| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Creative Steel/Ultra Mounts Transmission Mount Full Review
09-28-09, 01:49 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Creative Steel/Ultra Mounts Transmission Mount Full Review Alright everyone, I said I would write a review of this transmission mount after I had it in for a few days and had driven hard on it so here it is: 1) Idle Quality This mount has a great feel at idle. There are really little-no added vibrations that would be noticeable to the average person. There is a slight noise increase and I can now hear some clutch chatter when the clutch pedal is out that I never heard before this mount was installed. Overall I would say 10%-20% increase in vibrations/noise 2) Normal Start from a Red Light There is not much difference in noise/vibrations here from a good condition stock mount but shifting is significantly smoother. Shifting is the only time a noise difference can occur becasue you can hear the syncros "winding" up. I would say 5%-10% increase in noise only due to shifting 3) Hard Launch from a Red Light Do you ever miss shifts? Do you sometimes have a problem getting into gear? If so then this is the mount for you!!! I noticed that before I had this mount, when I was REALLY beating on it, there would be times where I would have to "force" the transmission into gear, this is no longer a problem. The shifter engages with a nice click on each shift and shifting effort has significantly decreased (this is also evident in downshifts). Overall there is a 5%-10% increase in noise again due to shifting 4) Cruising at any Speed There is little to no difference here from the stock mounts. No added vibration but there is some added road noise. I would say 20%-30% increase in in cabin noise. 5) Increased HP/TQ Now I'm not going to go out there and say that this mount made ANY difference in this department, but I do feel like it slightly increased throttle response. This should be expected though anytime you tighten up the drive line. Less stuff to twist equals power to the wheels faster. Once again Max went above and beyond with this mount. You will never have to worry about this mount's studs twisting, or this mount ripping apart. I would recommend this to anyone including the everyday V driver. I would even go as far as to say that when you are doing that first shifter mod you should get this too to REALLY make a difference. Move over UUC Creative Steel is here to stay and they are only getting better (stay tuned  )!
__________________ R.I.P. Cadillacforums..... |
09-28-09, 02:27 AM
|  | Cadillac Owners Fanatic Cadillac(s): 05 CTS V | | Join Date: Feb 2009 Location: Avondale, AZ | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review I will be ordering mine this week. thanks for the write up.
__________________ Platinum, Katech STS, MOMO knob, UUC bushings, clear corners, Billet radio,A/C,door pulls, & armrest endcaps, sim brushed aluminum dash overlay,rear spoiler, 3157 LED tails, STAGEUP tune,GM Accessory wheels,Vision .08oz lugs, JETHOT KOOKS 1 7/8,HI FLO Cats, Aero Turbine muffs,H pipe, Specter Werkes cradle bushings,Billet Prototypes catchcan,NGK TR55, Optima Red Top, Hendrix PRO axles, Hawk HPS, cryo/cross drilled rotors(R). BEST E.T. to date 11/06/09: 13.495 @ 107.00 |
09-28-09, 10:59 AM
| | Cadillac Owners Member Cadillac(s): none | | Join Date: May 2009 Age: 43 | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review Thanks for the info Ted. Another nicely detailed review. I think Purdue is paying off for ya. From what you wrote I was thinking there might be some "non-performance" folks out there that would like a mount that is a bit softer or closer to stock. Our mount only has 4X the urethane of the stock mount so I think we could safely soften it up and still be way ahead. You guys tell me......From what Ted wrote, leave it alone, go softer, do both?
I'm glad the mount is working out because the mold it required was a real bitch.
__________________ Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
I'll let you know when the web site is up. |
09-28-09, 11:03 AM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review A little softer than metal, but stronger than urethane? Very nice
__________________ Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff, Clear Fogs/Sidemarkers, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq |
09-28-09, 11:03 AM
| | Cadillac Owners Enthusiast Cadillac(s): 05 Raven V | | Join Date: Oct 2008 Location: San Diego | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review Leave the mount firm. "Increased vibration" is part of running urethane mounts. Heh, wait till one of these boys gets a couple of solid mounts.. then theyll know what REAL vibration feels like.  |
09-28-09, 11:42 AM
|  | <----- go ahead and stare Cadillac(s): Maggied '05 CTS-V | | Join Date: Jan 2008 Location: West Chester, PA Age: 26 | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review Thanks Ted. What about reduced clunk?
