document out just over half way down. http://www.trafficjams.ca/Performanc...9SuedeKnob.htm
| | Cadillac Discussion Tools | | |
Censor is OFF | | | |
