| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Gforce Axles Review
10-18-09, 12:07 AM
| | Cadillac Owners Fanatic Cadillac(s): 2005 Cadillac CTS-V | 2007 Cadillac Escalade ESV | | Join Date: Oct 2008 Location: Dallas, TX | | | Gforce Axles Review Alright, here is a quick summary of the results. We used the lollygagger write up for guidelines.
Install was pretty straight forward. Labor was intensive, but can be done in about 1 1/2 hours if you know what you are doing. Here are a few KEY notes.
1. When you are trying to get the outer CV joint off the half shaft, it is very difficult. You will need to use a tremendous amount of force. We wrapped the joint and half shaft with a towel, and hit it with a sledge hammer. (don't damage the CV). It took several hits to finally get it loose.
2. When inserting the shaft into the differential, you are listening and feeling for a snap (most likely won't hear it, but you will feel it). This is the retaining clip going past something inside the differential that holds it in. Once you push past that, continue all the way until it stops. AT THIS POINT, PULL IT BACK SLOWLY UNTIL IT CATCHES.
During the initial install, we left the shaft all the way up against the differential, and it kicked it out when we were on the test run (leaving us stranded three blocks away. If you compare it to the driver's side, even that shaft is out from the differential slightly. We pushed the car back, redid the entire thing, and did what I told you guys to do.
3. When trying to insert the half shaft into the hub, it helps to push up on the bottom of the spring with a jack. This helps to align ALL the pieces that eventually bolt onto it. ALSO, make sure the half shaft is comepletely perpendicular to the hub, or it won't go in all the way.
Results:
3000 rpm clutch dump -> smooth with the rear just raising up and laying down rubber. Experienced minimal wheel hop right before and after the 1-2 shift. Normal, nothing bad at all.
3500 rpm clutch dump -> same result
4000 rpm clutch dump -> same result
Rolling start -> smooth, no hop
After the diff kicking out the axle the first pass, we were very nervous that it would happen again. Luckily, nothing yet, and hopefully nothing ever. This has nothing to do with the half shaft from gforce, it is a design issue with the inner CV.
Overall...very happy. No hop.
__________________ 2005 Platinum Silver | Brand X Nitrous | Zex HALO Purge | Zex AutoTherm Heater| Kooks 1 7/8 Headers | Magnaflow Exhaust | MSD Super Conductor Wires | NGK TR6 plugs | Stealth V Intake w/K&N drop in | Eibach Springs w/2003RC51 spacers | GForce1320 Half Shaft | B&M Shifter & UUC Bushings | Z06 FRCs | Goodyear F1 GS2s | Deck Lid Spoiler | iPod/XM adapter
Dynojet @ 21st Century 371whp/360tq NA | 487whp/517tq N2O |
10-18-09, 01:13 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Gforce Axles Review These were street or track results?
__________________ R.I.P. Cadillacforums..... Quote:
Originally Posted by Twitch I might treat myself to a lil something this Christmas. I like the idea of a 90mm setup. But,,,,,and don't tell anyone,,,,,it's probably a better idea to let her exhale better before I shove more air down her throat. | |
10-18-09, 01:35 AM
| | Cadillac Owners Fanatic Cadillac(s): NONE | | | | | Re: Gforce Axles Review That's great!
Did you and Wistler both get them installed?
Thanks
Chris |
10-18-09, 12:32 PM
|  | Cadillac Owners Connoisseur Cadillac(s): CTS-V | | Join Date: Jan 2007 Location: Dallas, TX Age: 29 | | | Re: Gforce Axles Review So how bad was the pucker factor when the axle popped out?! I would have automatically thought diff failure! One thing i wonder is if you cannibalize your stock axles and the diff does go out, i guess you'd kinda be outta luck in terms of warranty taking care of it? This would only be an issue for people still under warranty of course. If you had your stock axles laying around and blew the diff you could potentially take the time to put the stock axle back in. Glad the wheelhop is gone for ya though. Its like a whole new car now i bet! |
10-18-09, 01:25 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04/'09 CTS-Vs | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Gforce Axles Review Quote:
Originally Posted by dannboss After the diff kicking out the axle the first pass, we were very nervous that it would happen again. Luckily, nothing yet, and hopefully nothing ever. This has nothing to do with the half shaft from gforce, it is a design issue with the inner CV. | I would p00p my pants. How the hell do you prevent that from happening at all?
__________________ The Caddy that zigs?
So they were a generation late...or two... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 24,882 and counting... |
10-18-09, 01:29 PM
| | Cadillac Owners Fanatic Cadillac(s): NONE | | | | | Re: Gforce Axles Review The trick is to make sure you feel the retaining snap out into the retaining groove.
Sometimes those OEM retaining rings get compressed and dont spring back out like they should. You can take them off and expand them a bit so they spring out a bit harder.
