Looking for rear toe rods and trailing arms
Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 78
2004-2007 Cadillac CTS-V Performance Mods Discussion, Looking for rear toe rods and trailing arms in Cadillac CTS-V Series Forum - 2004 - 2007; OK, lots of aftermarket activity these days but I'm still having trouble locating aftermarket chunkier toe rods and offset/bent thicker ...
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    OK, lots of aftermarket activity these days but I'm still having trouble locating aftermarket chunkier toe rods and offset/bent thicker (preferably) trailing arms to tighten up the rear and allow for some larger rear wheels.
    Anyone out there thinking of making and selling some please let me know.
    Missed out on RC51s, Voodoo (who ended up not selling them) and the newest vendors don't seem to be making them.
    Cheers.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,215
    Re: Looking for rear toe rods and trailing arms
    BMR makes them. Are those not beefy enough for you?
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    CTS-Voodoo's Avatar
    CTS-Voodoo is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Raven V
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by AAIIIC View Post
    Those are straight like the stock ones. Though my best advice is to buy BMR arms and have them sliced and bent at a fab shop. Its not that much work and your average custom shop would only charge hourly fabrication prices, figure 4-500?
    ichpen's Avatar
    May 2008
    1,383
    Quote Originally Posted by CTS-Voodoo View Post
    Good idea. Didn't I read somewhere that the BMR toe rods were a bitch to do an alignment on? Curious as the first thing I'll be doing is an alignment after installation
    What do you reckon on the bending, 2-3"?
    CTS-Voodoo's Avatar
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by ichpen View Post
    Well they actually have to be bent in a downward position from the front mount so you can run them below the body mount. Heres stock:
    So when you drop the front to clear the body mount:
    Look at all that beautiful clearance... While you're back there slap in the braided lines and a set of toe rods, its so worth it. The toe rods are what is really making the handling difference in my rear. Im sure eliminating the rubber mounts has helped, but the car is so solid in the rear now that the only way it comes out is by gross throttle application. Heres a shot of mine, super basic, same construction as the trailing arms 1.25 X .120 wall DOM with FPK ends, i think theyre 3/4 shaft, its been a while. The hiems are teflon lined (and a little overbuilt for because theyre made for rock crawlers)
    jerrycecco is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Jun 2005
    TX
    469
    Quote Originally Posted by Look at all that beautiful clearance... :D While you're back there slap in the braided lines and a set of toe rods, its so worth it. The toe rods are what is really making the handling difference in my rear. Im sure eliminating the rubber mounts has helped, but the car is so solid in the rear now that the only way it comes out is by gross throttle application. Heres a shot of mine, super basic, same construction as the trailing arms 1.25 X .120 wall DOM with FPK ends, i think theyre 3/4 shaft, its been a while. The hiems are teflon lined (and a little overbuilt for because theyre made for rock crawlers)
    [IMG
    http://www.happypestcontrol.com/webextras/ctsv/ctsv-rear-build/100_0606.jpg[/IMG]
    I asked before and I'll nicely ask again, CTS-Voodoo, I'm interested in buy a set of toe rods if you build one more set...
    jerrycecco@tx.rr.com
    supergeess is offline Cadillac Owners Fanatic
    Automobile(s): none
    Jul 2008
    Los Angeles
    127
    Will someone please make these trailing arms!! I am sure they would sell pretty quickly.
    MO POWA! is offline Cadillac Owners Fanatic
    Automobile(s): CTS V
    May 2009
    30
    140
    i need some offset trailing arms too, looks like i'll end up modifying my bmr ones
    TKSFab is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Feb 2009
    108
    toe rods are easy for me, the only problem im having is finding a uni-ball for the trailing arms.
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,786
    My alignment guy was not happy at all with the inside nut on the toe rod (BMR) as it is very hard to get at once installed.
    I thought about grinding a socket wrench down and making a special tool for this purpose, but my alignment guy said he managed to tighten it with an air chisel (I think he was joking!).
    Jun 2005
    TX
    469
    Quote Originally Posted by TKSFab View Post
    Excellant....
    Like to see what toe rods looks like and the price too...
    ichpen's Avatar
    May 2008
    1,383
    Quote Originally Posted by jerrycecco View Post
    Excellant....
    Yes, sign me up for toe rods also please
    Feb 2009
    108
    I will be building Toe rods this week. Trailing arms are going to be hard for me to make as i have to make it based on my car pulling the trailing arms is a time consuming process, or at least it appears that way, and i dont have a 295 tire. i need to round up everything i need which i am working on the,once all gathered the process can continue forward.
    Anyways, the Toe rods will be 1.25 x.120 wall 4130 chromoly tubing with chromoly bungs and aurora heims(quite simply the best heims on the market). Everything will be tig welded as well.
    Pictures and thread to come when i complete them.
  16. #14
    CTS-Voodoo's Avatar
    Oct 2008
    AutoRepairSEO.com
    951
    Sounds like everyone here will finally have the pretty version of what I have.
  17. #15
    ichpen's Avatar
    May 2008
    1,383
    Yay. Thanks. Keep us posted and put me on the list.
  18. Remove Advertisements
