5 Dyno Pulls, Holy Lost Power When Hot Batman
Results 1 to 9 of 9
2004-2007 Cadillac CTS-V Performance Mods Discussion, 5 Dyno Pulls, Holy Lost Power When Hot Batman in Cadillac CTS-V Series Forum - 2004 - 2007; Made 5 dyno pulls on my 2005 V with ~2300 miles: Fuel = Amoco Ultimate 93 Octane (only thing run ...
    StealthV's Avatar
    StealthV is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 Z06 / 2013 F150 EcoBeast / 2008 Twin-Turbo Bimmer
    May 2004
    MN>ND>MN>SD>IL>MN>IL
    48
    4,860
    Fuel = Amoco Ultimate 93 Octane (only thing run since it was new)
    Elevation = 700 ft
    Ambient temp = 87* F
    Atms. pressure = 29.99 in Hg
    Relative Humidity = 87%
    (The stereotypical hot, muggy, summer day)
    As the pulls went by, you could hear the V was getting hotter and that it didn't like the heat. Just speculation on my part, but the first pull probably would have set the best numbers of the day if allowed a full pull as it sounded the best on that one.
    Definitely need to work on my custom CAI design and feed some cold air into her.
    Pull #1
    320 RWHP @ 5404 RPM (aborted run)
    Knock Reduction = 0 degrees
    High octance fuel map = 100%
    Engine Coolant Temp = 192 *F
    Intake Air Temp = 91 *F
    A:F @ peak = 11.9
    Timing advance @ 5404 = 21*
    Pull #2
    341 RHWP @ 5928 RPM
    Engine Coolant Temp = 196 *F
    Intake Air Temp = 95 *F
    A:F @ peak = 12.1
    Timing advance @ peak = 21*
    Pull #3
    327 RHWP @ 6023 RPM
    Knock Reduction = 2.2 degrees
    High octance fuel map = 92.7%
    A:F @ peak = 12.1
    Timing Advance @ peak = 19.5*
    Pull #4
    331 RHWP @ 6025 RPM
    Knock Reduction = 5.9 degrees
    High octance fuel map = 97.2%
    Engine Coolant Temp = 201 *F
    Intake Air Temp = 100 *F
    A:F @ peak = 12.1
    Timing advance @ peak = 20.5*
    Pull #5
    330 RHWP @ 5916 RPM
    Knock Reduction = 5.6 degrees
    High octance fuel map = 99.7%
    Engine Coolant Temp = 203 *F
    Intake Air Temp = 97 *F
    A:F @ peak = 11.8
    Timing advance @ peak = 21.5*
    wildwhl's Avatar
    wildwhl is offline Cadillac Owners Master
    Mar 2004
    Reno, NV
    5,496
    Re: 5 Dyno Pulls, Holy Lost Power When Hot Batman
    Stealth V
    Is you V stock at this point? If not, what mods?
    Let's see - if it IS stock - 341 rwhp = reasonable loss in my book, aka about 44 rwhp over what the reported GTO numbers are...so I think, again, a point that the power is there!
    StealthV's Avatar
    May 2004
    48
    4,860
    Only thing not stock on mine is the Z06 fuel rail covers which perhaps helps a bit with trapping less heat over the intake manifold. Agree on the power being there, I think I got one of the media "ringer" cars, lol.
  5. #4
    Slick V's Avatar
    Slick V is offline Cadillac Owners Fanatic
    Apr 2004
    Ft. Lauderdale
    32
    247
    Those are some good numbers
  6. #5
    Shinkaze is offline Cadillac Owners Fanatic
    Atlanta, GA
    331
    Great numbers, I think 341 is the strongest dyno I've seen yet and looks like a solid LS6 Car! FWIW on my TA I noticed greater heat soak (maybe of the coil packs) when I had the covers on and picked up 5 RWHP when I pulled them off (that is while doing back to back runs). On a first or second run it really didn't make any difference. That said the cowl of an F-Body over hangs the motor so there is less airflow. not sure it's that big of a factor on a V or not. I'll have to take a closer look when I get more time but ~15 RWHP between 2 and 3 worry me since the intake temps are the same. You may want to post this over at LS1Tech since the have some Gurus over there that can probably disect those runs much better than I ever could.
    -Adam
  7. #6
    Dreamin is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 ATS-V
    Feb 2004
    Calif.
    2,254
    StealthV: What are you using to log that data?
  8. #7
    StealthV's Avatar
    May 2004
    48
    4,860
    Quote Originally Posted by Shinkaze
    ~15 RWHP between 2 and 3 worry me since the intake temps are the same. -Adam
    Sorry, made a typo on run 3: the intake air temp was 97, not 95 which in itself isn't enough to explain the HP difference.
    For some reason on run 3 (heat soak ) the timing was 15-18* for most of the pull and peaked out at 19.5* around 6000 RPM. Compared to pulls 1 & 2 where the timing was pushing 29* up until about ~3700 and started backing down to 21* as it climbed higher up the rev band.
    That lost spark advance in pulls 3, 4 & 5 caused the power loss - over 14 degrees less advance than the first two pulls. Just need to figure out what caused it now.
  9. #8
    StealthV's Avatar
    May 2004
    48
    4,860
    Quote Originally Posted by Dreamin
    <-- men in black holding a gun to my head. All I can say is be patient.
  10. #9
    Feb 2004
    Calif.
    2,254
    No problem, will do. I guess it's related to your new "supporting vendor" status?
    I have Ease PC... but it doesn't show High octane fuel map as a percentage... it shows everything else.
    I am thinking about getting HP Tuner... just to be different.
    But i can wait to see what you have in store!
  11. Remove Advertisements