If you put the stub in too far and the retaining ring doesnt snap out into the groove then it will come right out while driving.
Best was is to put the stub in until it bottoms out and then pull back out a bit until you feel the retaining ring snap out into the retaining ring groove in the diff. |
10-18-09, 02:25 PM
| | Cadillac Owners Fanatic Cadillac(s): 2005 Cadillac CTS-V | 2007 Cadillac Escalade ESV | | Join Date: Oct 2008 Location: Dallas, TX | | | Re: Gforce Axles Review These were street results, although the test was the same as if I was at the track (I would think) considering the hard launch and shift through 3rd.
The pucker factor was bad. I had no idea what happened, but heard and felt a clunk and new something was wrong. Hindsight though, couldn't I have still driven it back since power should still be delivered to the driver side?
If it destroyed something, I would just take the gforce sticker off the axle and take it in. Don't think a tech would really be able to tell the axle was different considering the rest of the half shaft is still stock. But technically, you could just put it all back to stock. |
10-18-09, 02:38 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Gforce Axles Review The test is COMPLETELY different at a prepped track. I have had the same exact results as you with my single axle from the other company, but at the track everything changed. |
10-18-09, 03:22 PM
|  | Semper Fi Cadillac(s): (His) 2007 CTS-V (Hers) 2010 SRX | | Join Date: Apr 2007 Location: Plano, TX Age: 27 | | | Re: Gforce Axles Review We ran out of time to install mine. Whenever Dannboss has time to help with my install mine is going in.
We now know how the axle is suppose to fit into the diff. It was much quicker the second time around. Mine should take around 2 hrs now that we know exactly what to look for.
__________________ 2010 SRX: Stock
2007 CTS-V: SNL v.2 Cam, Kooks 1 3/4" headers with off road pipes, Magnaflow with Tru- X, CAI, Eibach Pro Kit, Monster Level 2 clutch and 18lb flywheel, Gforce1320 axles, flat black powdercoated wheels, Dunlop SP Sport 01 275/35 rear, 245/40 front, V2 shift knob & tuned by Matt Gelsomini at SNL Performance: 406rwhp/418rwtq http://www.youtube.com/user/whisler151 |
10-18-09, 08:02 PM
| | Cadillac Owners Enthusiast Cadillac(s): 05 CTS-V | | Join Date: Aug 2009 Age: 24 | | | Re: Gforce Axles Review good to hear,
are you running any other anti wheel hop stuff? kars, bmr,spector?
also, Im curious to see a track test just to see how it does, but I honestly dont plan on tracking my V. |
10-18-09, 11:57 PM
| | Cadillac Owners Fanatic Cadillac(s): 2005 Cadillac CTS-V | 2007 Cadillac Escalade ESV | | Join Date: Oct 2008 Location: Dallas, TX | | | Re: Gforce Axles Review SkullV, I thought you were talking about the drag strip. I agree that a road course would be a different test. I am going to try and make the next open track day at eagle's canyon.
The only aftermarket "suspension" mods I have are Eibach springs and the TSB wheel hop spacers. Neither did squat for the vicious wheel hop though. |
10-19-09, 12:10 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Gforce Axles Review Quote:
Originally Posted by dannboss SkullV, I thought you were talking about the drag strip. I agree that a road course would be a different test. I am going to try and make the next open track day at eagle's canyon.
The only aftermarket "suspension" mods I have are Eibach springs and the TSB wheel hop spacers. Neither did squat for the vicious wheel hop though. | I am talking about a drag strip. A prepped strip offers MUCH more traction at launch then a road course. These axles should make absolutely no difference at a road course unless they are out of balance which would be bad and not good. |
10-19-09, 12:15 AM
| | Cadillac Owners Fanatic Cadillac(s): 2005 Cadillac CTS-V | 2007 Cadillac Escalade ESV | | Join Date: Oct 2008 Location: Dallas, TX | | | Re: Gforce Axles Review Quote:
Originally Posted by SkullV I am talking about a drag strip. A prepped strip offers MUCH more traction at launch then a road course. These axles should make absolutely no difference at a road course unless they are out of balance which would be bad and not good. | Drag strip is planned as well. Looking to do that sooner than later, and will post results. |
10-19-09, 12:23 AM
Originally Posted by dannboss Drag strip is planned as well. Looking to do that sooner than later, and will post results. | Sweet! Looking forward to it. Have you been to the strip before and gotten hop? |
10-19-09, 12:47 AM
| | Cadillac Owners Member Cadillac(s): CTS-V | | Join Date: Jan 2009 Age: 21 | | | Re: Gforce Axles Review well im ordering mine tomorrow and as soon as its instaleld it will be to the track the same week so if they arent there by then ill post results. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