__________________ 05 CTS-V / maggie 2.8 / b&m shifter & uuc bushings / gto shift knob / kooks lts 1 3/4 + cats / magnaflow / k&n cai / fg2 shocks / hotchkis sways / hawk hps / 265|40 bfg kd / ngk tr6
434 rwhp / 412 rwtq..........are you new to the forum? READ THIS and then TRY THIS. |
09-28-09, 12:45 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac cts v | | Join Date: Feb 2007 Location: Wisconsin Age: 54 | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review Quote:
Originally Posted by MotorMounts Thanks for the info Ted. Another nicely detailed review. I think Purdue is paying off for ya. From what you wrote I was thinking there might be some "non-performance" folks out there that would like a mount that is a bit softer or closer to stock. Our mount only has 4X the urethane of the stock mount so I think we could safely soften it up and still be way ahead. You guys tell me......From what Ted wrote, leave it alone, go softer, do both?
I'm glad the mount is working out because the mold it required was a real bitch. | If you make it a little softer you'll sell more. If it was only 2 or 3X the urethane of the stock mount it would still be a big improvement. I think for the road course track guys who don't need hard launches, it would be a good option.
__________________ FG2s| GMPD bars| H&R springs| UUC slotted rotors 2piece up front| Hawk HP+ with Tispeed shims| Goodridge stainless brake lines.| UUC shifter| UUC wrapped knob| Z06 FRCs| Kooks headers 1.75| Hi-Flo cats| Corsa exhaust| Lingenfelter CAI| CG Lock| Ultimate grid pedals| Stealth FFV intake tube| UUC trans mount| 381RWHP 357RWT tuned by SpeedLab Spring Grove Ill SuperFlow Dyno| |
09-29-09, 02:52 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review Bump for a great product! |
09-30-09, 02:46 AM
|  | Cadillac Owners Member Cadillac(s): 05 CTS-V Stealth Gray | | Join Date: Sep 2009 Location: Wylie, TX Age: 28 | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review How hard was the install? Anyone in the DFW area that would help me change mine for a six pack?
I just picked up a 05 out of warranty with broken mounts. |
09-30-09, 06:05 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2007 Cadillac CTS-V Series | | Join Date: Oct 2004 Location: McLean, VA Age: 25 | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review Quote:
Originally Posted by CTSV_510 Thanks Ted. What about reduced clunk? | this is what i'm curious about as well... |
09-30-09, 06:28 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review Quote:
Originally Posted by CTSV_510 Thanks Ted. What about reduced clunk? | Quote:
Originally Posted by Natedog this is what i'm curious about as well... |
It's hard to answer this question. The cause of the clunk is reduced, and there is less twisting at the differential bushing, but you can hear the clunk just as well due to the poly that the mount is made of instead of rubber... |
09-30-09, 11:29 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 CTS-V, Black | | Join Date: Jun 2008 Location: Northern New Jersey | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review So Ted, do you think it is it safe to say that these are a superior mount to the (new style) UUCs?
__________________ 2005 Raven Black w/ Sunroof... CAGS - UUC Shifter & Bushings w/ 09 V Shift Knob - Magnaflow Exhaust - 20% Tint - Blacked Out Rear & Sidemarkers - Creative Steel Motor Mounts/Trans Mount - UUC Diff Bushing - CTS Armrest - K&N CAI - Chrome OEM rims - Goodyear F1's - 07 Diff with KARS III - Ultimate Pedals - GM drilled/slotted rotors - Sea-V Billet Lock Pulls - Valentine 1 - Wait4Me Tune - JL Audio 10" W6V2 Sub Swap - Heavy's Fire Extinguisher ... waiting to go on: clear fogs |
09-30-09, 11:49 PM
Originally Posted by c4ss So Ted, do you think it is it safe to say that these are a superior mount to the (new style) UUCs? | Yes, they absolutely are. |
10-01-09, 12:29 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 CTS-V, Black | | Join Date: Jun 2008 Location: Northern New Jersey | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review Quote:
Originally Posted by SkullV Yes, they absolutely are. |
Good to know. I only ask because I'm in the market for a set. I've gone through 2 set's of stockers in about two years  |
10-02-09, 06:39 PM
| | Cadillac Owners Member Cadillac(s): 2005 CTS-V | | Join Date: Apr 2009 Age: 39 | | | Re: Creative Steel/Ultra Mounts Transmission Mount Full Review I just ordered the whole set today!! Can't wait to feel the improvement. It was a pleasure talking to you today, but I didn't catch your name.
Thanks, Billy | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
